Question about Russell Hobbs RH1042 Frontload Washing Mashine
Can't get my machine to start after programme has finished
Machine won't restart when I turn it to 0 which is off position I have to switch it off at the plug for the start button to come on so I can choose my programme and press play
    New Friend:
    Problem Solver:
  • 7 Answers
I find quite often I have to turn it anticlockwise for it to allow me to start it again, or wait for a short while (my plug is behind the machine)
Posted on Oct 21, 2016
How do i reset washing machine AEG 64840
You can choose the right programme for any type of laundry following the descriptions on the washing programme tables (see «Washing Programmes»).
Turn the programme selector dial to the required programme. The programme selector determines the type of washing cycle (e.g. water level, drum movement, number of rinses) and the washing temperature according to the type of laundry.
The pilot light of button 8 starts blinking.
The selector dial can be turned either clockwise or anticlockwise. Position "0" to Reset programme/ Switching OFF of the machine.
At the end of the programme the selector dial must be turned to position "0", to switch the machine off.
If you turn the programme selector dial to another programme when the machine is working, the yellow pilot light of button 8 will blink 3 times and the message Err is displayed on the display to indicate a wrong selection. The machine will not perform the new selected programme.
Jan 15, 2015 | AEG Washing Machines
ASCO Washing Machine - AEA 12001
This is normal on most machine. Once the machine finished washing or you switch off the maching manally, you will have to wait for around 2 to 3 mins for the mechanisim to unlock the door.
Apr 07, 2014 | Asko Washing Machines
F 14
counter problem
1- switch the machine off
2- key { 0 } + { 8 } together & switch it on .. keep pressing ( 0 + 8 ) for 8 seconds
3- will see a new menu .. key [ 389 ] then [ start ]
4- key [ 388 ] then [ start ]
5- restart the machine
Jul 05, 2011 | Toshiba E-Studio167 Copier
Switch on it shows "test" and cannot programme
It depends on what date the machine was manufactured. The date should be on the plate which is probably in an awkward position on the back ;-0(
Date code 39 March 2005
Press start/cancel until ALL LEDS are lit
Press both start/cancel AND on/off together until 'dOFF' is displayed
Date code 39 March 2005 to date code 42 June 2005
Press the cancel button and the machine should return to normal
Date code 43 July 2005 onwards
Press both start/cancel AND on/off TOGETHER with top left option button until 'dOFF' is displayed.
John C
Mar 22, 2011 | Hotpoint Aquarius WD640 Front Load...
Programme not finished on/off button flashing won,t restart
As you do not specify model, itis difficult to give you an accurate answer to your problem.
If it has a start/cancel, or reset button, then switch washer off, wait a few seconds, then switch on again.
Press and hold start cancel button for 3 seconds, and then try to programme it again.
This is not guaranteed to solve the problem ,as I say, you do not specfy the model number.
Feb 02, 2010 | Hotpoint Washing Machines
this sounds like a door lock issue if the machine does not detect the door has closed properly you will get the same symptoms, try slamming the door shut (not too hard) if machine starts but then does the same thing next time you use it will need new lock it will have gone out of calibration.
Oct 14, 2009 | Bosch Classixx WFL 2066 Front Load Washer
The water plus light is on what does this mean
To switch off the fault indicator: switch the washing machine off with the
I-On/0-Off button and turn the programme selector to Finish.
You gave no model number but here is the site for instructuons.
Try the reset first.
Aug 19, 2009 | Miele Washing Machines
Annoying beep when wash cycle finishes on bosch classixx 1400 express
Starting with the rotary switch in the off position, turn it one click clockwise, press and hold on the bottom right hand button, turn the rotary switch one more click CW and release the button. The number displayed is the volume for button presses, press the centre right hand button to increase/turn off (0). Turn the rotary switch one more click CW to select end of cycle volume, agjust and set the rotary switch to off to leave set up mode.
Dec 06, 2008 | Washing Machines
Press "end of cycle" for 3 seconds, & tell me what happened.
You will rate me also.
Jan 19, 2008 | Indesit WA 115 Front Load Washer
Indesit W1A111 starts cycle when selector set to "off"
many indesits have a memory on board, set the timer to off position, turn on the mains press start let the machine finish what it is doing, and it will reset normally, turn off at mains for a few minutes can also do the trick, it sounds like one of the option buttons was pressed and you didn't let the timer finish its course,
Aug 29, 2007 | Indesit W 123 Front Load Washer
Russell Hobbs RH1042 Frontload Washing Mashine Logo
29 people viewed this question
Top Russell Hobbs Washing Machines Experts
ray gallant
Are you a Russell Hobbs Washing Machine Expert? Answer questions, earn points and help others
