Question about Sage Timeslips 2008 Full Version for PC (TSW2008RT)
TURN ON INSERT
WHEN ENTERING DATA ON TIMESLIP ALL OF A SUDDEN I AM OVERWRITING INSTEAD OF INSERTING TEXT WHEN MAKING CORRECTIONS
How do I load the IPL to a CASIO TE-2400?
that is the correct way . Maybe you need to activate sdcard option on the new machine it could be off
Apr 30, 2014 | Retail Supplies
When i type a sentence and make a mistake and want to add a new word into my sentence the space bar and any keys i touch type over my existing print. how do i correct this.
You need to toggle your overwrite/insert setting.
All you have to do is hit the "Insert" button on your keyboard. Hitting it once will set your type settings so that new text will be inserted instead of overwriting existing text. Hitting it again will toggle it back.
Mar 28, 2011 | Logitech 967437-0403 Keyboard
How do i insert symbols while texting ... I can text but cannt insert ?,=? + £
Here's how:
Enter text
When entering text, you can change the text input
mode:
• Press and hold [ ] to switch between T9 and
ABC modes.
• Press [ ] to change case or switch to Number
mode.
• Press and hold [ ] to switch to Symbol mode.
Enter text in one of the following modes:
Mode Function
ABC
Press the appropriate alphanumeric key until
the character you want appears on the
display.
T9
1. Press the appropriate alphanumeric
keys to enter an entire word.
2. When the word displays correctly, press
[ ] to insert a space. If the correct word
does not display, select an alternate
word from the list that appears.
Number Press the appropriate alphanumeric key to
enter a number.
Symbol Press the appropriate alphanumeric key to
select a symbol.
Here is a link for a free online user's manual for your convenience:
http://downloadcenter.samsung.com/content/UM/200904/20090420115654593/CMS_-_Samsung_B2100_UM_EU_Eng_FINAL_Rev.1.1_090326.pdf
Please leave us 4 thumbs up :)
Nov 29, 2009 | Samsung Solid B2100 Cell Phone
OVERLAPPING INSTEAD OF INSERTING.
Even in Microsoft Word, you can choose if you want to insert or overwrite. You do it by pressing the INS key on the keyboad. As you do not reveal the identity of your calculator I can only provide a general solution.
If the keypad has a marking Ins about a key , you use it to insert either directly by pressing the key or as a Second/Shift function. Once toggled the Insert/Overwrite mode should persist until you toggle it to the other mode.
It is also possible that your CAS can be configured for the Insert/Overwite setting.
Hope it helps.
Nov 08, 2009 | Texas Instruments Office Equipment &...
I hit some key and now when I try to insert letters between words instead of inserting it gobbles up the letters ahead of it.
You did not say which program you were using, but in most cases the "Insert" key on your keyboard toggles between the Insert and Overwrite functions of the software. Pressing the Insert key again shoudl fix your problem.
Aug 05, 2009 | Computers & Internet
For some reason when I input data to create slip
Go to the Sort Tab and make sure you are sorting in date order. It should be the top selection on the sort tab
May 03, 2009 | Timeslips 11 (TSW11RT) for PC
Letters print out cancelling other words
there is a feature on your computer to switch between "insert" which inserts words at the point of your cursor, without being destructive to other text, and "overwrite" mode, which replaces current words/text with what you type. in Microsoft Word or other word processing programs, you can see a small symbol representing either "INS or OVR" in the bottom status bar. to switch between these modes, press the "Insert" key on your keyboard (also labeled "Ins" on some keyboards), this toggles the insert/overwrite mode back and forth.
Feb 19, 2009 | Microsoft Windows XP Professional for PC
Edit Text on a picture after Adding it
no, text in an image is not saved as text, it is encoded to each pixel that it overwrites.
do not add text in camera, save the images to a hard disk and use a simple image editor, like irfanview http://www.irfanview.com, to do the text overlays, it has undo, you can use irfanview to pixel edit the text set image
May 16, 2008 | Olympus FE-230 Digital Camera
Budgets in excel
Dear Madiha35,
I would recommend the use of the Table Function in Excel.
Here are the steps in Excel 2007, if this does not work for your version please add comment for me to reply to.
Conversely, If you would like the softcopy of the screenshots, I would be happy to email them to you.
Excel 2007 had a budget format workbook
New workbook, Select Budgets in the last hand navigation, Select Personal Budget.
Step 1:  Enter your data into the worksheet.
Step 2:  Create Table
             Highlight the relevant data
             On the insert tab, click on Table
Step 3:  Verify Table range is correct, Click OK
Step 4:  Select the cell you where you wish to Sum Data.
         Click on Autosum.
Step 5:  To Insert new data
         Click on the sum row in the table, (Not the entire worksheet row)
         Right click, Insert, Insert Table rows from above
Step 6:  Enter new data in row
Step 7:  Data is automatically calculated in formula.
Oct 22, 2007 | Computers & Internet
Sage Timeslips 2008 Full Version for PC (TSW2008RT) Logo
Top Sage Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Clinton Daley
Clinton Daley
Are you a Sage Computer and Internet Expert? Answer questions, earn points and help others
