Question about GoVideo Go Video DVD/VCR Combo
Dvd tray won't open
My dvd tray won't open.  Hasn't been used in several months. I can hear it trying to open? Any suggestions?
  • 2 more comments
  • sue322 Nov 24, 2007
    I have the Sony DAVC450. It has a 5 disc changer, and no door will open. It says "open", and I hear whirring.
  • kj209 Nov 25, 2007
    i am unable to open the tray to load a cd. it keeps telling me loading. help!
  • Anonymous Jan 31, 2008
    I'm having the same problem. My player is only a couple years old. Drag.
  • JohnJC May 01, 2008
    I have a Insignia IS-DVD040924I vcr/dvd combo player. I can not get the tray door to open. When I push the button to open the door to insert disc the tray will not open. It says trying to read disc and says no disc is in the tray. I mannualy open the door and see a tiny black belt broken inside. Can you give me some advice of what to do and where to find a replacement belt. Also, Is this easy to fix yourself?
I've had the same problem on one drive first ,then the other. For some reason if you keep a disc in the tray it will open and close fairly normally.Sometimes I have to give it a helping hand to close. This isn't a fix ,but it might help you to get your projects done.
Posted on Jan 30, 2010
The belt that opens and closes the drawer is too old and likely stretched out or otherwise deformed..
it's a $3.00 part however i'm having difficulty finding the part number to find an exact match, and could use help on that.
i'm going to temporarily use a belt i got from a dvd repair place. we measured it and found one that's ALMOST the same size (little skinnier but little shorter. difficult to gauge proper belt without a parts list.
i'll keep looking.
if anyone has access to parts list for GoVideo DVR4200 i'd appreciate the heads up.
thanks,
mark
Posted on Nov 02, 2007
    New Friend:
This worked GREAT, thank you! A couple smacks on top with a rubber mallet and voila! Will keep a dvd in now, always-- THANKS
Posted on Jan 18, 2014
I'm having the same problem and need acces to parts to fix it.
Posted on Oct 28, 2012
This worked like a charm for me. I don't care that it isn't technical. IT WORKED right a way and the hint about keeping a DVD in the unit is right on too!
Posted on Dec 27, 2008
I have had the same problem with my GoVideo. May not be very technical, but I find that if I smack on it with something hard, it usually opens. It will usually open if there is a disc in the tray, so I always try to keep one it, and haven't had much problem. oh I just noticed that this post is 9 months old, so you've probably fixed it by now. Oh well...
Posted on Jul 13, 2008
  • Katrina MacGregor
    Katrina MacGregor Jan 18, 2014
    this worked GREAT, thank you! Rubber mallet on the top of it and voila! will keep a DVD in now, always.
Try openning after trouble shooting
Posted on Oct 31, 2007
SOURCE:
Aspire e1 510-2500 how to open cd-dvd
goto were your icon is for mycomputer..open it and you will see the icon for your dvd,,cd,,drive,,right click on it and at the top it will say open,,click on it and your dvd,,cd,,drive should open.
if it dont open then your tray is stuck and you may end up opening your laptop to get to it,,or there might be a small screw on the bottom of your laptop that will allow you to take it out from there.
Apr 21, 2014 | Acer Aspire Computers & Internet
Samsung dvd R155 disk tray won't open/eject
1) try to clean the button with special contact cleaner spray
2) if this work, is o.k otherwise use the r. control and try to open the tray if work, is obvious the button was dirty. If doesnot work, you must the DVD player.
3) inspect any belt and replace, and lube any shaft +gear with small lubricant( vaseline) and replace any parts broken.Tight any wires connector very well and clean it.
4) if doesnot resolve the problem you must go the repair shopt TV for fix it.
God bless you
Jul 31, 2012 | Televison & Video
Go Video DV 2150 - DVD door won't open at all. You can hear a mechanism working behind the closed door, but nothing happens and the door remains shut. Any advice??
There is a small belt under the loading tray which would have gone slack ( loose ) and the sound you hear is it slipping on the motor pulley. If you are confident you can remove the mechanism and turn it upside down and access this belt. Dismantle only if you can get the spare belt or your efforts will be in vain.
Sep 13, 2011 | GoVideo Go Video DVD/VCR Combo
Disc tray will not open. I've turned on &off several times and it won`t open the tray. tries to but won`t open
This problem is caused by a loose drive belt in the eject mechanism, you need to open the ps2 and replace the drive belt...
Take off the top cover, then take off the cover from the top of the dvd drive mech... then carefully remove the disc tray and you should see the belt near the front. Replace that belt and it should work fine again
On a couple of rare occasions the drive motor has been found to be faulty, but usually replacing the belt will fix it
Jan 25, 2011 | Sony PlayStation 2 (PS2) Console
Dvd drive is not working
Replace the DVD drive. They are inexpensive and it's not worth your time to try and fix this drive...
Feb 05, 2010 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Unable to open CD tray
the winding of the motor controlling the tray operation may not be getting the supply properly or functioning well ...
check it...
that must be the problem
Mar 21, 2008 | Toshiba SD-6000
DVD Player is not opening the tray
There is a belt most likely under the tray that has stretched. replace it with the same size and it should be ok.
Apr 03, 2007 | KLH DVZ-2500 System
LG DVD+RW door won´t close
Deliverance
this problem can happen if tray-in sensor not sense. their r a small liver which press tray in sensor automaticly when tray stay inside. liver and sensor location is near emergency exit hole (when u use a pin for emargency exit actually u press this liver then it release try-in sensor). check this liver and its path any pice of cd is their or not. (to check open ur drive cover. to open it at first use emeargency exit hole to open tray then open cover)
Dec 19, 2006 | LG (GSA-4120BK) DVD±RW Burner
GoVideo Go Video DVD/VCR Combo Logo
2,822 people viewed this question
Top GoVideo Televison & Video Experts
Marvin
Marvin
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
