Question about Kitchen Ranges
Samsung ne595nopbsr error code E-84 can't reset
Error code e-84 does not reset after suggested 30 second disconnet
2 Suggested Answers
  • 92 Answers
SOURCE: TFT -LCD Samsung LT-P227W
BY UNPLUGGING YOU RESET THE TV. SOUNDS LIKE IT IS GOING INTO A PROTECT MODE IF THE STNDBY LIGHT IN FRONT IS NOT FLASHING ITS PROBABLY A POWER SUPPLY PROBLEM IF IT IS COUNT HOW MANY FLASHES THAT WILL BE AN ERROR CODE
Posted on Feb 22, 2008
What is error code SC on Samsung washer?
If your washing machine malfunctions, you may see an information code on the display.
Please see below for possible solutions for each information code. If you have tried all of these and are still experiencing problems, you may need to contact the Samsung Service Centre to arrange an engineer visit.
CODE: 1E, E7, 1C (Water level sensor)
Action:
Switch off the appliance at the mains then wait 30 seconds. Switch appliance back on again and start a new program. If the information code remains, contact the Samsung Service Centre.
CODE: 3E, 3E1, 3E2, 3E3, 3E4, bE, 3C (Motor) Action:
Apr 09, 2017 | Samsung Washing Machines
HOW do I get rid of a code on my dryer or is it EL8,what part repairs this code.
Good Afternoon Butchie111, thank you for your post!
From the information you have provided your Frigidaire dryer is displaying an error code of "EL8" and it will run for 30 seconds then beep the code. I am showing that "EL8" is an invalid code. It could be a possible miscommunication error so I would suggest performing a reset on your dryer and you can do that by disconnecting power from your dryer for roughly ten minutes. If that does not help your issue could you please provide me with the new error code or inform me if your dryer still displays "EL8"? I look forward to your response. -Matt
Feb 22, 2015 | Frigidaire Dryers
How to reset error code on 2008 accord v6
Soft reset disconneting the negative battery cable few minutes; if the code come back again, its possible that you have some problem with the sensor, wires or harnesses connections.
Keep in mind that sometimes will need OBD scanner tool to reset or delete all stored codes.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Sep 04, 2012 | Honda Accord Cars & Trucks
Reset error code on 2008 accord v6
Sep 04, 2012 | 2008 Honda Accord
Our power went out due to the snow storm, and the display panel shows 88 on each side...how do I reset this...will this cause the fridge temp to go up?
From http://www.samsung.com/us/support/supportMain.do
Your refrigerator is equipped with an onboard diagnostic system. If the diagnostic system detects a fault, it will display a specific line segment on you refrigerators LED display. If your refrigerator is displaying an error code, please note the error code, and reset the refrigerator by unplugging the refrigerator for 30 seconds. When the refrigerator is plugged in, it performs a self diagnostic check of the various sensors and functions. If the error code reappears your refrigerator will require service. Please click the "Create Online Service Request" button below this article to initiate the service process. After a power outage the display panel may start blinking "88 88." If you unplug the unit for 30 seconds then plug it back in the display will return to normal operation after several hours. The power outage/surge can cause a communication error between the circuit boards in the unit. It can take several hours for these boards to stabilize.
If the display does not reset, go to the Samsung Support link above, enter your model number, and follow the prompts to request a service ticket.
Good luck, and if this helps, please rate my answer!
Feb 02, 2011 | Samsung Refrigerators
Flasshing five times a orange leds canon pixma 4500
If the LED is blinking 5 times it means ASF (cam) sensor error [5700].
To clear memory, you must reset it.
You can try and clear the error by holding down the power button and waiting for it to turn off then wait 30 seconds and turn it back on. {you might need to unplug it to get it to turn off}
Or,
Hold down the stop/reset and then push the power button while the printer is on. The printer should shut off then wait 30 seconds and then hold the stop/reset again and push the power button and the printer should turn on with the error cleared.
Hope this helps.
Mar 25, 2010 | Canon Pixma iP4500 InkJet Printer
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Samsung washing machine reset code
    i have samsung
    6 kg WA80HAG silver nano
    dear'
    plz help me to reset washing
    machine
    thanks
    Mar 18, 2008 | Samsung WF337AA Front Load Washer
    Feb 22, 2008 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
    Samsung rs2578sh
    Yes, you have a faulty defrost heater or thermal fuse, the fault will re-occure within a few weeks. Regards Advisor
    Aug 22, 2007 | Samsung RS2578BB Side by Side Refrigerator
    Kitchen Ranges Logo
    60 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    paulcarew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
