Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
Light will not shut off
Door opens and closes but light stays on
    Scholar:
  • 86 Answers
If the wall transmitter has a button that says "LIGHT" be sure it is pressed and the light should go off. If you press that button and the light goes on, it will not shut off unless you press it again. If that's not the problem, you may have a failed light relay in the opener. One other thought, are you using 75 watt bulbs in the opener? I see where some people are trying LED bulbs to save money and they will not shut off when they are supposed to due to low current draw.
Posted on May 12, 2014
The open door light stays on wen all doors r closed
Thats because your door is out of line and when closing it,its probably not closing on the switch that should be on the inside of the pillar post were the door actually shuts on..Get the door fixed or lined up properly so it closes flush and will certainly then close on the switch that triggers the open door light :-)
Feb 06, 2013 | 2001 Nissan Frontier Crew Cab
Samsung model smh7178std, shut the door and the fan and lights come on automatically, if i lift up on the door the fan shuts off but light stays on.
some switches are normally closed "short position" press switch "open" it will be labeled NC on the one side, "stands for normally closed" and others will be NO "stands for normally open" press switch "short" if there is no change in readings when you press switch it is defective.
Mar 28, 2012 | Samsung SMH7178STD Microwave Oven
Interior lights stay on when the switch is off and car is parked
is the door ajar light on sometimes also when driving? I had a similar problem with the light staying on. I determined that it was the passenger front door latch sticking. I opened the door, then took a screwdriver to push the latch shut on the door jamb. (Make the truck think the door is shut even though it is open). Then lubricate that jamb and pull the handle open to open the door. Keep doing this (closing with screwdriver and opening with handle) until the latch works freely. This took care of my light and door ajar problem.
Aug 12, 2009 | 1999 Ford Expedition
Door lights sensory stay on in the dash board.
When you shut the door, there are these things that connect to the door frame, and the door to shut off the light when you Shut the door. try to put aluminum foil on it, check for corrosion, or rust.
Jul 11, 2009 | 1998 Ford Taurus
Rear door won't stay shut
Check the latch mechanism on the door. There is a piece of the latch that closes around the clasp on the door frame. sometimes this closes when the door is open and you can't shut the door. Take a screw driver and flip this latch piece open and close the door.
May 29, 2009 | 2008 Chevrolet Hhr
I have a side by side Viking refrigerator and after leaving the door open a little too long the lights went out in both the refrigerator and freezer. I figured that they would go back on automaticlly after...
Remove the center grill of the top grill and shut the power off and back on, the lights should reset
When the lights are working open the Ref door then close the freezer drawer, watching to see if the light in the freezer shuts off. It should shut off when the freezer is about 1" from closing. If it stays on until the door is fully closed then there is a problem with the light switch in the freezer.
Normally when you leave the doors open until the lights shut off, it should reset when both doors are closed
Mar 06, 2009 | Viking DDBB363 Bottom Freezer Refrigerator
Interior dome light/exterior cab light stays on -won't shut off
Lube your door latches. One of the door ajar switches are sticking . Use wd40 or some othe spray lube . Spray into the latch and open and close doors several time.
Jan 25, 2009 | 2000 Ford F250 Super Duty Crew Cabs
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
Top liftmaster Electrical Supplies Experts
Vince Heuser
tamska1102
Level 1 Expert
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
