Question about NKOK Singer Chainstitch Battery operated Sewing Machine
Toy sewing machine wont work
Cannot get needle to catch underside of stitch. Tangles thread around needle. Won't stitch at all.
Bobbin thread wont form a stitch
Hai, Please check the bobbin tension and winding. And cleaning the machine.
Mar 20, 2014 | Brother InnovIs 4000D Computerized Sewing...
Husqvarna Viking - Thread gets caught up on the underside of material when trying to sew.
There are two things that come to mind that may be causing the problem.
1) Change the needle, for it could be bent even thought it may not look it. (This is the most likely cause).
2) Have a look just inside and check if any screws have come loose. This has happened to me. (Even the repair man did not find it.
Nov 29, 2013 | Sewing Machines
Thread wont loop, it doesn't sew?
It loops, it's just that your shuttle isn't catching the loop. The loop is formed on the upstroke of the needle on the back or "scarfed" side of the needle. If the shuttle point doesn't catch that loop, no stitch.
First make sure you have a fresh needle. If still no stitch... take it in for service. (clean, lube and time)
Oct 03, 2012 | Brother SE-270D Computerized Sewing...
I have a brother ls-2125 sewing machine. the upper thread is not catching the bobbin thread properly. help please
  1. Tension
    • Your sewing machine tension controls the rate at which the thread is fed through either the upper section of your machine or through the bobbin case. If your upper or bobbin threads aren't threading properly, sometimes adjusting the tension will correct this problem.
    Timing
    • Your sewing machine works by passing the upper thread through the needle of the sewing machine at precisely the same time the bobbin brings its thread to its uppermost position. If either the needle or the bobbin thread reach these positions too soon or too late, the threads won't interact and create the knots that make the seam. You can throw off your timing by sewing too many layers of fabric or hitting a pin with your needle. See you sewing machine repair facility to correct any timing issues.
    Thread
    • Thread can get snagged or caught in the upper section of your machine or on lint pieces in the lower bobbin section. If your threads aren't catching properly, you may be able to fix it by unthreading and rethreading both your upper thread and bobbin threads.
Oct 15, 2011 | Brother LS-2125 Mechanical Sewing Machine
HAVE A BROTHER XL5340 SEWING MACHINE WHEN THE TOP NEEDLE AND THREAD GOES IN TO LOWER BOBING IT WONT CATCH THE BOBING THREAD AND LOOP CORRECTLY ITS NOT CATCHING AND LOOPING AROUND THE BOBING
firstly check that the needle is in the right way, flat shank to the back. This is easy to get wrong and will prevent the rotary hook from catching the upper thread when the needle is at the lowest point in the stitch sequence.
Also check threading up of the top thread, particularly that the thread is through the take up lever.
There is good trouble shooting tips at http://www.sewusa.com/Sewing_Machine_Repair/Sewing%20Machine%20Troubleshooting.htm too.
However, if you are certain threading up is correct, and needle is correct then the timing between needle and rotary hook may be out. There is diagrams at this website too for this problem
http://www.sewusa.com/Sewing_Machine_Repair/Sewing%20Machine%20Hook%20Timing.htm however, I've always left timing repair to my sewing machine technician to deal with.
Jul 26, 2011 | Brother XL-5340 Mechanical Sewing Machine
Brother pe 150 needle wont pick up thread from bobbin changed needle
Check that the needle is in the right way, flat shank to the back. If it is around backwards, the shuttle hook won't be catching the thread at the back of the needle to form the stitch.
Jun 22, 2011 | White Sewing White 3032
When i start to sew on my Janome sewing machine model Sewist 525S it does a couple of stitches on any stitch type then bangs then sews then bangs then stops. I look to see the problem and the bobbin and...
There has to be a problem in your threading or your needle. You may have the needle inserted backwards, flat side has to face rear or the needle is bent. Totally unthread your machine and make sure that there are no tangles and that it feeding the right way. Watch how they show your for threading and winding the bobbin, plus threading the bobbin. Good luck, but I truly think it is in your threading.
Sep 25, 2010 | Brother LS-1217 Mechanical Sewing Machine
The thread is bunching on the underside of the fabric and does not seem to be actually creating a stitch. The machine will proceed as if it is stitching for about an inch or two and then jamb and the...
Totally unthread your machine, then rethread after you have inspected your needle and replaced if necessary. Your top threading is not right, so pay attention to how you are doing that, no tangles. Before you rethread, take out your bobbin and clean the area with a brush that is probably in you sewing accessory box.. Study your manual and if you do not have it, go to www.sewingmanualsonline.com and download one for $10. Good luck
Sep 20, 2010 | PfaFF Creative 7570
Bobbin thread does not loop up when threading machine. Then the needle thread get wraped around the inside the bobbin sewing the material to the machine
There are so many thing you need to re-check.
First clean out the bobbin area to be sure there aren't any thread tangles still there.
Open the manual and start from the beginning with threading the machine with the presser foot lever UP - always.
Read the instructions and do not rely solely on the pictures as we all sometimes rush to do (I am just as guilty as the next person to do this).
Make sure the bobbin thread is feeding from the bobbin case in the correct direction.
Hold onto the end of the top thread (after needle has been threaded) and lower then raise the needle to catch and bring up the bobbin thread.
Place the fabric under the presser foot and as you hold onto the ends of the top and bobbin thread, hand walk the first stitch, then use the power pedal.
If you need a manual, you can download (free) from Singer - http://www.singerco.com/accessories/manuals.html
Mar 25, 2010 | Singer 8280 Mechanical Sewing Machine
NKOK Singer Chainstitch Battery operated Sewing Machine Logo
29 people viewed this question
Top NKOK Toys Experts
ray gallant
Are you a NKOK Toy Expert? Answer questions, earn points and help others
