Question about NAD Audio Players & Recorders
Nad 5120 turntable motor faulty
Motor faulty
2 Suggested Answers
  • 35708 Answers
SOURCE: I have a NAD 5120 turntable. When the head liftes to play,it connects on one channel and the unconnected side makes a "mmmm" sound. What do i needs to change? Or is this the end?
This may not be the end. Check the connections at the rear of the cartridge. They have a tendency to work loose over time
Posted on Oct 13, 2012
How do I set-up my NAD 533 turntable for initial use???
This Turntable looks nice. The belt goes around the two spindles [one big one small. the speed is adjusted by choosing which part of the small spindle you put the belt on. The upper platter rests on the big spindle and doesn't seem to be secured to it.
The counterweight should simply screw onto the back of the arm.
Manual can be found here: http://akdatabase.org/AKview/albums/userpics/10007/NAD%20533%20Turntable%20Owner's%20Manual.pdf
Jul 02, 2014 | NAD 533 Turntable
How do I set-up my NAD 533 for it's first time use ???
nadelectronics.com/products/turntables/533-Turntable
www.manualslib.com > Brands > NAD Manuals > Turntable > 533
Jul 02, 2014 | Denon DP-29F Turntable
Where can i get a on/off switch for a NAD 5120 turntable?
You will have to match it up to something that's currently available, as NAD is long out of business. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 06, 2013 | NAD 533 Turntable
Grating noise when turntable is spinning
if u r comfortable taking the turntable off the record player do that and turn on the player without it on see if the grating noise is still there if it is u have a motor problem if it is gone find out from a stereo place what u can use to clean the top, bottom edge, and underside of the plate that the record sits on check your belt for signs of wear good luck
Sep 30, 2013 | NAD 533 Turntable
NAD T760 FM stereo not working
Hello
There are three fuses with your NAD surround receiver.
Reference No Part Number Description
M751*AH 5120-0200-0 Fuse 5A 125V Time Lag 5x20 MM MITI/UL/CSA
M754*AH 5120-0052-0 Fuse 1.6A 250V Time Lag 5x20 MM UL/CSA
M752*C 5120-0024-0 Fuse 3.15A 250V Time Lag 5x20 MM SEMKO/VDE
Check them first and inform me which one has blown out. I'll give you detais after that. OK.
Oct 26, 2011 | NAD T760
My very old NAD 5025 got a hum noise problem
Check the motor shaft. It could be bent making the pully wobble which makes the whole turntable vibrate which gets passed through the needle. I just found this out on mine. Easy way to test is to hold the platter while the needle is resting on the record. The speakers will hum/wobble at a low frequency. Lift the needle off the record and the sound stops? It's the motor...
Jan 23, 2009 | NAD 533 Turntable
NAD 533 Turntable
Just do a search in Google for "NAD 533 Drive Belt"
- OPTiC
Turntable Technician
www.1200s.com
Sep 01, 2008 | NAD 533 Turntable
Nad turntable
the belt (aka rubber band) should be changed when it starts to slip
it is not whats causing the table to turn backwards. it's the motor or circut that drives the motor.
Jan 22, 2008 | NAD 533 Turntable
Connect turntable to NAD S300
Yes you will need a pre-amp for your turntable, there is no phono input on this amplifier. Please update the question & let us know if the information given was useful to you - Good Luck!
Sep 08, 2007 | NAD S300 Amplifier
51 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
