Question about Roland Versa Art RS 640 64-inch Printer
Stripy lines across image when using a block of colour. Any suggestions?
Perfect printing on full images but single block of colour gets stripes
Printer prints stripes through images
your printer needs to be cleaned. Use the cleaning mode in windows printer HPOFFICEJET
Sep 18, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Colour printing comes out in lines across the whole page
Is the nozzle is perfect? i dont think so. But, if you print with best/photo mode is ok.
Jun 01, 2009 | Canon i850 InkJet Photo Printer
White vertical stripe on color images when they're printed
You may have some dust on the imaging window (printer head). Remove the toner cartridges and clean it with some tissues.
Apr 28, 2009 | Konica Minolta magicolor 2430 DL Laser...
Dark Blurry Ink Line
When I print darker color images I get what I call Zebra stripes across the picture on a slant about 1/2 inch apart. Changed the toner and the drums are at 45% capacity. Any suggestions. Thank you.
Sep 03, 2008 | Konica Minolta magicolor 7450 Laser...
Lines on page
The effecds like 'banding' very often this happens when the ink is running low.
When you say 'full color' do you mean at the 'best' [i.e. most ink used] setting or the you are printing the image on a full sheet of paper?
How do your images appear when you print small, say wallet sized, single image only on the page? draft mode? Gray scale?
Jul 16, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
Paper feed and colour problems with Konica Minolta bizhub c250
any stripes are usually caused by imagining unit, first use the tool in front cover to clean laser glasses. inspect IU drums for stripes maybe youll need to change them. is the page coming out ok, but picture is printed crookedly ?
Apr 17, 2008 | Konica Minolta bizhub C250 All-In-One...
Horizontal lines
Depends on whether the "lines" are colored or just blank areas missing in the print . If it is blank areas , then most likely the laser scanner is dirty and the glass needs to be cleaned . If it is colored lines , then you most likely have a defective drum .
Jul 18, 2017 | HP LaserJet 1500L Printer
Roland Versa Art RS 640 64-inch Printer Logo
16 people viewed this question
Top Roland Office Equipment & Supplies Experts
Michael Harrier
Ravi
Chas Peters
Level 1 Expert
Are you a Roland Office Equipment and Supply Expert? Answer questions, earn points and help others
