Question about Teac AG-790 Receiver
Protect message system shuts down
How do I reset? I keep getting "prot" message when trying to turn unit on. It keeps shutting down..is not overheating.
The prot is the protection warning message that the amplifier defaults to when there is a problem. Try this: Turn the volume control WAY down. Disconnect your speaker leads from the rear of the component. Turn the unit on and see if it still protects itself. If the protection still comes on the amplifier is bad and needs serviced. If it appears OK, then connect one pair of speakers at a time to see which set has the problem. Usually the wires not the speakers themselves are the trouble.
Dec 05, 2010 | Samsung HTC550 Theater System
Samsung ht-x30 sutting down protection error
My samsung shuts down with "PROTECTION".Help me to solve the problem.David ilomo.
Dec 05, 2009 | Samsung Audio Players & Recorders
I get a PROTECTION message on my system. What is
the unit goes into auto protection mode whenever there is a shorted pair of speaker wires. check all the connections carefully to make sure no wires are touching any others on the back of the main unit and at each speaker
Nov 03, 2009 | Samsung HT-TX72 Theater System
Protection and shut down.ht-tx35
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotation
Jun 09, 2009 | Samsung HT-X40 System
Shuts down by itself
If there are no speakers connected and you still get the protection message, there is a problem internally. Exchange the unit while you can. The typical parts required to fix this problem will be over $75 US.
Dan
Mar 25, 2009 | Samsung Audio Players & Recorders
Toshiba home theater SD-KT50SU shuts off "PROTECTION"
Ok what this means is that some wires are touching in the back of unit causing a short (your system is protecting itself) look for wires touching and make sure its hooked up right
This should fix ya!
Dec 13, 2008 | Sharp XLDV60H Shelf System
Protect mode
i try to turn the stereo on a message saying "protect" comes up and then it shuts off
Apr 28, 2008 | JVC HX-D7 DVD Compact Stereo Audio / Video...
Protection displayed and shuts off
The protect message indicates that the output amp section has a problem. Normally this requires the replacement of the output transistors or the output amp pac. Expect the repair cost to be about $20-$60 for parts plus the local labor rate.
Dan
Mar 22, 2008 | JVC HXC6 500-Watt Stereo System with 5-CD...
"Protection Error"
the DVD is blocked in PAL system, ¿ How I can the DVD in NTSC system ? the menu is blocked. thank
Sep 24, 2007 | Toshiba SD-43HTS System
Teac AG-790 Receiver Logo
43 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
