Question about Hitachi 32LD8700 32 in. LCD Television
Flashing green and red its a 32 ld 30 u a will not switch on or off.
Tv will not switch on or off.
Tv switches on goes from red led to green and after a few second goes back to red. No picture 32 inch aquos
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can vet an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/
Dec 30, 2013 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Mitsubishi dlp tv model wd-62627 wont power on when i plug tv in green light flas then will stop then i try to power on tv after after green light stops flashiing after oabout 30 sec red lamp light co
Inspect the lamp first to see if shattered--set has a self check feature also:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filtercover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cablebetween FMT and Engine disconnected
May 30, 2012 | Mitsubishi WD Televison & Video
Push power button green light flashes several times then goes solid red for about 3 seconds but tv does not come on we unplugged for 30 mins did not help
My friend always left their LCD on and the TV did the same thing the main board inside needed to be replaced call service provider.
Jan 27, 2011 | Emerson LC320EM9 32 in. LCD HDTV
My 32LD30UA LCD TV is 16 months old, when you switch TV on the picture has a band of reds and greens running down screen for about 30 minutes then returns to normal.Help?
My HITACH 32LD30UA LCD TV when you switch TV on the picture has a band of reds and greens running down screen for about 30 minutes then returns to normal.
Dec 12, 2010 | Hitachi 32LD8700 32 in. LCD Television
Tv comes on, green light flashes several times, get the "digital television" shown at botton left corner, then flashing green light stops, tv turns off and red constant "stand by" light comes back on. TV...
common problem with that model is the backlight inverter, 1 or more of the six transformers may be bad.also check for bad capacitors.the tedious way to check is unplug each and plug in each one at a time but unplug the power from the tv each time you check one or you will get a nice jolt. the one that doesnt light the lamp is bad.or take each transformer off and check the primary and secondary coils if you find one open coil. the transformers cost between $8 and $20 each.it has a substitute part.
Jul 05, 2010 | Sylvania LD-320SS8 32 in. LCD TV/DVD Combo
Sony Wega KV-XF21M83 21" Color TV red LED flashing two times
mt sony trinitron power light is blinking from green to red twise and then pause for 3 seconds and then blinks again from green to red
Jul 05, 2009 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
Comcast remote code for 32" viewsonic
11755
  1. Turn on your device (i.e. TV).
  2. PRESS the button for the device you want to program (TV, VCR, CABLE, AUD, etc.) then RELEASE.
  3. PRESS and HOLD the SETUP button until the red LED for the selected device flashes twice, then RELEASE.
  4. ENTER the 5 digit code for your brand from the list above.
  5. You should receive 2 quick flashes on the LED for the selected device after entering your code.
  6. PRESS the POWER button to test the code. (On VCR,LD,and CD players use PLAY)
Jun 16, 2009 | ViewSonic NextVision N3260W 32 in....
Stuck in standby.
Mainboard damaged and need to be replaced, try EBAY for a general picture of prices but you will need your product code wich is located in the back of the TV next to serial number.
May 16, 2009 | LG 32LC51 32 in. HD-Ready LCD TV
Hitachi 32LD8700 32 in. LCD Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
