Question about Kenwood KMR-355U USB/CD Receiver
E4 after leak the machine is showing E4 how do I reset?
How to get into bottom section of dishwasher to find a leak
i had the e4 code today. fixed it, thank god.
Sep 09, 2016 | Dishwashers
Hi... I just bought Electrolux Dishwasher ESF2433W. When i first time turn it on, light at "Normal" button keep on flashing with beeping sound. After checking the trouble shooting manual, it actually refer...
E4 Overflow
Sometimes during trasport it is possible that styrofoam float mechanicaly activated overflow microswitch. So, you should check complitely overflow system.
At any time, if overflow micro-switch act and keep for longer than 2 seconds, the E4 would occur. When E4 occurs, the drain pump will run until flowmeter keep motionless for 2 minutes (if the model with the pressure switch (83/63),drain pump would run till the pressure switch reset and continue draining for 60 seconds.) and all the other components will be stopped immediately. At the same time, the buzzer will alarm for 30 seconds and error 4 will be shown. Note: Priority level of E4 is the highest. E4 operation is valid after other error operations have done. When E4 operation has done, all the others are invalid.
Dado
Feb 20, 2015 | Electrolux Dishwashers
Error e4
someone activated 4 zone reset thermostat
Jul 11, 2013 | Coleman York Control Board 03101237000...
E4 showing on the panel KDW60X10
The Kenwood KDW60X10 shows the E4 code when there is a water leak or a problem with the float switch (or it's PCB board connection). This could be a leak at the tank, the hose, or that the drain pump's anti-flooding system has been tripped.
Disconnect the dishwasher from power and the water line. Look for signs of a water leak under the unit. If the hose is leaking, you may be able to replace or reseat the drain hose. (Also make sure that there are no kinks in the hose.) Note: sometimes the leak is in the plastic where the drain hose connects to the dishwasher. That is harder to fix.
If the tank is leaking, replace the entire unit. For the other possible problems, you should consult a repair tech to narrow down the issue. Float switches are easy enough to replace; the PCB board and the anti-flooding system are not as easy to reset.
The manual for your dishwasher is available here: http://www.partmaster.co.uk/company/partmaster/manuals/Kenwood%20KDW60X10.pdf .
I hope this helps.
Apr 12, 2012 | Kenwood Dishwashers
Has E4 showing on machine have turned off and on but still reads E4
  1. E-4 ..........short of as or no gas. Refill gas after leak testing.
Dec 14, 2010 | Soleus KY-34 Portable Air Conditioner
Belling dishwasher IDW604 error code E4 on control panel
I found the solution myself. Underneath the machine, there is a plate. On the plate, there is a float and a microswitch, when the water leaks onto the bottom plate it raises the float and activates the microswith which shuts down the machine and shows E4 on display. To get rid of the fault, you have to pull out the dishwasher, then tilt it, and drain the water from the bottom plate. Also make sure that there is no leak in the internal piping, if there is, the fault will come back as soon as the recess in the bottom panel fills with water.Hope it helps.
Feb 25, 2010 | Dishwashers
Belling IDW604
Jan 20, 2010 | Belling 24 in. IDW603 Built-in Dishwasher
Error code e4 flashes on belling dishwasher idw604 , washer is empty cant get any programs to work
Dec 27, 2009 | Dishwashers
E4 error message
take off two black covers on bottom front of machine and mop up or soak up any water you feel or see at very bottom of machine by a polystyrene float this will fix it
Dec 27, 2007 | Baumatic 23 in. BDW13 Built-in Dishwasher
Kenwood KMR-355U USB/CD Receiver Logo
29 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
