Question about Utilitech Plumbing
Parts 58117-ul1 part number 22374
Tip
How to jailbreak using redsn0w on a PC (Windows) or a Mac
Updated January 15, 2012
This a general guide on jailbreaking any iDevice with iOS version up to 4.3.3 using redsn0w.
This guides focuses on redsn0w versions prior to 0.9.9b1 which has am all new UI and a bit different steps.
Redsn0w can jailbreak all existing iOS version (including the latest iOS 5.0.1) for any iDevice. CLICK HERE for more information and to see the list of all versions with their supported iDevices & iOS version.
A guide on how to use the newer versions of redsn0w will be posted here.
Supports the following devices with iOS 4.3.3, 4.3.2, 4.3.1, 4.2.1 and 4.1:
  • iPhone 4
  • iPhone 3GS
  • iPod touch 4G
  • iPod touch 3G
  • iPad
Download links for redsn0w 0.9.6rc19:
CLICK HERE for earlier versions of redsn0w for jailbreaking older iOS versions.
Below are IPSW files you'll use. If an Ad appears, just click SKIP THIS AD on the top left corner to continue on downloading:
For iDevices with iOS 4.3.3 installed:
For complete list of IPSW files, CLICK HERE.
WARNING!: This guide is for JAILBREAKING ONLY. Refer to UNLOCK GUIDE for more information on unlocking that includes a list of all the currently supported basebands.
DO NOT UPDATE if you need the unlock, otherwise you might lose it for good.
For best results, update iTunes to 10.1.
Procedure:
  1. Plug your iDevice to your computer
  2. Turn OFF your iDevice[space]To turn OFF, press and hold the POWER button for about 3 to 5 seconds then slide the red bar saying: slide to power off[space]
  3. Open/Run redsn0w and click Browse[space]NOTE: The screenshots you'll see here are taken from an earlier version of redsn0w using a Mac, however, as noted above, the process is completely the same if you'll be working on a PC (Windows), or a newer version of redsn0w.[mac1]
  4. Locate the official IPSW and click Open.
  5. redsn0w will process and identify the IPSW[mac3][mac4][space]
  6. Click Next and wait until it completes processing[mac5][mac6]
  7. Select your preferences and click Next[mac7]
  8. Turn OFF your iDevice (just a reminder from step 2).[space] Before you click Next, read steps 9 to 11 first in preparation for putting your iDevice to DFU mode[space][mac8]
  9. Press and hold the POWER button for three (3) seconds[ma9]
  10. Continue holding down the POWER button then press and hold the HOME button as well. Hold them both for another ten (10) seconds[space][mac10]
  11. Release the POWER button but keep holding the HOME button. You can release the HOME button once you see redsn0w in the process of jailbreaking your iDevice[mac11][mac12]
  12. Click Finish and you're done on the computer, and as it says, the rest takes place on your iDevice.[space][mac 15][space]
All you need to do now is wait and keep it plugged in your computer. DO NOT INTERRUPT![space]
Watch the complete process here:[space]
After the process, swipe through your homescreen pages to find Cydia. Usually, you'll find it on the 2nd page.
There are times that Cydia's icon would be blank. It will still work though, the important thing is it's already installed.[space]
If you have an iPhone and you want to UNLOCK, CLICK HERE.
Credits:
iPhone Dev Team
kidantvideos
Read more tips from kid_ant
on Sep 21, 2010 | Apple iPhone 3G
Motor would not start intermittently. Disassembled to determine possible problem.
The oil has to be there. Intermittent starting is usually the float switch hitting something in the sump. If the pump motor has a capacitor on it, replace the capacitor.
Aug 20, 2015 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
Why wont the pump turn on
If the pump is plugged in through a float switch the switch may be bad- try plugging the pump in by just the plug for the pump itself if possible -if that works then you need a new float switch.
Jun 10, 2014 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
Pump won't shut-ff
Hi Ron...
Check your float switch....sometimes they can get stuck to cause this problem of not shutting down after draining the orginal water.
Take the float switch and move it up and down...this may help to clear the stuck switch inside of the float
Bud
Apr 24, 2013 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
Pump not working
If power is going to pump and float switch is good, motor has fried, time to get a new one.
Oct 07, 2012 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
Could you tell me where I could get a user manual for a Gateway laptop, Model# W323-Ul1? Louise
The Gateway W323-Ui1 is also known as the Gateway MX3210,
http://support.gateway.com/support/manlib/Notebooks/MXModels/MXModels.shtml
(No, you did it right. The above page on Gateway is 'Flintstone's' looking)
On the above page scroll down to the heading - User Guides.
Now down to where it states - Notebooks - Gateway - MX3200 series
Click on the file name under this heading -
8511189 - Gateway Notebook Hardware Reference R0 Windows XP
This is a PDF file download. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above link it may take up to 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
(Took 12 seconds just now. File fully downloaded in that time, with no extra download time needed.
Using medium speed DSL connection)
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 18, 2011 | Gateway Computers & Internet
How to unlock my sony ericsson u1l or ul1 cell phone
There are many ways to Unlock the Sony Ericsson from Network Lock,But Unlock code is easy Method to unlock it from Network Lock,You can get the Unlock code from Online site and Unlock from Network Lock..Then Sony Ericsson U1i or satio (idou)
is same Only,Then Sony Ericsson Ui1 or sony ericsson satio,You can please Conform your model,then You can get the Unlock code for that Mobiles from here
Simpleunlocking.com and Unlock it from Network ..Enter the code using the Free instructions there..
Aug 09, 2011 | Ericsson Cell Phones
Hi, gateway w323-ul1 laptop cooling fan is not working.
Try blowing out junk in the fan by shooting air in the out vent. You can also try making up a very small hook with a paper clip and trying to see if you can pull out any junk.
If the Laptop is still under warranty call tech support. If not, you should still check the FAQ and knowledge base at the Gateway website.
Laptop fans don't run continuously. They normally run during boot and when the laptop gets too hot.
Oct 10, 2009 | Gateway Computers & Internet
Plumbing Logo
24 people viewed this question
Top Utilitech Plumbing Experts
Dave
J.D. Browning
J.D. Browning
Boyet Soriano
Boyet Soriano
Are you an Utilitech Plumbing Expert? Answer questions, earn points and help others
