Question about Tatung P46ACTP 46 in. Plasma Television
Light goes green but no display.
Hello and thanks in advance! I have a Tatung P46 Plasma TV. The TV will come on with amber light when switch on rear is applied and 2 relays click on and maybe back off. After I hit the power button, the amber light flashes and then I get a constant green light (no relay sound). There is never anything on the screen. I checked the 4 fuses and they are fine.
I have searched to the end of the internet and cannot find anything on a Tatung P46. I found Vizio P46 but not the Tatung. I would like a service manual so I can test the power supply. From what I see it has a good AC input and the red and white output shows 4.2VDC.
Any help at all will be very much appreciated!
Definitely Power Supply Board. Check carefully for open 1/8 watt metal film resistors. They wont show signs of overheating but they can be open anyway. I've never been able to find a print either. Once you do find open resistors make sure you measure for shorted components in the associated circuit.
Posted on Oct 20, 2009
Getting a message that hdmi is blocked?????and have several blinking amber/green light turns red and tv shuts off....help please WD-65737
Hello!
Please, read my previous solution for WD-65.....
you'll find the answer to your questions.
good luck,
thanks,
Alex.
Mar 06, 2012 | Mitsubishi WD Televison & Video
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
Tatung monitor Power light shows yellow light.
It sounds like your resolution or refresh rate is out of reach for your screen.
Restart your computer (even if it will be manually unplugging the power cable)
If you have no display while your computer starts up; you might have a hardware failure. Swapping your screen out, or plugging it into another computer (that works) will confirm if this is the issue.
If you can see the computer starting up you can press F8 (on your keyboard) continuously just before Windows can start.
Select "Safe mode" so that you will have the basics of screen settings.
Now you can go to control panel, display and click on the Settings Tab at the top. Change your settings to a rather default "1024x768" resolution and change your referesh rate to nothing more than 75hz under the advanced icon.
Hope this helps!?
Jul 07, 2009 | Tatung L17AMTN 17" Flat Panel LCD Monitor
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
Green light,nothing else
hi.have a look at the 2 main smoothing caps-the large ones-rated at 1500uf,200v.these temd to dome out on the top and can cause this problem.just done one of these sets,but badged up as a el4610.(psu type mpf7701)board nos.are c556/c557.let us know how it goes...
Apr 13, 2009 | Televison & Video
TATUNG P42HSMT
Also have a TATUNG P42SMT. Problem is the screen starts to turn green shortly after turning it on, then the screen goes black.
Sep 01, 2008 | Tatung P42HSMT 42 in. HDTV-Ready Plasma...
Pioneer PDP-435PG
I buy receiver of the plasma pdp 435pd my e-mail it is sergiofleitas@yahoo.com.ar
Apr 20, 2008 | Televison & Video
Plasma wnt stay on
I have had this problem in some models of plasma sets before. In most cases the power supply and main drive boards had to be replaced. In a small number of cases the failure was the screen itself.
In all cases, the cost of the repair was expensive. For the screen failure, the set was scrapped.
Jerry G.
Dec 30, 2007 | Hyundai ImageQuest HP4240 42 in. Plasma...
PLTV-26
WHEN I TURN ON MY TV THE LED IS RED THEN GREEN AND GOES BACK TO RED AND NO IMAGE. WHAT COULD IT BE, i ALSO DID A HARD RESET BY REMOVING THE WIRES AS THE TECH HAD SAID AND NOTHING.
Dec 11, 2007 | Protron PLTV-32 Television
Tatung P46ACTP 46 in. Plasma Television Logo
388 people viewed this question
Top Tatung Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
CoppellTVRepair.com
Are you a Tatung Televison and Video Expert? Answer questions, earn points and help others
