Question about Precor EFX 833 Commercial Series Elliptical Fitness Crosstrainer
Is there a reset button for the Precor EFX 833 Eliiptical?
Where is the reset button?
  • 13 Answers
SOURCE: i pulled the plug on my precor efx and now it wont
yes, we can help. 281-469-8506 www.nashsfitness.com
Posted on Aug 10, 2009
SOURCE: looking for repair manuals and error codes for
Could you please advice about ERROR 29 fo C956i/C966i treadmill.
Posted on Mar 04, 2010
maxtreadmill
  • 832 Answers
SOURCE: belt replacement for precor efx 645 verison 1
You may have to purchase the belt from a Precor dealer in you area, if you don't have one then call Precor directly @ 1-800-347-4404 and they will help you. Most of these part have not hit the secondary market yet and Precor pretty much call the shots.
Posted on Mar 13, 2010
dcramer531
  • 1654 Answers
SOURCE: How do I replace the
You may have to purchase the belt from a Precor dealer in you area, if you don't have one then call Precor directly @ 1-800-347-4404 and they will help you. Most of these part have not hit the secondary market yet and Precor pretty much call the shots on whom the sell parts and support to.
There is a place on line to get some of these, it is. www.treadmilldoctor.com/Products-Services2/precor-treadmill-belt.
The manual can be found at. fitness.manualsonline.com/ex/thread/view/idThread/2141832
This place has manuals and user manulas along with support and some partswww.shopwiki.com/Precor+EFX+5.171 I believe this unit has a 10 yr warranty with it and the part in question may be covered by them. There is also a 1 year part warrant for other parts, I just don't know what parts they are covering for the 10 yr.
Posted on Dec 26, 2010
ercupa190
  • 12223 Answers
SOURCE: precor efx 546 error.
please follow this steps and fix it. God bless youError 43 - Zero Switch not FoundDescriptionThe C944 and several versions of C96X used a lift position identification system that did notutilize a potentiometer.Instead, it utilized a switch that would be physically actuated by the lift when the lift was in thezero incline position. A revolution sensor counted lifted motor revolutions to determinesubsequent lift positions. In addition two limit switches where used to remove power from the liftmotor if the lift moved outside of it's normal range.When the unit was powered up the lift would start to hunt for the zero switch. It would first go up4% (maximum lowest physical position was -3%) if it did not find the zero switch or it hit the upperlimit switch, it would then go down until did find the zero switch. When the zero switch waslocated it would stop, the system would then know its physical position and be prepared tomonitor the revolution sensor. If during this power up procedure the zero switch was not found anerror 43 would be displayed.Possible Causes1. The lift position actuator does not physically operate the zero switch.2. The lower PCA is bad.3. The zero switch is bad.Possible Remedies1. There are several physical problems related to the lift platform mounting or the plate the zeroswitch is mounted on that can cause the actuator knob to miss the zero switch as it movespast. Repair the lift platform mounting, repair or replace the lift switch mounting plate asrequired.2. The lower PCA provides a 5 VDC power source for the zero switch. You should measure 5VDC across the zero switch when the zero switch is activated. If the reading is significantlylow, remove both wires from the zero switch and repeat the measurement across the wiresremoved from the zero switch. If the reading is still significantly low, verify the zero switchwiring. If the wiring is intact and correctly connected, replace the lower PCA.3. Move the lift to position where the zero is switch is not activated and remove power from thetreadmill. Remove both leads from the zero switch and measure the zero switch with anohmmeter. The zero switch should read very near 0 ohms. While measuring the zero switchwith the ohmmeter, activate the switch by hand, the reading should change to infinite (open).If either of the above readings are significantly incorrect, replace the zero switch.
Posted on Mar 15, 2013
My Precor EFX 833 elliptical shuts off in the middle of use m, I’ll be in the middle of a workout program and it will turn off
If you are using Electrical power coming from outlet box 110vac, The Power supply inside is defective. Or if you are using batteries, has the same problem with the converter-power supply, Repair or replace.
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Oct 26, 2017 | Precor Exercise & Fitness
Can I adjust the stride length?
Precor EFX 546 Version 1 Elliptical Trainer (Refurbished)
www.amazon.com > ... > Elliptical Trainers
Amazon.com, Inc.
Rating: 4.3 - ‎9 reviews
Working out on an elliptical can burn as many calories as working out on a treadmill. ...allowing you to go forward and backward, as well as adjust stride length to target ...The Precor EFX 546 allows you to stride smoothly while holding the ...
EFX® 546i Elliptical Fitness Crosstrainer™ ' Precor
www.precor.com/en-us/.../efx-546i-elliptical-fitness-crosstrainer-33
With the unique Precor CrossRamp® technology, users can alter the path of the EFX®546i between 13 and 40 degrees in both forward and reverse stride motions, cross ...Excellent stability and freedom of movement for users of all sizes.
FAQ - Precor
Dec 28, 2015 | Precor 546 Elliptical
New precore 5.33 elliptacal squeaks
bar soap on the ramps where the wheels travel until the shine wears off the wheels. I see it at warranty calls every week
Mar 24, 2014 | Precor Efx-5.33 Elliptical Machine...
Precor efx 576i resets everytime user changes direction
Does the lift work? If not, the battery is dead. Replace it.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
Feb 17, 2014 | Precor Efx 576i Experience Elliptical...
Replacing battery
Warning Notice for Battery Installation of certain Precor Ellipticals This notice provides details about the battery replacement procedure that should be considered by anyone performing this repair. Following is the warning about the battery installation for certain models of the Precor ellipticals.
Precor Elliptical Models Affected:
  • EFX C524 with serial#s beginning I7, K7, LH, SW, SX
  • EFX C546 with serial#s beginning NF,SZ, IK, IL, IU
  • EFX C546I with serial#s beginning X8, XG, Z2
  • EFX C556 with serial#s beginning NG, SY
When replacing the battery on your Precor elliptical it is important to make sure that the battery terminals are not allowed to make contact with the metal surface of the battery bracket. **Damage to the battery will occur**.
Electrical tape can be wrapped around the battery terminals to prevent them from making contact with the metal surface of the battery bracket.
Battery replacement on the EFX C524, EFX C546, EFX C546i and EFX C556 instructs you to remove the (4) screws that fasten the battery bracket to the frame. This allows you to turn the lower PCA and battery assembly away from the frame so you can slide the battery out of the battery bracket. It may be necessary to remove the nut that fastens the front retaining bracket or "L" bracket in order to slide the battery out of the battery bracket.
Warning Notice for Battery Installation on Precor EFX Ellipticals
Feb 07, 2014 | Precor EFX 546i Elliptical Version 4
How do I replace the battery on efx 546i
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Jan 01, 2014 | Precor EFX 546i Elliptical Version 4
How do i change the battery on a precor efx 5461
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH Warning Notice for Battery Installation of certain Precor Ellipticals This notice provides details about the battery replacement procedure that should be considered by anyone performing this repair. Following is the warning about the battery installation for certain models of the Precor ellipticals.
Dec 25, 2013 | Precor EFX 546i Elliptical Version 4
How to repair a 546 efx precor
Assuming the buttons are working, the numbers change on the display, and the incline works, it may be the lower circuit board or the generator. If it is a very old unit, it may be the electromagnet or the data cable that connects the two circuit boards.
May 08, 2013 | Precor Efx 546 Elliptical Version 2...
Precor efx 556
Here you will find parts and other information for the Precor EFX 556.
Repair Parts for Precor EFX 556 Ellipticals SPORTSMITH net
Jan 07, 2012 | Precor EFX 546i Elliptical Version 4
Precor EFX 833 Commercial Series Elliptical Fitness Crosstrainer Logo
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Howard
Howard
Ross Metcalfe
Ross Metcalfe
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
