Question about Video Game Consoles & Games
Factory ball level 10
Are all ping pong balls the same?
No. There are a wide variety of balls that all serve a different purpose. The types are as follows: fun/novelty balls (great for children & recreational play), practice balls (good for beginners), one star balls (good for school use), two star balls (good for most other styles and levels of playing) and finally there are three star balls (highest quality, used at a professional level).
Jul 29, 2012 | Sport & Outdoor - Others
How to reboot to reset password
The term "reboot" simply means to restart a device.
What you're asking for is "how do I do a factory reset of my router?".
In that case, most home routers have a "reset" button on the back that you have to push using something small like the tip of a ball-point pen.
Use the ball-point pen tip to press the reset button down for 10 seconds with the router still plugged-in to the power supply. While still holding the reset button down, unplug the router's power supply and wait 10 seconds. After that 10 seconds is up and while still holding the reset button down, plug-in the power supply to the router and wait yet another 10 seconds and then release the button.
This will return your router to factory defaults. Unfortunately, you didn't tell us the make or model number of the router, so I can't tell you for certain the URL to use to set up your router again.
Most likely it is either http://192.168.0.1/ or http://192.168.1.1/ with some default password.
Dec 20, 2010 | Computers & Internet
Front end
Ball joints First you would start off by unloading the ball joint by jacking up the lower control arm to see if there is indeed tire play indicating bad ball joints, raise the bottom of the tire with a pry bar and see the amount of play that you have thru the ball joint. You can also see if ball joints are bad by looking at the grease zerk on the bottom...BAD ball joints will have the zerk base level with the control arm...There should be atleast .050" sticking out To take apart mark and count the torsion bars. Undo the torsion bars. Remove all components in the way such as your brakes calipers (tie them up so you dont ruin the brake hoses), rotors, 4 wheel drive. Remove the steering knuckle. Check your spindle and bearings while you are in there to see about wear and such. Several ways to get the rivits out...Drill out the center of the rivit...take a dye grinder and cut a X in the head of the rivit and knock out with a hand chissel...or use the tourch (becareful due to the fact of ruining the control arms)...or use an air chissel (cutting an X in the rivit head will aid in removal. Replace with high tension bolts upwards as of grade 8 and use teflon nut with some locktight. Replace steering knuckle and the rest of the components removed in the disassembly. Tighten torsion bars to previous spec. Take vehicle in for an alignment due to having fresh ball joints in. No need ruining new ball joints after vehicle was used to driving with loose ones in
Jul 05, 2009 | 1998 Chevrolet S-10 Pickup
Was vacumning watershut off switch would not start again water level was well below the ball
left the top assembly which includes the motor out side in the sun for 2 days and this am it started. cwcb
Aug 21, 2008 | Vacuums
TV Volume settings
These are all settings that are put in by the factory and cannot be changed.
Nov 28, 2007 | Televison & Video
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
