Question about Weedeater Featherlite Blower 18 Cc 150 Mph 300 Cfm Model No Fl1500 Reconditioned
Starting string will not go back in
The string you pull to start the blower will not go back in
How to replace starter Rope
William, could not find your exact model, the links below should help as a lot of blowers and string trimmers pull ropes are changed using similar method.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Quick and Easy Homelite Weed Wha cker Starter Pull Cord Replacement
How to fix string starter recoil on small outdoor power equipment like...
How to Install Pull Start Recoil for Backpack Blower
Apr 10, 2016 | Troy-Bilt Tb4bp 32cc 4-stroke Gas Powered...
Pull string
you might have you coil set to close to the flywheel and the coil is not letting the flywheel spin like it is suposto sotheir for you string id to tin\ght when you hace the hood on so reagap the coil and sett it a little farther back from the flywheel by not to far back
May 14, 2013 | Mtd 22" Yard Machine Push Mower
Went to start bp251 blower after sitting in shed for a week, pull string was very hard to pull. took off plug a lot of fuel came out of plug hole . also checked muffler screen,was clean. there was quite a...
Take plug out turn blower to where plug hole is down pull starter cord many times until all fuel is out. Clean plug, install, try starting without priming or choking. If no start try priming just until you get fuel to engine. Try starting again. If this works when storing blower leave fuel cap slightly loose in very hot weather until you want to start.
Aug 09, 2017 | ECHO, Inc. PB-251C Handheld Blower
I don't remember how to start my weed eater;i've lost my manual
Pump the gas bubble near the black box air filter. Start pulling the string. Keep pulling until it turns.
Thanks
Jun 03, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
Starter rope will not retract
Either you have a broken rewind spring, or the starter mechanism is dirty to the point where the force of the recoil spring is not sufficient to pull the rope back in.
WEAR SAFETY GLASSES while disassembling your starter mechanism to see what the problem is. Upon reassembly, it is a good idea to lube the post in the starter housing (the one the pulley slides over) with some graphite or teflon lube.
Oct 25, 2009 | Troy -Bilt String Trimmer/Blower...
The pull string won't pull
hi
check the piston rings and bearings
bye
Nov 16, 2008 | Husqvarna Backpack Blower, Model No. 356bt
Craftsman 2cyl leaf blower wii not start
it sounds like vapor lock, trying giving it a couple pulls with the spark plug taken out
Nov 13, 2008 | Craftsman 4 Cycle Blower/Vac
Weedeater Featherlite Blower 18 Cc 150 Mph 300 Cfm Model No Fl1500 Reconditioned Logo
Top Weedeater Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
ray gallant
Are you a Weedeater Garden Expert? Answer questions, earn points and help others
