Question about Aurora Electronics Office Equipment & Supplies
HOW DO I CHANGE THE INK IN AURORA PR190m CALCULATOR
PR190M
How do you change the battery
see the back of your product...it contains the battery location which needs to be unscrewed
Oct 29, 2013 | Aurora Electronics HC108X Basic Calculator
How are numbers in scientific notation entered in Aurora SC150X calculator
Look for a key that is marked EE, or Exp, or x10^x. To enter a number in scientific notation, you enter the decimal part, then press the Enter Exponent key, followed by the exponent. If exponent is negative, you precede it with a press of the change sign key (-).
Once a number is entered there is no special treatment: multiply it divide, or add it.
Mar 16, 2012 | Aurora Electronics SC150X Scientific...
How do you use the "Pi" sign on the Aurora
It depends what FORMULA ur going to use it! Pi=3.1416, mostly used in measuring radius and circumference!
Nov 10, 2010 | Aurora Electronics SC150X Scientific...
What battery does the Aurora Scientific Calculator SC150X take?
The SC150X is powered by 2 AG-10/389 batteries. Take out the screw on the back panel and pry the case halves apart. After installing the new batteries and reassembling the case, press the 'reset' with a small paperclip while pressing the OFF button.
Aug 28, 2010 | Aurora Electronics SC150X Scientific...
Aurora db453b calculator manual
http://www.retrevo.com/support/Aurora-DB453B-Calculators-manual/id/9955ci153/t/2/
youshould be able to download from here you will have tosign up but it should be worth it
Dec 20, 2008 | Computers & Internet
Changing Ink in the Canon P170-DH Printing Desk Top Calculator?
The manual for the Canon P170-DH calculator is found on the canon usa web site. It is 22 mg in size, but prints out to 4 pages in English, Spanish and French.
According to the manual: Use only Ink Roller CP-13.
There are four figures showing the steps, so you'll have to imagine it.
1. Turn power switch off.
2. Remove the printer cover (Figure1).
3. Hold the tab of the ink roller. Lift the ink roller out of the base (Figure2).
4. Insert the new ink roller into position. Push down on the center of the ink roller until it locks into place (Figure3).
5. Replace the printer cover (Figure4).
Print out the manual for yourself and put it in a safe place.
Nov 20, 2008 | Canon P170-DH Calculator
35 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
k24674
Jim Keysor
ka4iup
ka4iup
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
