Question about IBM Correcting Selectric III Electric Typewriter
When key is depressed it adds a "dash" to type
Double trips when key touched
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 96 Answers
Your machine has a mechanical part that is either just sticking or needs a small adjustment. The dash (or underscore in upper case) is the character that is preselected when typing. When you hit another character, the machine either adds units or takes them away to give you that specific character. Your machine is not resetting fast enough so it is giving you an extra cycle and that is why you get the dash. A trained IBM technician should be able to resolve this issue for you.
Posted on Feb 24, 2015
How do I disable the touchpad
the touchpad can be disabled in the bios.
Aalternatively type up your messages in an email as these are saved instantly as a draft after one stops typing for a moment.
Feb 20, 2015 | HP Compaq 6730s Notebook
Tip
2008 Highlander Maint Req'd reset proceedure
This is the reset proceedure for a 2008 Highlander with a key-type ignition:
Turn the key ON, do not start the engine.
Look at the odometer, and verify that it displays "TRIP A". If it is on "ODO" or "Trip B", press the black stick next to the odometer to read "TRIP A".
Turn the key OFF.
Press in, and HOLD the black trip meter reset button, hold it IN.
DO not release it.
Observe the Odometer display. You will see 5 dashes, then 4, then 3, then 2, then 1 dash, and finally, 5 zeros. Then, whatever number that was displayed on "TRIP A" will be re-displayed..
Now release the black trip meter reset stick.
This completes the reset procedure, and it will be back on in 5,000 miles, to remind you of you next oil change.
on Nov 17, 2008 | 2008 Toyota Highlander
My speedometer doesnt work
Without key in ignition, depress and hold down the trip reset button by the speedometer until a code appears. Release button and the gauge cluster will go through a self diagnosis ( needles will move around and dash lights will blink). When needle returns to zero and lights go off, diagnosis will be completed and speedometer will be reset. Very easy fix.
Feb 24, 2014 | 2002 Dodge Neon
Speedododmeter don't work all other gauges do
Without key ignition, depress and hold down the trip reset button by the speedometer until a code appears. Release button and the gauge cluster will go through a self diagnosis ( needles will move around and dash lights will blink). When needle returns to zero and lights go off, diagnosis will be completed and speedometer will be reset. Very easy fix.
Feb 21, 2014 | 2000 Dodge Caravan
Maintenance required on dash board how can i reset it please help
    • 1
      Sit inside the driver's seat of the Honda Accord and close the driver's side door. Any interior lights on can prevent the maintenance required light from resetting properly on some year models.
    • 2
      Insert the key in the ignition.
    • 3
      Depress the odometer/trip button located beneath the odometer on the instrument panel. Hold the button down.
    • 4
      Turn the ignition key two clicks forward to the accessory power position. This is also known as the key-on/engine-off position.
    • 5
      Continue to hold down the odometer/trip button for up to 15 seconds until the maintenance required light goes out. On some Accord models, the maintenance required light may blink once before going out.
    • 6
      Release the odometer/trip button and then turn the ignition key to the off position.
    • 7
      Start the Honda Accord to ensure the maintenance required light is no longer illuminated on the instrument panel. If it still is, the reset procedure did not take and you'll need to repeat the procedure.
  • Apr 13, 2011 | Honda Civic Cars & Trucks
    Turn off the mainttenace light after you change the oilhow do you
    Turn the key OFF.
    DO not release it.
    Jan 04, 2010 | 2008 Toyota Highlander
    Maintenance Lamp
    Here's how you reset your maintenance light.
    To reset the light,
    Turn the ignition on
    Make sure the odometer displays "ODO"
    1.Turn the key off
    2.Press and hold down the same button you use to get to "ODO"
    3.Turn the key back to ON ( while still holding down the button)
    4.Hold the button in until all the flashing lines on the odometer go away and the bunch of "000000" shows up and the maint reset light will turn off.
    Your'e done.
    If this doesn't work, you would have to try it on "trip A" instead of "ODO".
    Oct 03, 2009 | 2006 Toyota Tundra
    Maint. light reset
    Turn the key OFF.
    DO not release it.
    Jan 02, 2009 | 2008 Toyota Camry
    Maintenace light
    This may sound difficult, but it is really simple; the reset takes 30 seconds; here you go:
    Get in the car.
    Turn the key ON (do not start it)
    Observe the odometer. Is it on ODO (total mileage driven?
    If not, depress the reset stick by the speedometer from trip a or
    trip b until ODO is shown, and the total mileage traveled is displayed.
    Turn the key OFF
    Press and HOLD the reset stick on the instrument panel (trip a/trip b button), and HOLD it until advised to release it.
    Turn the key ON (do NOT start the engine)
    Observe the odometer: You will see 5 dashes, 4 dashes, 3 dashes, 2 dashes, and the 1 dash, followed by 5 zeros. The total mileage you started with will be redisplayed.
    You may now release the reset stick.
    Start the engine, the maint light will be reset.
    What procedure does: It adds 5,000 miles to your odometer, and the light will come back on in 5 K miles.
    The graciousness of a FixYa rating for my assistance to you would be greatly appreciated! Thanks for choosing FixYa!
    Dec 09, 2008 | 2007 Toyota Land Cruiser
    Resetting maintenance light for toyota yaris
    Turn the key on.
    Is it displaying ODO/total miles traveled? If not, depress the trip reset button until ODO is displayed
    Key off
    Press & hold the trip reset button, keep pressing it until advised to release it.
    Key on
    Observe the odometer display
    you should see 5 dashes, then 4, then 3, then 2, then 1, and then 5 zeros, and then the mileage you started with.
    Release the button.
    You are done,
    If you do NOT see 5 dashes, 4-3-2-1, set the trip meter to "trip 'A'"
    and retry as instructed above. Some Toyotas use either method.
    Sep 24, 2008 | Toyota Yaris Cars & Trucks
    IBM Correcting Selectric III Electric Typewriter Logo
    60 people viewed this question
    Top IBM Office Equipment & Supplies Experts
    James Cagle
    James Cagle
    CheckitRight
    CheckitRight
    Jim Keysor
    Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
