K51b john deere transmission problem
Slow speed and loss of power what parts would you reccomend. I'm looking at replacing the cyl. block, motor kit and filter .
SOURCE: illustrated parts list for john deere 102 riding lawnmower
Go online to www.johndeere.com click on residenial tractors,then click on services and support. You should be able to get an answer there. Otherwise contact them through email.
Posted on Apr 08, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
nova2nv
  • 197 Answers
SOURCE: My 870 john deere clutch will not disengage. The
This is common for the 70 series.Clutch dics are stuck together,just short of splitting tractor you have to hit a pile of dirt with loader bucket to see if you can break it loose.
Posted on Nov 14, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Replaced transmission on my John
Hi and welcome to FixYa, I am Kelly
This is a generic response to all John Deere Variator linkages but most likely what you must do with a transmission change.
To adjust the "Variator linkage" do the following.
1. Pry off the buttons on the side that cover the access holes located just below the variable speed lever.
2. Put the variable speed lever in notch #5.
3. Loosen cap screw one or two turns. This is located inside the hole.
4. Disconnect and ground the spark plug.
5. Turn ignition key to crank engine until clutch-brake pedal raises as high as it will go.
6. Take up linkage slack by pushing down on cap screw (see step #2). Tighten cap screw.
NOTE: If the tractor won't move with the variator in the first notch after these adjustments then the primary drive belt needs to be replaced.
I am concerned that maybe you did not connect the linkage properly but you have to do the above steps if no matter what you do you only have slow speeds.
Posted on Apr 22, 2011
rstef58
SOURCE: My John Deere LX280 is slow when backing up & has very little power. The fluid lever is good. Where should I look.
I have a LX280 that had this same issue. The problem was grass clippings blocking the pedal movement underneath the mower. Follow the rear pedal path and you may find the same issue. After removing the clippings buildup under the mower, the power was restored. Cheers!
Posted on May 03, 2012
Where can i find the oil drain plug on kt17 kohler motor
look for a pipe that has a plug in the end or a pipe cap .
Oct 04, 2017 | John Deere Garden
What size drive belt fits John Deer L110 ?
The youtube video shows you how to replace it.
This webpage also has detailed instructions:
https://jdagccc.custhelp.com/app/answers/detail/a_id/486/~/transmission-drive-belt-replacement---100-series-hydro-42-in.
This should be the replacement belt you are after. Please confirm before purchasing. http://www.greenpartstore.com/John-Deere-Traction-Drive-Belt-and-Idler-Kit-GX20006KIT1.html
Nov 16, 2016 | John Deere L100 Series
I purchased a K46 transmission to put in my John Deere LA115. Once installed it worked but pressing revese makes it go forward at slow speed and pressing forward it goes quick at varied speeds.
Try removing the lever on the shaft and turning it 180 degrees, or connecting above or below the pivot point.. This should reverse the operation of the linkage.It will be pushing the opposite way then.
Oct 17, 2016 | John Deere L100 Series
Feb 29, 2012 | John Deere Garden
John Deere Three Bottom Rollover Plow
Hey, the "round cylinder" is a power steering motor for a John Deere 630. If you start looking for one of those instead, I'll bet you'll have better luck. Deere dealerships tend to not care unless you're buying a half million dollars in equipment.
Sep 27, 2009 | John Deere 3 Pt. Hitch Moldboard Plow...
John deere transmission what other mowers interchange
You will have to first know what kind of transmission you have. You will have to consider if it is manual or hydrostatic drive. The transmission model number should be stamped usually on the top of the transmission. Yes transmissions are interchangeable, for example some John Deere, Craftsmans and Husqvarna all use the same transmission. Peerless is a manufacturer of these, the only one I know of. So don't let anyone tell you that you can ONLY use a John Deere product. To determine what transmission you can cross over with, get the model and serial number off of your John Deere's transmission. Call a small engine repair shop and ask them what all transmissions it will cross over with. Let them know you are aware that Peerless manufactures the same transmissions for most all riding mowers and that they will interchange. If they are uncoperative, contact me with the model and serial numbers off of your transmission and I will cross reference it for you. But try to get model and serial numbers for other brands from them, then check these against used ones. You will need to tell them if it is a hydrostatic transmission or manual and if so what speed manual.
Jul 11, 2009 | Athearn N Rtr John Deere Tractor Model B ...
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
