Question about Logitech M525 Mouse - Wireless - Radio Frequency - White - Usb - Scroll Wheel
Reset Logitech M525 mouse
I need to reset my mouse as I lost the usb device and have a different one that I want to use my old mouse with
My kindle fire does not charge.
If you are truing to charge with a USB post then switch to a wall wart. There is often not enough voltage to charge from USB.
Feb 04, 2015 | Amazon Kindle Fire HD
How to reset an Ipad2 when the first owner lost the ID and password?
Connect it to iTunes and Reset it to Factory Default. If that doesn't work put the iPad into Recovery mode:
To put your device into recovery mode, follow these steps:
  1. Turn off your device and leave it off.
  2. Plug in your device's USB cable to a computer with iTunes.
  3. Hold down the Home button on your device as you connect the USB cable. Keep holding down the Home button until you see the Connect to iTunes screen.
  4. When you see this screen, release the Home button. If you don't see this screen, try steps 1 through 3 again.
Oct 14, 2014 | Apple iPad 2 Wifi 16GB
How to remove a password from google nexus 7
I believe the only way to reset your password would be a hard reset. This will also remove all of data and return the device back to the original factory settings.
Reset your Nexus device to factory settings
Apr 22, 2014 | Google Nexus 7
My pandigital tablet dont wanna charge
USB Connections
All tablets connect to your computer using a USB cable.
Once connected, the device should charge as long as the computer recognizes it.
Look for manufacturer-specific software to launch once you plug your tablet into your computer; if this software fails to launch, it's likely that your computer hasn't detected the device and won't charge it.
Try a second USB cable, if available, or plug the USB cable into a different port.
If the device doesn't charge in either port, replace the USB cable.
AC Adapters
Some tablets are sold with an accompanying AC power adapter, though these accessories are often optional.
Try plugging your tablet into its AC power connector in the event that its USB cable isn't functioning.
Also check different wall outlets in case the outlet you are plugging your tablet into is defective.
If the device fails to charge in different outlets, the AC adapter may be faulty.
Reboot Like any device with an operating system a computer, a mobile phone or an MP3 player tablet computers can freeze from time to time.
When a computer freezes, you can reboot or restart it to get the operating system working properly again.
This is true of tablets too, but rebooting these systems can be a little tricky.
Check the manufacturer's website for specific instructions to restart your system.
Putting the tablet to sleep and waking it up doesn't clear its memory look instead for the buttons for a "reset," which are different for every brand.
This may clear up any recent malfunctions, like freezing apps or charging issues.
Restore
Just like a computer, tablets sometimes need to be restored to their original state to overcome technical issues like charging problems.
Again, the process of restoring your tablet to its factory default differs from model to model and from brand to brand.
Check the manual or the manufacturer's website for specific instructions, but as a general rule: plug the tablet into your computer using the provided USB cable.
Wait for the appropriate software to load and then look for a "Restore" option.
Follow the onscreen prompts to restore the device.
Aug 05, 2013 | Tablets & eReaders
Kindle will not charge from out let or computer
Please clarify: what charger did you use to connect to an outlet? The Kindle 3 comes with an USB cable to charge from a PC or Mac computer and no charger outside for many countries outside the US (for other countries an external charger is available from Amazon as optional accessory). Use of a different charger (e.g. mobile phone charger with USB connector) is not supported, not recommended and may fry your Kindle if a wrong voltage is hooked to it.
Things you can try:
  1. Use a different outlet to charge the Kindle.
  2. If you use the supplied USB cable to connect to a PC, make sure its firmly seated on both ends. Connect to a powered USB port directly on your computer. Some external USB hubs do not come with a separate power supply (external power supply is mandatory for an USB 2.0 hub, some cheap models are sold without one anyway) and are not suited to charge anything. Just to make sure, disconnect any other USB device except mouse / keyboard to check if the USB port in use is not burdened by too much drain.
  3. The Kindle power LED should glow amber while charging and green if the device is fully charged.
  4. Give the Kindle a reset pressing Home --> Menu --> Settings --> Menu and select "Restart." If the charge light is on but the device is still not charging, contact Amazon customer service.
  5. If the charge light does not light, the AC adapter or cable needs to be replaced.
  6. Contact Amazon customer support for any warranty issues.
Jan 01, 2011 | Amazon Kindle 3G
Logitech performance mx mouse does not work
Install set point and check if it works. www.logitech.com/download
Dec 20, 2009 | Logitech MX510 Performance Optical Mouse...
Logitech mx510 mouse fatal error during install after windows xp repair
re dl all drivers again for xp update it run ccleaner after that ok then it should work
Jan 23, 2008 | Logitech MX510 Performance Optical Mouse...
Logitech mx510 optical mouse warrant situation
buy new one at store stick old one in box return it say u dont like it after a week k
Dec 14, 2007 | Logitech MX510 Performance Optical Mouse...
MX 510 freezing
Same problem been getting worse. Figured out that the mouseware driver is outdated and not compatible with win xp. Use logitech's setpoint for mx518 or uninstall mouseware. Now no more freezes
Oct 11, 2007 | Logitech MX510 Performance Optical Mouse...
Logitech M525 Mouse - Wireless - Radio Frequency - White - Usb - Scroll Wheel Logo
100 people viewed this question
Top Logitech Tablets & eReaders Experts
Are you a Logitech Tablet and eReader Expert? Answer questions, earn points and help others
