Question about Tally T6218 Matrix Printer
How to enter ip address
Add ip address
I am unable to install hp laserjet M2727 nf MFP in the network. i don't know how to install it on the network? please suggest me the steps .
Hi
This is very easy setup to install the network printer. first to set the your desire network IP address in your printer.follow the mention option enter the Ip address.
  1. Press the Menu button.
  2. Press the Down Arrow to find Configure Device .
  3. Choose Configure Device .
  4. Press the check mark button.
  5. Choose I/O .
  6. Press the check mark button.
  7. Press the EIO (1 or 2) Jetdirect Menu .
  8. Press the check mark button.
  9. Choose TCP/IP .
  10. Press the check mark button.
  11. Choose Configuration Method .
  12. Press the check mark button.
  13. Choose Manual .
  14. Press the check mark button.
  15. Select Manual Settings .
  16. Choose IP address .
  17. Press the check mark button.
  18. Enter IP address with keypad.
  19. Press the check mark button.
  20. Choose Subnet Mask .
  21. Press the check mark button.
  22. Enter Subnet Mask with keypad.
After assign the IP addres in printer. connect to your printer with router or switch. and insert you HP Installation CD in Rom,
Go to the Control Panel and select Printer and Faxes click the "Add Printer"the new Add printer wizard open click next and remove the check mark in " Automatic detect and install the Plug and Play printer" click next, then you get "Select the printer port screen" Click create New port and choose Standard TCP/IP and click next.
You will get another New windows " Standard TCP/IP Add Printer Port" click next and put the Printer IP Address click next and next, Finish.
Now the windows will appear " Add Printer Wizard" click the Have Disk " and choose the .Inf file for your Installation CD, and Click Finish.
Your printer will install and the test will come.
If my solution solve you problem then give me four thumb
Cheer
Jul 12, 2011 | HP Laserjet M2727nf Multifunction Printer
Tip
How to change the IP address on a Ricoh Aficio C811 printer
With the use of a DHCP (Dynamic Host Configuration Protocol) server, you can automate the administration of IP addresses for printers. However, you may want your printer to have a static IP address. To set up a static IP address on a Ricoh Aficio C811 color printer, follow the steps below.
1. When the printer is powered on and ready, press the Menu button.
2. Using the up or down arrows, scroll down through the menu to Host Interface and press OK.
3. Scroll down to Network and press OK.
4. Machine IPv4 Address is the first option on the network menu; click OK when it is highlighted.
5. You will see two options -- Auto-Obtain (DHCP) and Specify, and below them are three tabs -- IP Add., Subnet M, and Gateway. Scroll down so that Specify is highlighted, and then press the arrow button below the left-most tab (IP Add.).
6. Using the up and down arrows to change the numeric value, enter the IP address you want to use for the printer. Use the side arrows to go to the next part of the address once you've entered the value for the current octet.
7. Once you've entered the complete IP address, press OK. (If you want to cancel out without saving the new address, press Escape instead.)
8. If you need to specify a subnet mask and gateway address, you can enter those values in the same way, by selecting each of the corresponding tabs on the IPv4 menu (Subnet M and Gateway, respectively).
9. After you've entered all of the information and saved each address, make sure Specify is highlighted and press OK. You should see "Programmed" displayed on the screen.
10. Turn the machine off and then back on to apply the changes and reset the network connection.
on Mar 17, 2011 | Ricoh Aficio SP C811DN Laser Printer
How do I get my router add a new port forwarding entry - port 12345, protocol TCP. And how do I find out the IP address of my computer? Thank you for you your assistance.
To find the IP address your computer is using:
Windows XP/7
1. Click on Start > Run
2. Type cmd and hit enter
3. Type ipconfig and hit enter
4. The number on the right of IP Address is your assigned address.
To add a port forwarding entry, log into your Linksys device and try the following:
1. Click on the "Applications & Gaming" Menu
2. Input an application name (Can be anything you want)
3. Enter the desired port number [12345] in both External and Internal Ports
4. Choose the TCP protocol
5. Enter the last number of the IP Address in the box
6. Click the Enabled check box
7. Click on un7bpgedqyopdk0zbwaaaabjru5erkjggg== on the bottom
Sample of Port forwarding menu
vnplpartunolz7n6n3b9m+jnn7ml0i2nqxyrocyd25orpdehebgvt+6hh5hgnu0+edcks7p0pdwicsaoso4igridejiaikycxiwjccv4h6gesrve+m0iaaaaasuvork5cyii=
May 03, 2011 | Linksys WAG200G Router
How to obtain my password and add another laptop to wrt54G
To access the router's web-based setup page using Mac, click here. Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
Aug 23, 2010 | Linksys Wireless-G WRT54G Router
How do I change the ip address from the lcd display?
hi
  • Go to the Control Panel from the Start menu.
  • Step 2 Click "Network and Internet" and then "Network and Sharing Center."
  • Step 3 Click "Manage network connections."
  • Step 4 Choose which Internet connection you would like to change if you have more than one. Right click on it and select "Properties."
  • Step 5 Click the "Networking" tab.
  • Step 6 Choose either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6).
  • Step 7 Click "Obtain an IP Address Automatically" to reset your IP address automatically, then click OK.
  • Step 8 Click "Use the following IP Address" to enter your own IP settings.
  • Step 9 Enter your IP address into the boxes marked "IP Address," "Subnet Mask" (or "Subnet prefix length for IP/TCPv6) and "Default gateway."
    Change your DNS Server Settings
  • Step 1 Click "Obtain DNS Server Address Automatically" and then click "OK."
  • Step 2 Click "Use the following DNS Server addresses" to change your DNS Server settings manually.
  • Step 3 Type your primary DNS Server address into the box that says "Preferred DNS Server."
  • Step 4 Type your secondary DNS Server address into the box that says "Alternate DNS Server."
    Add a New Network Protocol
  • Step 1 Click "Properties" and then "Install" from "Manage network connections."
  • Step 2 Click "Client," "Service" or "Protocol," depending on which you wish to add. Then click "Add."
  • Step 3 Select the item you want to add from the dialogue box and click OK.
  • Jul 02, 2010 | Zebra Printer 140-751-00000
    Where is my printer IP address
    The printer IP address is something you have to add. You can go to Xerox.com and go to support, type in your model number and then to support again.
    Then enter IP in the search box and it will tell you step by step how to set it up.
    You can set the printer up with a USB cable and it will skip that all together.
    The reason it is asking you for the IP address is so it can find the printer and automatically add it.
    If you need help. e-mail me at rak458@aol.com I will try and help you that way.
    Dec 22, 2009 | Xerox Phaser 6125 Laser Printer
    I don't know how to port forward my comtrend adsl+
    A. Determining the IP Address and MAC Address of a Computer:
    Note: Please use the computer for which the Ports are to be opened:
    For Windows 2000/XP users:
    1. Please click on Start and select Run.
    2. Type in cmd and click on OK.
    3. In the Command Prompt, please type ipconfig/all then press Enter or Return key.
    4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router).
    5. Please note down the IP address and Physical address.
    B. Reserving an IP Address:
    1. Please open any web browser like Internet Explorer or Netscape Navigator.
    2. Connect to the router by typing http://192.168.1.1 in the address field and click Enter or Return key.
    3. A window will prompt for a user name and password. The default username is "admin" and the default password is "admin".
    4. When the setup page opens, click on LAN IP Setup under Advanced tab.
    5. Click on Add under Address Reservation.
    6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
    7. If the computer you want is not on the list, please click on the Refresh button to update the table.
    8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add.
    9. Click the Add button when done.
    C. Opening Pre-Defined Ports for Internet Services:
    1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced menu.
    2. Please select the service type Port Forwarding. The router pre-defined services are listed there.
    3. From the Service Name pull down list, select the service that needs to be hosted.
    4. Enter the IP address of the computer in the Server IP Address box.
    5. Click the Add or Apply button.
    6. Repeat all steps to open more ports.
    Note: If the name of the Internet service does not appear in the drop down list, you may manually open the ports for that Internet service. Please follow the steps below:
    D. Opening Ports for Games, Applications or Custom Ports:
    1. Click on Add Custom Service button.
    2. Type the service name in the Service Name box and the lower range numbers in the Starting Port box.
    3. If the application uses only a single port; type in the same port number in the Ending Port box.
    4. If the application uses a range of ports; type in the higher range numbers in the Ending Port box.
    5. Type the IP address of the computer in the Server IP Address box. Click Apply button.
    6. It will then refresh to the Port Forwarding page, and will show the list of all ports opened in tabulation.
    7. Repeat all steps to add more ports for more services.
    E. To Edit or Delete a Service Entry:
    1. Click on the Radio Button that needs to be Edited /Deleted, under the Port Forwarding page.
    2. Modify the information from the Service Name, Starting Port, Ending Port, and the Server IP Address, and then click the Apply button.
    Sep 25, 2009 | Linksys WRT55AG Router
    Problem connecting with mates on fifa 09 on ps3.
    here is the link for your port forwarding configuration:
    http://kb.netgear.com/app/answers/detail/a_id/1166
    here is the link for HOW IS PORT FORWARDING CONFIGURE:
    http://kbserver.netgear.com/kb_web_files/n101145.asp
    Instructions for RP614, MR814, WGR101, WGR614, WGT624, WGT634U, WGU624, WGM124, or WPN824 These routers do port forwarding by assigning port numbers to a "service" that is associated with the application you want to run.
    To Let an Application Use Port Forwarding
    1. Type the router's address in an Internet browser's address bar. (By default the router's address is 192.168.0.1). The Setup Wizard appears.
    2. Enter the router's username and password.
    3. Under Advanced, click Port Forwarding on the left menu bar.
    4. A Port Forwarding Screen (Varies Slightly by Router)
    5. From the Service & Game (or Service Name) pull down, select the service that you will host. The services the router knows about are listed here. If the service does not appear in the drop down, add a service as described in the next section, then return to this step.
    6. Enter the IP address of your local server in the Server IP Address box.
    7. Click Add.
    8. Click Logout to exit from router settings.
    To Add a Service for These Routers
    To define a service not in the Service Name list, determine what port numbers are used by the service.
    1. Click Add Custom Service.
    2. Enter the first port number in an unused Start Port box.
    3. If only one port number is to be forwarded, enter the same number in End Port. To specify a range of ports, enter the last port to be forwarded in the End Port box.
    4. Enter any name you choose for the service.
    5. Click Apply.
    Apr 03, 2009 | NetGear WGR614 54Mbps Wireless Router...
    Configuring IPSec between a Microsoft Windows 2000 or XP PC and a Linksys VPN Router
    Windows XP or Windows 2000 IP Address: 140.111.1.2 ? User ISP provide IP Address, this is only a sample Subnet Mask: 255.255.255.0 BEFVP41 WAN IP Address: 140.111.1.1 ? User ISP provide IP Address, this is only a sample Subnet Mask: 255.255.255.0 LAN IP Address: 192.168.1.1 Subnet Mask: 255.255.255.0 Step-by-Step [Windows 2000/XP] Create IPSec Policy 1. Click the Start button, select Run, and type secpol.msc. in the open field. 2. Right-click IP Security Policies on Local Computer and click Create IP Security Policy. 3. Click the Next button, and then type a name for your policy (for example, ?to_befvp41?). Then, click Next. 4. Deselect the Activate the default response rule check box and then click the Next button. 5. Click the Finish button, making sure the Edit check box is checked. Build 2 Filter Lists: ?WinXP? BEFVP41? and ?BEFVP41? WinXP?. Note: The references in this section to ?WinXP? can easily be exchanged for ?Win2000?, if running Windows 2000. Filter List 1: WinXP? BEFVP41 1. In the new policy properties, deselect the Use Add Wizard check box and then click the Add button to create a new rule. 2. From the IP Filter List tab, click the Add button. 3. Type an appropriate name ?WinXP? BEFVP41? for the filter list, deselect the Use Add Wizard check box, and click the Add button. 4. In the Source address field, select My IP Address. 5. In the Destination address field, select A specific IP Subnet, and fill in the IP Address 192.168.1.0 and Subnet mask 255.255.255.0. 6. If you want to type a description for your filter, click the Description tab. 7. Click the OK button. Then click the OK (for WinXP) or Close (for WIN2000) button on the IP Filter List window. Filter List 2: BEFVP41? WinXP 8. On the IP Filter List tab, click the Add button. 9. Type an appropriate name ?BEFVP41? WinXP? for the filter list, deselect the Use Add Wizard check box, and click the Add button. 10. In the Source address field, select A specific IP Subnet, and fill in the IP Address 192.168.1.0 and Subnet mask 255.255.255.0. 11. In the Destination address field, select My IP Address. 12. If you want to type a description for your filter, click the Description tab. 13. Click the OK button and click the OK (for WinXP) or Close (for Win2000) button on IP Filter List window. Configure Individual Rule of 2 Tunnels Tunnel 1: WinXP? BEFVP41 1. From the IP Filter List tab, click the filter list WinXP? BEFVP41. 2. From the Filter Action tab, click the filter action ?Require Security?, and click the Edit button. 3. verify that the Negotiate security option is enabled, and deselect the Accept unsecured communication, but always respond using IPSec check box. 4. Select the Session key perfect forward secrecy (PFS) and remember to check the PFS option on the BEFVP41, and click the OK button. 5. From the Authentication Methods tab, click the Edit button. 6. Change the authentication method to Use this string (preshared key), enter the string ?XYZ12345?, and click the OK button. This new Preshared key will be displayed. Click the OK button to continue. 7. From the Tunnel Setting tab, click The tunnel endpoint is specified by this IP Address radio button and type the WAN IP Address 140.111.1.1 of the BEFVP41. 8. From the Connection Type tab, Select All network connections and click the OK button to finish this rule. Tunnel 2: BEFVP41? WinXP 9. In the new policy properties, deselect the Use Add Wizard check box and click the Add button to create the second IP Filter. 10. From the IP Filter List tab, click the filter list BEFVP41? WinXP. 11. From the Filter Action tab, select the filter action Require Security. 12. From the Authentication Methods tab, click the Edit button. 13. Change the authentication method to Use this string (preshared key), enter the string ?XYZ12345?, and then click the OK button. This new Preshared key will be displayed. Click the OK button to continue. 14. From the Tunnel Setting tab, click the radio button for The tunnel endpoint is specified by this IP Address and type the Windows 2000/XP IP Address 140.111.1.2. 15. From the Connection Type tab, select All network connections. Then, click the OK (for WInXP) or Close (for Win2000) button to finish . 16. From the Rules tab, click the OK button to go back to the secpol screen. Assign New IPSec Policy 1. In the IP Security Policies on Local Computer MMC snap-in, right-click the policy named to_befvp41, and click Assign. A green arrow appears in the folder icon. [BEFVP41] Setup Screen 1. Open your web browser and enter 192.168.1.1 in the Address field and press the Enter key. 2. When the User name and Password field appears, skip the user name and enter the default password admin and press the
    Feb 16, 2006 | Linksys EtherFast Cable/DSL VPN Router...
    Tally T6218 Matrix Printer Logo
    Top Tally Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Tony
    Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
