Question about Roundup VCT-1000 Vertical Contact Toaster
VCT 1000 has no power
To the unit to repair shop, technician said the unit only needed to be reset. No power to the unit again, where is the button to reset the unit.
Frigidaire fra18emu2 unit won't power on
Good Morning Marty, thank you for allowing me to assist you. Here are a few simple troubleshooting tips that may help you resolve this issue:
· First, confirm that the unit has power to it.
· Check the power cord connection to the wall outlet is secure.
· Make sure that the house circuit breaker has not tripped.
· Try testing the air conditioner again. Make sure the unit is turned off, Press the TEST button, you will notice a clicking noise as the BUTTON pops out. Then press the RESET button. Again, you will notice a click as the button engages, now turn unit on. If the LCDI plug does not reset the cord may be damaged.
· The "Cool" circuit has an automatic 3-minute compressor time delayed start if the unit is turned off and on quickly. This prevents overheating of the compressor and possible circuit breaker tripping. And the fan will continue to run during this time.
· If the unit has been turned off and on rapidly or if the thermostat was changed to a lower number and then immediately turned back to a higher number the compressor may not start. You must turn the unit off and wait a minimum of 3 minutes for the unit to equalize before restarting.
If these assessment measures prove to be ineffective, I would strongly suggest contacting an authorized service technician who would be better able to assist you in the diagnosis and repair of your unit. You can often locate an experienced technician in your area by going to the manufacturer website.
Aug 19, 2013 | Frigidaire FAH106N1 Wall/Window Air...
1999 ford contour p1381 error code
Low oil level Cam timing improperly set Continuous oil flow to the Variable Camshaft Timing (VCT) piston chamber VCT solenoid valve stuck open Camshaft advance mechanism binding (VCT unit).
Read more: https://www.autocodes.com/p1381_ford.html
probably the cam sensor, sometimes the sensor can get damaged or the plug gets dislodged when the timing belt is done. .
Jun 20, 2017 | 1999 Ford Contour
Cotton candy maker will not power on
If you have checked to make sure it is plugged in, and outlet has power. The next thing to check is a circuit breaker in the front underneath the handle. A small white button to push.
If resetting the breaker, and it runs for a second then trips again, do not reset it again, this indicates a ground fault in the machine and it needs to be repaired by technician.
If the breaker doesn't change the operation (no power) then it should be repaired by a technician as there is no easy fix for the symptoms you have described.
Mar 21, 2013 | Gold Medal Products Gold Medal 3008SS...
The protection circuitry has been activated 3 times consecutively and as a safety precaution, capability to turn on the power is disabled.
If there is no apparent cause for the protection mode activating (such as shorted speakers, burning smell, blown fuses, lighting strike or mains power surges), reset the protection as follows and see what happens.
Connect power cord to mains and wait 5 seconds or so. While holding down "info" and "tone control" buttons, press "main zone" power button briefly and release, but keep "info" and "tone control" buttons pressed for at least 3 more seconds. The unit should power up. Assuming the reason for the protection has passed or been fixed, the unit can now be turned off and then back on with the "main zone" power button to restore normal operation mode.
If the protector activates again, the fault is still present and the unit needs to be repaired, ideally by a Yamaha authorised repairer.
There are dangerous voltages present in high power amps and a lot of grunt in terms of stored energy - best left to trained technicians.
Apr 20, 2012 | Yamaha RX-V671 7.1 Channel AV Receiver
How do I reset my yamaha rx-v671 receiver?
Yamaha RX V671 will not turn on anymore after a power outage
The protection mode has activated.
Reset the protection mode as follows and see what happens.
Apr 10, 2012 | Yamaha Audio Players & Recorders
P0012 Intake camshaft position timing over retarded bank one Is this a easy fix
Code P0012 - Variable Camshaft Timing Over Retarded - Bank 1
How does a P0012 code trigger the check engine light? This code will trigger the check engine light under the following condition:
* The comprehensive component monitor, referred to as the CCM, monitors the Variable Camshaft Timing (VCT) position for over-retarded cam timing. If the cam timing exceeds a maximum calibrated limit or is stuck in a retarded position, the check engine light will come on and set this trouble code.
Possible Causes:
Incorrect camshaft timing
VCT solenoid valve stuck open or continuous oil flow to piston chamber
Camshaft advance mechanism binding, or faulty VCT unit
Diagnostic Help:
This check engine light code is caused by a mechanical fault of the VCT unit or related components, so there is no need for electrical diagnosis. Possible symptoms may include rough idle, stall or hard start. Refer to manufacturer specific component tests for the VCT unit. You may also use the "Get Help" link if you need specifications or have any other related questions. Remember to refer to an appropriate manual for specific instructions.
Other details mentioned a P0012 DTC trouble code may be caused by one or more of the following:
* Incorrect camshaft timing
* Wiring problems (harness/wiring) in intake timing control valve control solenoid system
* Continuous oil flow to VCT piston chamber
* Failed timing valve control solenoid (stuck open)
Possible Solutions:
The main thing to check is to verify the operation of the VCT solenoid. You're looking for a sticking or stuck VCt solenoid valve caused by contamination. Refer to vehicle specific repair manual to perform component tests for the VCT unit. Notes: Dealer techs have advanced tools and the ability to follow detailed troubleshooting steps, including the ability to test components using a scan tool.
Hope helps (remember to rate and comment this).
Sep 30, 2010 | 2004 Ford F150
The lens cover does not open
You have a problem with your lens barrier unit. Sometimes, it can be repaired but sometimes that part needs to be replaced. This repair should be done by an experienced technician. The only easy thing that you can try is to unplug the camcorder from any type of power source, let it sit for about 10 minutes and try again. There should also be a reset button (most of the time it is on the side case where the LCD fits against the camcorder). You can try pushing the reset button and see if that makes a difference. Hope this has helped you.
www.austintelstarservices.com
Sep 05, 2010 | Canon VIXIA HF S10 Camcorder
TV suddenly has no power / power button non-responsive
I hate to say this but you are looking at a repair cost to get this going again. You may have some luck leaving the unit unplugged for a few weeks and then re trying it but that is a long shot. If it were my unit I would recycle the old one and replace with a used or new unit. If the problem is power supply related repair charges can be in the 40-60 dollar range. Decide on your own what is best for you but the unit will need repair by a shop technician most likely.
May 03, 2010 | Sanyo DS31590 31" TV
MY TV turns off automatically after I turn it on
This sounds like you have a high voltage problem. When your unit turns on the high voltage builds up to the operating voltage. Apparently something is overloading the circuit which causes the set to shut down for safety reasons. This locks out the controls and you can't restart it until the power is removed which resets the micro. The unit is going to need professional help if you are not an electronics technician, and I'm guessing you aren't. This should not be a hard fix and the cost should be reasonable. Find a good repair shop and get an estimate or get it repaired. Good luck.
May 22, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Roundup VCT-1000 Vertical Contact Toaster Logo
29 people viewed this question
Top Roundup Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Roundup Kitchen Appliances - Other Expert? Answer questions, earn points and help others
