Question about Fitness Quest Integrity 3000 Air Rower
Broken cord the bungie cord broke need to order new one
    New Friend:
Where can i get a replacement cord belt for the air rower, its frayed and snapped?
Posted on May 24, 2014
TRANSFER CASE REBUILT SAME PROBLEM 2H GOES INTO NUTRAL WHEN ACCELERATION
is the shifter bent or is the spring on the side of the shifter broken on the out side
Oct 12, 2015 | Cars & Trucks
Sliding door on my 1996 ford aerostar van has completely come off track and all attachments from top to bottom are broke. the bottom piece is the only thing still attached all brackets are bent and door...
Check around the car wreckers that specialise in ford and ford vans for a complete assy. Some wreckers, if they want business, may even fit the door for you at a reasonable price.
Aug 24, 2013 | Cars & Trucks
Need resistance bands for ab lounger
I noticed these are now being sold as a used item on eBay. I do not know where to get new ones. I modified my ab lounge to use bungie cords. These are much cheaper.
Apr 05, 2012 | Fitness Quest Ab Lounge Ultra 1ea
I cut the cord in order to make the length shorter. i twisted them together and used electrical tape to insulate the attach point. i tried this several times, and im not even getting a broken signal.
No amount of comforting words is going to help you fix what you broke.
You might have some luck calling Sony to see if you could order a new cord.
https://servicesales.sel.sony.com/ecom/accessories/web/index.jsp
Shop By Phone: Priority Service: 1-239-768-7691 Toll Free Service: 1-800-488-SONY (7669) Phone Hours:
Monday to Friday - 8:00 am to 12 am (Midnight) ET
Saturday and Sunday - 9:00 am to 8:00 pm ET
Jan 12, 2011 | Sony MDR-V500 Professional Headphones
How do i get my hood 2 closed if the latch is broken
You could tempoarly hold it closed with a bungie cord hooked to the hood in the front and allached to a secure place ubder the truck, then get a replacement latch to do the repair
Oct 05, 2010 | 2001 Dodge Ram 1500 Truck 2WD
How do you repair the vynil arm at the socket on a My Size Barbie? The arm is loose and hangs down and is not flush as the other one is.
is it attached by a "bungie" type cord? if it is, you will need to cut the overstretched cord out and replace it with the same sized( in inches or length) cord of similar thickness.Use a coat hanger with one end bent into a small hook to pass through the body and grab the new replaced bungie cord and pull it through to the fastener on the loose arm.
Jun 16, 2010 | Toys
HOW TO REPLACE CORD BROKE INSIDE UNIT CAT TAKE IT
you know the cord is broke? and you wish to remove and replace the broken one? well it has to be opened to remove or reconnect the broken wiring. is there screws attaching the removable parts in order to get to the broken cord? recommend you locate broken wires and reconnect each wire to its color either white and black. and use electrical tape to cover each wire reconnected.
Mar 12, 2010 | Hoover Elite U5061-900 Bagged Upright...
What is the stretchy cord holding your tent poles together called, and where can you purchase some?
Slang term is bungie cords, but its just better and cheaper to buy new poles than deal with a pain in the @#$!
Feb 06, 2010 | Coleman 10' X 10' Sundome Tent 9160K101
Are two bungy cords enough to secure one piece of luggage on top of a 2004 pathfinder thats criss crosses the bungy cords of course and also bringing in the luggage as tight as possble with the crossbars...
Hi SSheftall,
If you can get them tight enough that the luggage won't move easily, I'd have to say yes.
In the end it's your responsibility and your call. If you, the vehicle operator have any doubt, by all means, secure it further. Be safe.
Mike
Aug 02, 2009 | 2004 Nissan Pathfinder
The blender coupling on my oster snapped in half. I have the replacement part already I just cannot figure out how to get the broken coupling off the base of the motor. I also got a replacement square...
10-01-2009 Sara - see solution for rlaymon 1-9-08 "Top part of base broke off" by TanyaCS on 1-20-08 - good ideas. I just fixed mine - 2 hour job + half hour to put a new cord in. Like TanyaCS my broken coupling was rusted to shaft - used WD-40 twice and let sit - meanwhile took out motor and removed fan - kept screws and washers in order on workbench (kitchen counter) - the fan hole is "D" shaped - fan end of shaft also "D" shaped - I filed a "flat" on the other side of the factory "flat" (side of 'D' that is straight) - Used big pliers on broken coupling and adjustable wrench on on the "flats" on fan end of the shaft. Broken end came right off. New cord is 18 gauge extension cord capable of at least 6 amps. Cut off the un-needed end. Or order a replacement cord $4 when you order the rubber drive coupling $4, pin with slinger washer $3. Bet you also need new rubber feet - didn't buy for mine - wish I had. Bert
Jul 11, 2008 | Oster 465 Work Top Blender
Fitness Quest Integrity 3000 Air Rower Logo
758 people viewed this question
Top Fitness Quest Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you a Fitness Quest Exercise and Fitnes Expert? Answer questions, earn points and help others
