I have xp dell mini and has no beeps and has a black screen what give it has work fine early?
    Sergeant:
  • 446 Answers
Screen is bad
Posted on Apr 07, 2014
PCTechOnline
  • 532 Answers
SOURCE: loud beeps at start up dell inspiron mini
Beep codes for the Inspiron Mini are as follows:
Beep Code Possible Problem
One Possible system board failure — BIOS ROM checksum failure
Two No RAM detected
NOTE: If you installed or replaced the memory module, ensure that the memory module is seated properly.
Three Possible system board failure — Chipset error
Four RAM read/write failure
Five Real Time Clock failure
Six Video card or chip failure
Seven Processor failure
Eight Display failure
Posted on Jun 10, 2010
tomcattech17
  • 214 Answers
SOURCE: My dell inspiron mini 1012
Its a POST Beep code:
For more info, go here:
http://support.dell.com/support/edocs/systems/opgx620/en/ug/tools00.htm#wp1120374
Posted on Jun 10, 2011
hunter19_46m
  • 7482 Answers
SOURCE: When I turn on my
Hi...
Start your computer in the Safe Mode.
To start in Safe Mode
Turn your computer on
Keep tapping F8 while the computer is starting up
When the computer starts select Safe Mode
1. Uninstall any softwear you may have put on the computer before the problem started.
2. Do a complete System Restore: Start>All Programs>Accessories>System Tools>System Restore.
This will bring your system back to a time before you installed the softwear or Microsoft installed drivers,updates,etc.
Note: Just be sure to use a date in a darkened box before your trouble start date.
When you have done the above, restart the computer and if your still getting the blue screen of death, the installed drivers,softwear,etc might have corrupted the Operating System.
If that happened then that means either repair or reinstall the operating system.
You will need to do the following:
1...Repairing the Operating System...
A...You will have to have the Operating Dics that came with the computer.
Note...If you do not have the disks that came with your computer or the ones you should have made when you first got your computer...then you will have to go to the manufacture's webpage and see if they have a recovery disk available for your computer, if they do not a recovery disks available then you can also try ebay to locate the recovery disks.
The original disks will have your product key number that came with the computer, you can also find it on the tower, or under the bottom of your laptop, or maybe the piece of paper that the CD orginally came in may have the number on it.
You can also download a small program and it will tell you your product key number.
Go to the following webpage to download your FREE key finder.
http://www.magicaljellybean.com/keyfinder/
B...You will now insert the disc into the CD/DVD player
C...Restart the computer
D...When the window opens that tells you to press "Any" key, you will press any key you want to press.
E...If you do not receive a message that says "press any key to boot from CD", then then the computer is not ready to boot from a cd.
To correct this problem you will have to go into your computer's Bios and change the computer to boot from a CD.
To get into the Bios, shut the computer off,restart, while the computer is starting up keep tapping F1 as the computer is starting up.
When you are in the Bios, select to boot by CD by moving the cursor with the direction arrows on the keyboard.
Once you have selected to boot by cd the exit and restart the computer...the disc is already in the cd/dvd player.
Your system will then boot from the cd.
F...After a minute or less it should ask you if you want to Quit Repair, or Continue.
You will select Repair this time, but you may have to come back here and select Install if the repair does not work.
It will ok the agreement document if it asks you too.
Tap F8 on your keyboard to pass it when ready.
It will ask you if you want to Install, Repair, Delete Partition, or Quit.
Select Repair
Inside the box there will be one or two partitions.
Choose the largest partition.
After you have chosen the largest partition, you will then press the "r" key to start the repair
After the repair is complete, then you will need to restart your computer.
G...Computer Restart
After the repair is complete, shut the computer down (the computer will shut down a few times during the installation of the operating system
that is normal).
Then restart your computer, when the computer restarts it will have a box to put your product key...put the product key in the box and click.
The computer should start up and run as if it was a new computer.
You do not need to re-register
You can now remove the disc.
If this fails to clear your your problem then you have a hardware problem.
It could be faulty ram
If you still have the problem then you have two choices.
1.Reinstall the entire Operating System and you may have to update some drivers.
This will require you to go back to the start of the repair info and select Install instead of Repair.
2..Take your machine in to have the hardware tested.
Keep in mind that if you do a complete reinstall of the Operating System you will lose all the information on the computer,such as pictures, programs, videos, everything you installed will be gone.
Please take time to rate me four thumbs up
Posted on Sep 08, 2011
Geekman
  • 32281 Answers
SOURCE: dell insperion 5030 screen black and beeping
This POST code means there is a problem with the RAM.
Reseat the RAM and if the Dell still does not boot up then -
If it still does not boot up then could be faulty. Remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Posted on Sep 09, 2012
Geekman
  • 32281 Answers
SOURCE: Dell laptop black screen gives intermiitent 7 beeps
This WEB site gives the BEEP codes for the Dell.
http://en.community.dell.com/support-forums/laptop/f/3518/p/19447544/20098900.aspx
Posted on Oct 08, 2012
It start beeping until XP window come up,
It could be a bad memory module. Try removing and reinstalling them. Try one module at a time to see if beeping stops . Check all other connections to make sure they are properly connected. Hope this helps.
Jan 01, 2014 | Dell Inspiron Mini 10 10v 1010 1011 PP19S...
Dell Mini 10v boot issue
check the fan is working fine.... check th hardisk
Nov 28, 2011 | Dell Inspiron Mini 10v Netbook Computer
Dell inspiron mini -- at first it works fast but suddenly the screen goes black and I don't know why. I tried pushing the power button but it didn't work, the power button still lights up (so meaning, it...
Hi, Please try removing the battery and then starting it. Those beeps are error codes that help tech support people identify the problem, The easiest solution is to take the laptop to service center. Good Luck
Apr 01, 2011 | Dell Inspiron Mini 10 Notebook
I have a Dell Inspiron Mini, and everything was working fine until last Friday i tried turning it on and it as it loaded it went directly to a black screen with white letter and asked me how I wanted to...
Looks like your master boot record is corrupted or you have a bad hard drive. Without cd drive there is one option but it is not guarantied it will work. You can acctually make USB flash drive bootable but you need another computer with cd drive and an XP Operating System CD. You can google how to make usb flash drive bootable for XP and it will give you step by step instructions. Or you can borow an external cd drive or take it to pc repair store. Good luck.
Mar 17, 2011 | Dell Inspiron Mini 10 Notebook
When i turn on my laptop it makes a beeping noise for about 15 seconds.the screen also goes black after this for about the same time.then the laptop works fine just wondering what may be the cause of this.
Hi there, I am also facing same problem with my Dell Inspiron mini 1012, when i turn on my laptop it makes a beeping noise for about 15 seconds.the screen also goes black after this for about the same time.then the laptop works fine just wondering what may be the cause of this. S Bhat, India
Nov 01, 2010 | Computers & Internet
Inspiron 1520-before finishes loading desktop screen goes black..
As it works ok in safe mode, I suggest you check that your graphics drivers are up to date.
You should be able to download the latest from the Dell website.
Mar 20, 2010 | Dell Inspiron 1520 Motherboard
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
