Question about Vision Mares Pure Mask
How to tighten straps on snorkelling mask
Brand new mask, with straps that are too loose for me to wear.
2 Suggested Answers
  • 217 Answers
SOURCE: how to loosen straps on snorkeling mask
http://www.youtube.com/watch?v=ZaktqZSPmts
Here is a quick 2-minute video that will explain how to loosen the straps on your snorkeling mask, and tell you many other useful facts about snorkel masks. If your mask is a different model, you can look at the related videos on YouTube and find one that has straps similar to yours.
Posted on Dec 18, 2012
How to loosen straps on snorkeling mask
Jul 05, 2012 | Vision Mares Pure Mask
Where the strap connects to the mask broke on my snorkel mask. Can this be replaced. I only wore the mask one time.
Yes. You should be able to find a replacement strap online or at your local sporting goods store, for quite cheap.
Apr 05, 2011 | OMNI Deep See Omni Silicone Mask
I have snorkeled two times in Porta Morales, Mexico (South of Cancun) and used the tour's equipment. I have been unable to keep water out of the mask regardless of how tight I make the straps. Repeated...
With any mask it is important that it is the correct size for your face. To check the size place the mask to your face without using the strap. Breath in through your nose to create a vacuum, the mask should stay stuck to your face. If air leaks in then the mask may well not be suitable for you. Of course the mask skirt (the bit that touches your face) must be clean and free from damage or tears. Also your face must be clean ie no sun tan lotion. Just a tip never have the straps tight on your mask..
Hope that helps :)
Oct 18, 2010 | U.S. Divers Avalon Purge Mask
Part that holds strap to the mask is broken.
It depends on the brand and model of Mask. Divers Direct sell some replacement buckles for Tusa masks. Tusa Liberator buckles and Tusa M10 buckles as well as a few for other models. Scubastore.com lists Mares Mask Buckles.
Probably the easiest is to go online to any of the major search engines and search for the brand name of your mask plus the words "mask buckles" and you should find a supplier (if there is one).
If not, you can try this fix. Not sure if it will work - kinda depends on what part of the mask buckle is broken. Good luck.
Jun 24, 2010 | U.S. Divers Cozumel Mask
The clasp to connect mask to snorkle broke. can I purchase the small clasp?
In short, no. But just do as many other do and use a short rubber band. Lay the middle of the band across the inside of the strap, and then pass the snorkel tube through the two resulting loops either side of the strap.
May 21, 2010 | Speedo Condor Mask Snorkel Set
Replacement Quick Disconnect Strap Buckles
You won't find any spare parts as Sherwood don't supply them.
Your mask had a limited 12 month warranty from new, so if it's under warranty still then Sherwood will likely either replace the entire mask or take the parts you need off a spares donor for you.
Click here to contact them.
If you can't claim under warranty they may still decide to help you on a goodwill basis, but in future if you want reliable spares and aftersales support buy established market leading brands such as Mares, ScubaPro, Cressi etc.
Mar 29, 2010 | Sherwood Oracle Mask
I have an Akona Wahoo scuba mask and the strap has broken. Can I get a replacement?
Most any scuba shop will have replacement mask straps.
They are very common replacement.
Dec 01, 2009 | Akona Wahoo Junior Mask
Replacement part for snorkel attachment
its a plastic clip if i am correct. i have in the past used a rubber band, but you could go to a local dive shop, they normally have the rubber replacements for snorkels.
Nov 26, 2009 | Aqua Leisure Dolfino Tri-view Dive Mask...
Avalon Mask strap assembly broke
Try to spread apart the clip using two sets of small nosed pliars on each side of the clip, therefore not applying any pressure to the mask. Best wishes with a wonderful sport!
Dec 27, 2008 | U.S. Divers Avalon Purge Mask
How to choose a scuba mask
"The shape of the scuba mask and the silicone skirt on the mask must conform to the shape of your face to provide you with a comfortable fit. Ensuring the silicone skirt is a high-grade, flexible silicone can help to ensure the scuba mask conforms to the shape of your face and the long life of your scuba mask. Some people are allergic to different types of rubber, if you have an allergy to rubber, be sure to choose a silicone scuba mask because silicone is hypoallergenic. Always talk to your scuba diving gear retailer about the alternatives available to you. When trying on scuba masks you will notice the different shapes of the nose pockets. The nose pocket protects and cushions your nose, helps to keep your scuba mask from fogging during a dive and helps you to maintain equalization. Ensure the size and shape of your nose pocket is comfortable; not too tight and not too large. This will improve not only the comfort of your scuba mask, but your ability to purge your mask efficiently. There are increasingly different styles of scuba mask straps on the market. You may like the factory issue strap on your scuba mask or you may want to purchase a separate strap. Scuba mask straps are available in a single strap or a double strap design. The single strap should wrap around the centre of the back of your head. The benefit of the double strap is that you can position the top strap on the upper part of your head and the bottom strap on the lower part of your head to offer extra stability and comfort. Most scuba mask straps are rubber or silicone and fasten with a post-hole belt enclosure. Newer scuba masks offer a slide-lock type enclosure, which allows you to adjust the scuba mask quickly and easily when wearing the mask. Scuba masks are constantly improving. If you wear prescription glasses or contact lenses on a daily basis you can purchase a scuba mask without having to wear your glasses or contact lenses under your mask. Many manufacturers will create custom scuba masks which include your prescription in the front lens. A good sign you have chosen the right scuba mask for your face is when the mask stays on your face comfortably without using the straps to hold it in place. You should try this simple test with each scuba mask you try on for the first time: See our choices for scuba masks 1. Place the scuba mask over your eyes and mouth ensuring the mask is in the correct position. 2. Take a quick, light breath in through your nose and immediately start to breathe through your mouth as if you are scuba diving. This will create a slight suction between the scuba mask and your face. The scuba mask should stay on your face. If you must push the scuba mask against your face, or inhale repeatedly to help the mask stay on your face, the mask is not a good fit. 3. Keep the scuba mask on your face for approximately one minute. This will help you to determine how tight the seal is and how comfortable the mask is on your face. 4. Exhale gently through your nose to release the seal on your scuba mask and remove the mask from your face. There should be no mark on your face from the scuba mask. If there is a red line around your face from the seal of the mask, the seal was too tight or the mask is not the proper size for your face. Try the test a second time. If you still have a red mark on your face after you remove the mask, you need to continue your search for a scuba mask. Remember, a good scuba mask is one that's comfortable, doesn't leak and is easy to use."
Dec 01, 2008 | Vision Mares Pure Mask
Vision Mares Pure  Mask Logo
313 people viewed this question
Top Vision Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a Vision Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
