Prizmo tv Can't get sound through hdmi connection
How do I connect my LG HR836T into my LG TV & LG sound system HB806 already connected
It all depends on how many HDMI input you have in the back of the TV, usually most models have 3. If you already have the TV and the sound already connected, then all you need to do is connect the player to the back of the TV to any of the HDMI input. Those are usually mark as HDMI 1 HDMI 2 and HDMI 3, so when you use your remote control to change the input in the TV, make sure to which input you connect the player to. You don't have to touch or do anything to the sound system.
Feb 15, 2015 | LG Audio Players & Recorders
I have a universal ge remote control will it work on my 19 inch prizmo tv
082,087,038,024,004. Check these codes. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 21, 2013 | Universal Remote Control GE174Universal...
How do I connect my Panasonic SC-HTB500 sound bsr to my Panasonic TH-42PX75U television with an HDMI cable?
If you have a set top box (blu-ray, dvd, cable) with HDMI Out, then you need a pair of HDMI cables. Connect one from the HDMI Out of the set top box to the HDMI In of the sound bar. Then connect the HDMI Out of the sound bar to the HDMI In of the TV.
If you only want to use the sound bar as an external speaker system for the TV, then you should get a digital audio cable (fiber optic cable). Connect this to the Digital Audio Out on the TV (below HDMI ports) and to the Digital Audio In of the sound bar.
I hope this helps. You can find the manual of the TV here: http://www2.panasonic.com/consumer-electronics/support/Televisions/Plasma-TVs/model.TH-42PX75U . The TV also has analog (RCA) audio out jacks labeled Prog Out on the bottom left of the connection panel; the sound bar however doesn't have RCA audio in jacks.
(since there are no HDMI out jacks on the TV, there is no other way to connect the sound bar.)
Dec 26, 2010 | Panasonic Televison & Video
Need the prizmo tv codes for a universal remote
Prizmo TV no universal remote codes work. I called RC Willey (where I purchased the Prizmo TV) to get a replacement remote for my Prizmo 19" TV. Customer service finally gave me a number for Red Rock Sourcing 1-702-252-5049. Red Rock took my Prizmo TV model number and they apologized for any inconvience. I told them no universal remote codes work for the Prizmo TV. Red Rock Sourcing is sending me a free replacement Prizmo remote by Fed-Ex. I hope this helps you.
Aug 14, 2010 | Uniden WHAMx4 LCD Remote Control
Cannot find the tv code for a Prizmo TV, to set up a remote control
RcWilley where I purchased my Prizmo TV 19" referred me to Red Rock Sourcing 1-702-252-5049 I gave them my Prizmo model number and they are sending me a free Prizmo replacement remote by fed-ex. The universal remote codes don't work on the Prizmo TVs
Jun 07, 2010 | Philips Magnavox 27MS343S 27" TV
CANNOT FIND CODE FOR PRIZMO TV
universal remotes do not work for the Prizmo TVs. RC Willey where I purchased my 19" Prizmo TV, referred me to Red Rock Sourcing at 1-702-252-5049. Red Rock is sending me a free Prizmo replacement remote by fed-ex. I hope this helps.
Apr 24, 2010 | Philips Magnavox 27MS343S 27" TV
What cables do i need to connect my ps3 to my sony recevier.
do you wan the suround sound to play sound for what the tv is displaying or just the ps3
for just ps3
connect hdmi to ps3 and tv
connect optical to ps3 and suround sound
change video settings to hdmi
change sound settings to optical
it asks to set settings automatically you have tyo doo it manually
if you want to play every thing that tv displays then
connect ps3 to tv with hdmi
connect suround sound with hdmi to tv
(this might not work)
if it dont work then
and your tv should have sound out or something along those lines it should be two phono plugs in the back of the tv connect that to the suround sound
Dec 31, 2009 | Sony HT-DDWG700 Theater System
JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Jan 12, 2009 | JVC AV-36D303 36" TV
Connection help with receiver and lcd TV
depend on what you wants to do. if you wan to get sound from your tv on receiver connect out from tv to in on receiver if U have optical out from tv send this to optical input on your receiver and set up your receiver to impute to digital HDMI carrie sound and video...
(My Denon receiver set-up shows an HDMI cable going from the Video Out on the TV to the HDMI MONITOR OUT on the receiver)
OUT TO OUT don't make sense ...could be out to impute you may have HDMI going from receiver to TV and other HDMI imputs on receiver to use receiver as distribution unit say you have satellite HDMI, DVD HDMI, Computers HDMI IMPUTE all of this connected to your Receiver and the HDMI monitor out from your receiver connected to TV so now you may select any of this sources to wach In your TV and lessen trough receiver speakers
Apr 10, 2008 | Sony BRAVIA KDL-40V3000 Television
74 people viewed this question
 Grubhead
Grubhead
