Question about Cuisinart Keurig B50 Single Cup Coffee Maker + 12 K Cups
NEED TO CLEAN KEURIG
HOW DO WE CLEAN THIS MACHINE
How do I descale my Keurig 20 coffee machine
Start the brew cycle without inserting a K-cup. Repeat until reservoir is empty, discarding the mug contents after each brewing cycle. This process will help remove lime and scale buildup. Keurig recommends descaling your brewer at least every 3-6 months depending on your water source.26 Apr 2015
How to Clean a Keurig Coffee Machine - Cleaning Lessons from The ...
www.thekitchn.com/how-to-clean-a-keurig-cooking-lessons-from-the-kitchn-218103 https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=How+do+I+descale+my+Keurig+20+coffee+machine
Dec 22, 2016 | Keurig Coffee Makers & Espresso Machines
My Keurig only brews a part cup
Most likely you need to change the filter and descale it as well.
I use a CleanCup once a month:
https://www.amazon.com/CleanCup-Single-Machine-Cleaning-Capsules/dp/B00E0QAS34/ref=sr_1_1?ie=UTF8&qid=1480095410&sr=8-1&keywords=keurig+cleaner+cup
I change the filter once every 3 months:
http://www.keurig.com/Accessories/6-Pack-Keurig%C2%AE-Water-Filter-Cartridge-Refills/p/Water-Filter-Cartridges
And I descale it every time I change the filter using this:
http://www.keurig.com/Accessories/Keurig%C2%AE-Descaling-Solution/p/Keurig-Descaling-Solution
Otherwise, the tubing is going to get clogged up in your machine and produce smaller and smaller cups of coffee, not to mention, when you keep your machine clean, your coffee will always taste its best!
Hope this helps!
Nov 25, 2016 | Keurig Coffee Makers & Espresso Machines
My gaughter put milk in my keurig machine
Not good, all tubes are clogged and need cleaning. Call Factory for instructions.
Nov 02, 2012 | Keurig B60 Coffee Maker
How do i clean my keurig b70 coffee machine
Check out this tip about how to descale your Keurig coffee brewer
How to Descale your Keurig Coffee Brewer
heatman101
Oct 24, 2010 | Keurig Platinum B70 Coffee Maker
My keurig machine is brewing only a little water and sometimes not working at all. slow brewing time. just started. no problems yesterday
mcdevito75 here, You may need to clean the machine. water used to make coffee leaves deposits in the brewing holes and has to be cleaned out. Refer to the owners manual on cleaning.
Jun 13, 2010 | Keurig B50 Coffee Maker
MY KEURIG IS BLOCKED AND THE WATER WILL NOT COME OUT
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage.
Apr 04, 2009 | Keurig Elite B40 Coffee Maker
Cuisinart Keurig B50 Single Cup Coffee Maker + 12 K Cups Logo
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
