Can't get remote to turn on tv it will turn valume high & low but it won't change channels or turn tv on and off. can't manually change channels
    Scholar:
  • 89 Answers
Are you using the supplied remote with the TV.
Try Resetting the Remote.
First, remove the batteries from the remote.
Then, wipe the contact surface of the batteries.
Then, press each button on the Remote twice repeatedly.
Then, reinsert the batteries and check whether the issue is resolved.
Posted on Jun 17, 2009
Trying to set up my new elements tv with a uverse wireless box. Did a channel scan but still can't find any channels. Help please!!
Is this a high def tv? Are you using an hdmi cable, component cable(red green & blue) or a low def coax cable to connect the tv? If coax, the tv needs to be on channel 3 or 4. If hdmi or component cable is used you need to change your input on the tv with your remote to the matching input you wired it to. The uverse stb (set top box) changes the actual channels once you have selected the correct input.
Jun 26, 2014 | Televison & Video
Sharp Aquos LC-60E79U has flashing green power light and OPC light but won't turn on
Try to I unpluged the power, push volume and channel down, pluged power again
While it's flashing unplug your TV from the main power source for 15 seconds,Then press Valume Up and Channel Up, while holding it plug the TV back in, you should see the TV Turn on. How to Reset Your Sharp LCD TV TV Repair
Jun 15, 2013 | Televison & Video
My sony bravia klv40ex600 won't turn on,the light indicator for power,volume and channel is on, the screen is still black
Hi, have you tried pressing the TV button that is under the On/Off button on top right hand side of remote control? Some times its possible to accidently press the DVD or VCR controls and this by-passes the TV as a remote?
Another cause can be a poor or low battery in the remote itself. If you have no luck let me know & we can try some more things, however, I have heard that The On/Off Switch on the TV can be a problem. Goodluck, Jon..
Jul 22, 2012 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Is there any way to get my tv channel back on 4 with no remote?
Try after amke a factory reset to your tV. Normally, aits remote control is needed to make it channel-4.
Apr 29, 2012 | Televison & Video
Tv won't switch to "tv"
Your T.V. is programmed to store the last input you've selected. You have to manually switch it back to your T.V. channel input after each time you switch it to HDMI or any other input even when you turn it off. The "Source" or "Input" button on your original T.V. remote will change this.
Jun 24, 2011 | Vizio 42 in. LCD TV
Ihave spn 4235 plsama tv problem is keep scan channel and rase the valume by self also icanot use the remote control to use the tv for on and off just plug and unplug the wire power need help plz
First take the Batteries out of your remote control to see if the T.V. is still changing channels or not. If it stops changing the channels and volume, try opening the remote with a knife and clean all the pads with rubbing alcohol to prevent sticking buttons. Be careful if using a remote with a roller ball.
Jun 06, 2011 | Samsung SPN4235 42 in. Plasma HDTV
Whent turn up the valume sound whit no power
I would contact Adcom for a service place near you
Feb 17, 2010 | Adcom GFA-5400 2-Channel Amplifier
Remote stuck--can't change channel or turn off TV
Pull out the power plug of your TV and don't use it for few minutes. Remove batteries from your remote and keep it without batteries for few minutes. After about 15 minutes your TV and remove both will work fine.
Jun 15, 2009 | Logitech Webcam
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
