Question about Smith Optics Eyewear Accessories Pivlock Replacement Nose Piece Black
Broken R arm of Smith Optics V2 Imp Black glasses
I broke my impossibly black Smith Optics Rt arm. I've gone thru Smith Optics in the past (around a year ago) and it was a pain so I want to buy a replacement right arm only. Help?
Schematics on an optima 50 cal cva v2 black powder spring broke and trying to put back together
This site has a diagram. Also says the factory will help. The link is further down his post. It's from '09
CVA Optima Pro trigger diagram
Sep 22, 2017 | Optics
Water dispenser for gsh25JSTA BROKE can I fix
All of you guys are wrong. What that person is saying is that the physical paddle used when you place your glass in the dispenser bay and press against the paddle....That's what's broken the paddle......
Jan 05, 2013 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
My c-20 copier will not print from glass. prints blank pages. will only print the ones placed on the feeder.
I know this silly, but you put the originals on the opposite end of the glass. I don't mean to insult anyone, but I don't know your experience with this machine.
The fact that it copies thru the feeder, tells me the copier is ok. The doc feeder uses the same optics.
hope this helps
Feb 07, 2011 | Xerox CopyCentre C20 Black and White...
One side of the finished copy is black, I cleaned the glass, I tried feeding it thru a different way, must be the drum?
first clean the optics(lens, mirrors) clean the chargers, and check if the drum is ok then change the drum cleaning blade
Aug 26, 2010 | Konica Minolta Office Equipment & Supplies
Spa Pump Wiring
Black and Red are your two hots for high and low speed. The Green is always ground and the Blue would be neutral.
May 09, 2010 | AO Smith A O Smith Motors Century 1hp 115v...
Wiring a 220v single phase motor and capacitor
Black and white are usually power. an ohmmeter will confirm. Brown are for capacitors. There is almost always a diagram on the motor someplace. Eric
Jun 17, 2009 | AO Smith A O Smith Motors Century 1hp 115v...
No water going thru washer arms
remove the pump screen and, clean the pump
you probably have broken glass preventing the pump impeller from moving
May 29, 2009 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
Night owl / night vision
Unscrew front lens front of intensifier tube should have an even bronze tinted coating on glass if it is grey and blotchy the tube is degassed. common fault with this model nightvision
wayne
May 30, 2008 | Night Owl Optics Aero NOAR25 Monocular
My 8 yr old daughter thru the remote and broke the screen on my 32in LG lcd tv. All black now, looks like broken glass on left side. Can it be repaired for less than new?
your lcd panel is bad most of the time that is the most expensive part on the tv. cost on a 32inch lcd panel is 650.00 not including labor . this lg panel is not aviable now.sorry.
thanks doctor video leadng edge electronics since 1987
May 11, 2008 | Televison & Video
Smith Optics Eyewear Accessories Pivlock Replacement Nose Piece Black Logo
Top Smith Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Smith Cycling Expert? Answer questions, earn points and help others
