Question about Sony Ericsson Walkman W810i Cellular Phone
Unknown file in my mobile
I downloaded few contents from my PC to my Sony W810i.When i opened the folder,unknown file called "_desktop.ini" is replicated to all pictures,videos,sounds,web folders and wherever the new folder is created.This file cannot be deleted as it says "Cannot delete the protected file" and also removed when i try to run the antivirus for the phone and card memory.Please suggest me a solution as how to delete the _desktop.ini file.
  • 729 Answers
Re: Unknown file in my mobile
That's a virus from a virus-infected computer. I'm very sure of it. 100%. Your phone is also infected... Only McAffee Anti-virus ca n remove it for now.
Posted on Oct 31, 2007
0 characters
3 Points
Sony experia U Sony keeps flashing on screen and nothing else happens. This occured after I tried to update phone
To install the flash tool, follow the steps below:
  1. Download the Tools
  2. Unzip the file you downloaded and place it somewhere on your computer.
  3. In the unzipped folder, run Emma.exe. During the installation, make sure you remember the installation path:
    1. Default path in Windows 64 bit is: "C:\Program Files (x86)\Sony Mobile\Emma\"
    2. Default path in Windows 32 bit is: "C:\Program Files\Sony Mobile\Emma\"
  4. Copy the Customization.ini file. You find it in the <Emma zip filename>.
  5. Paste the Customization.ini file into the installation folder. The installation folder is the folder named Emma in the installation path examples on point 3.1 and 3.2 above.
  6. Click Start > All programs > Sony Mobile > Emma (if you used the default installation path from step 3 above) to start the flash tool
You can visit my blog with video Tutor lol
Feb 14, 2013 | Sony Ericsson Sony Xperia U St25i Black...
Another appiliocatin runnig close it and then start the camera
Try to replace any application that double. It maybe will say operator failed. Don't worry just after u did that. Do the next step.
2. Turn the phone off then turn it on again.
3. Open file manager go to application and try to delete any doubled application. It will maybe show you nothing after deleted. But don't worry. Get out from application folder then open it again. You will find unknown application with the same name of the deleted application that you did before. Just delete it then its gone.
4. Repeat that with every double application or games. If it say failed. Then restart your phone then try and it will be deleted.
Mar 10, 2012 | Sony Ericsson Walkman W810i Cellular Phone
How to read sms, of my sony w810i phone through computer
You must download PC suite first in order to read sms of your W810i on our computer.Things that you require are:
  • Data cable.
  • Phone monitor :It is the PC suite for Sony Ericsson W810i that will allow you to do task like reading SMS on your phone managing them,contacts and data etc.
You can download PC suite from following link:
Installation instructions:
  • Download the file to a temporary folder on your PC.
  • It is recommended to uninstall any previously installed version of Sony Ericsson PC Suite
  • Execute the downloaded file.
  • If updating to a newer version of the Sony Ericsson PC Suite, a restart of the PC may be required after the new installation is completed.
How to use:
  • Connect the mobile phone to your PC using an applicable connection: Cable, Infrared or Bluetooth connection.
  • Start the included programs from the Start/Programs/Sony Ericsson folder or the Application Launcher application
Dec 13, 2009 | Sony Ericsson Walkman W810i Cellular Phone
How to install application, theme and games on
ok now listen
just join ur mob to pc via media player .
then go to multimedia folders thru pc connections and in phone memory create folder 'games'
now downlod game
u shud download both jar jad files of game
now in the games folder which u created create a flie for the game mov both th efiles of game to this folder.....................
now disconnect ur phone frm pc
now click *#6984125*#then 4then*#9072641*#
for 2times
switch off mobile
again click above keys
and enjoy
Dec 12, 2009 | Samsung SGH-L700 Cell Phone
Hi everyone, i just download games,softwares from the internet for my sony ericsson w810i,but they do not work in my mobile phone..can anyone help me cuz i think that there is a problem with java in my...
Try this 1. Downlaod new applications from www.mobile9.com1
2. Download to pc first
3. Transfer via usb cable to your phone by copying and pasting the jar file into your ''other folder''
4.After all this this check your phone in the other folder and it should give the option to automatically install to applications or games folder.
5. Have fun
Sep 16, 2009 | Sony Ericsson Walkman W810i Cellular Phone
How can i read pdf files on my sony w810i mobile phone
Download a software called mobiledoc and then u can read pdf files easily..Google it and u ll get it easily
pls rate my suggestion...
Jun 24, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Unlock code
To accomplish the unlocking of your Samsung R210 Spex due to forgotten or unknown user lock code I used the following method. First, you will need a data cable. I bought this one from eBay...
Data cable
Create a folder on your desktop. I named mine Samsung R210.
When you plug your phone into the PC it may be recognized and work. If not you may need the USB drivers also.
Unplug the phone.
Open the Samsung R210 folder and create another folder. I called mine USB driver. Download this driver to the USB driver folder...
In the zip file there's a folder called Samsung_USB_install
Unzip it into the USB driver folder also and click on setup.
Reconnect the phone.
Check the control panel under USB and ports COM and LPT. My phone appeared on COM 10 under ports COM and LPT.
Next, create two more folders inside the Samsung R210 folder. I called them PST and Cricket DLL. Download Samsung PST lite and DLL installer files from the following two links into their respective folders.
Samsung PST lite...
Cricket DLL file for the PST...
Unzip them both into their same folders.
Run the install for PST.
Run the install for the Cricket DLL.
There should now be a shortcut on your desktop named Samsung PST lite. Double click it and you should see the PST Lite window.
Double click SCH-R210 on the right.
This should show you the unlock code in the next window.
If you don't see the info click the read general information button at the bottom. Write down the user lock code or be sure to remember it. Close the windows. Disconnect the phone. Enter the lock code into the phone and you should be free!
PS, I got my R210 Spex off eBay for $0.01 because it couldn't be unlocked! I have a feeling those prices will go up now that this info is on the web.
Mar 13, 2009 | Samsung Cell Phones
Request of folder lock for java mobile
I need folder lock or phone lock software for sony ericsson mobile W810i (java software) THANKS
Jan 10, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Call recorder without beep
that is preset in the phone...don't think that it can be disable
Sep 24, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Sony Ericsson Walkman W810i Cellular Phone Logo
76 people viewed this question
Top Sony Ericsson Cell Phones Experts
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
