Question about KitchenAid KEBC101 Electric Single Oven
Kitchen aid induction cooktop
Fault code f60
Where to purchase
http://www.consumerreports.org/cro/kitchen-ranges.htm
Freestanding electric smoothtop ranges are the big sellers, but you have more choices than ever. Our Ratings include smoothtop ranges, of course, but you'll also find induction and coil-top ranges in the electric category, along with gas, dual-fuel (gas cooktop, electric oven) and pro-style ranges. Choose a single oven or double-oven range, freestanding or slide-in. We test all of these. Consumer Reports offers you buying advice that you can trust. We provide unbiased Ratings and range reviews to help you choose the best range for your needs and budget, and use our buying guide to learn more about range types and features that matter most.
Ratings & recommended kitchen ranges
Electric smoothtop ranges (62)
Our Recommended ranges can do it all and, based on our survey of thousands of readers, do not have brand reliability issues. The Recommended ranges will bring pasta water to a fast boil, hold a big batch of spaghetti sauce or chili at a low simmer, a... More
Recommended electric smoothtop ranges
Electric smoothtop range Ratings
Electric induction ranges (9)
Recommended electric induction ranges
Electric induction range Ratings
Electric coil ranges (10)
Recommended electric coil ranges
Electric coil range Ratings
Gas ranges (43)
Do you love cooking with gas? Our Recommended gas and dual-fuel ranges (which pair a gas cooktop and electric oven) are top scoring and, based on our survey of thousands of readers, do not have brand reliability issues. They have large cooktop burner... More
Recommended gas ranges
Gas range Ratings
Pro-style ranges (34)
Pro-style ranges are stylish, stunning, and make a statement. But despite their high price, they aren't the best ranges we've tested. So before you swipe your credit card check our Ratings. You'll see the top brands, including Viking, Wolf, Thermador... More
Recommended pro-style ranges
Pro-style range Ratings
Jul 19, 2015 | Ovens
Tip
Kitchen Aid Oven / Stove Fault Codes
If your Kitchen Aid Oven is showing fault codes starting with F, the problems and solutions can be found at the following website.
CLICK HERE
on Feb 26, 2011 | Ovens
Induction cooktop won't turn on
Could be the safety switch of, because the logic detects an error (or defect) in the induction system.
Mar 31, 2015 | Belling Ovens
SAMSUNG INDUCTION STOVE ERROR CODE E84
Unplug the oven wait 10 minutes plug back in . Cooktop AND Oven working ? Yes - you have a communication problem - display board or main PCB.
Is the oven not working and the cooktop still works ? If yes it is a power problem on L1 or L2 , to verify if the issue is in the oven or the home swap L1 and L2 on the power cord. (if you do not know what you are doing then you should not touch them). If the Error remains yet the cooktop stops working or the cooktop stops and the oven starts working etc. Replace the Circuit breaker in your house panel - it works but not correctly. No Difference check the L1 line and the transformer connector on the oven board - resolder the connectors for the transformer.
Dec 23, 2012 | Samsung Induction Range FTQ307
De dietrich induction hob fault code d5 6f 20 a3
I have a De Dietrich DTI749X induction cooktop and i have the FO error code flashing on two of the hobs.
How do I fix this?
Sep 01, 2011 | De Dietrich Ovens
Kitchen Aid f3e2
F3 - E2 Oven temperature is too high (Cook mode)
Replace Oven temperature sensor (RTD)
Note:
This error code applies to all F3-E... faults.
Good luck.
Jul 21, 2011 | Ovens
My daughter-in-law just moved in to a newer home with a stainless steel Kitchen Aid ceramic top stove. It has a warming oven, a convect feature etc. However, with options etc. it is very confusing to...
Kitchen Aid manuals are available from their support site: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . The model number is needed to locate the manual. For ranges, the plaque with the model number is inside the oven door.
The KitchenAid ovens that I know will turn off when you press Off (unless the control lock is on - then you need to disable the control lock). The Warming Drawer will have a separate Off button. Dual oven units require you to select which oven and then press off.
See http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/KESS907XSP_Use%20and%20Care_EN.pdf for a similar range. (ceramic glass cooktop, convection feature and warming drawer)
I hope this helps.
Jul 02, 2011 | KitchenAid Ovens
Kitchenaid Oven
good day,
hope this link below will solve your problem.
kitchen
Jul 27, 2010 | KitchenAid KEBC101 Electric Single Oven
Error code F2 E3 r:02 E:03
Kitchen Aid Error Code F2-E3
Called kitchen aid, they said you need a new control board part #9782455.
Mar 16, 2010 | KitchenAid KEBC107 Electric Single Oven
KitchenAid KEBC101 Electric Single Oven Logo
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
