Question about Samsung RS265TDBP Side by Side Refrigerator
Programming codes list of programming codes to manually defrost
Step by step
What steps are you looking for? Also what is the problem? Also this may solve your issue
Copied from: voxrightnow
Programming the Remote:
Your universal remote can operate a variety of brands of components. In order for your universal remote to control your components, you need to program the remote with the codes that match the components (See Code List below). These codes enable the remote to communicate with your components. Each brand and each component has its own "language," and, by programming the correct codes into your remote, you tell the remote to "speak the same language" as your components.
There are two methods you can use to program your remote control to operate your components: Direct Code Entry and Manual Code Search and Entry. Most components can be programmed in one of these ways. Try them in the order listed.
In order to control combo TV/VCR or TV/DVD units, you must program both the TV key and the VCR•DVD key. Once programmed successfully, the TV key controls the TV functions on your unit, and the VCR•DVD key controls the VCR or DVD functions. There is a specific section in the Code List for combo units. The codes in this section should be tried first, using Direct Code Entry on the TV and VCR•DVD keys. If this is unsuccessful, follow the normal programming methods for both the TV and the VCR•DVD keys
Direct Code Entry:
To program your universal remote to control your components using the Direct Code Entry Method, follow the steps below.
1. Manually turn on the component you want the remote to control (TV, VCR, DVD, satellite receiver or cable box).
2. Find the Code List below. Find the list for the component you wish to program. Find your component's brand. You will see a listing of four-digit codes for each brand. If your brand isn't listed, use the Manual Code Search method to program the remote control. (Refer to page 5 in the User Manual for Manual Code Search method, or scroll down in this Answer to the next section.)
3. Press and hold the component key (TV, VCR•DVD, SAT•CBL) you wish to program. The LED indicator light turns on and remains on. If you release the component key any time during the Direct Code Entry procedure, the LED indicator light blinks four times, and the process is exited.
4. While holding down the component key, consult the Code Lists for the four-digit code that corresponds to your component's brand and use the number keys (0-9) on the keypad to enter it. While you are pressing the numbers, the LED indicator light turns off.
5. After the fourth number is entered, the LED indicator light turns on. At this time, release the component key. If the LED indicator light turns off, you have entered a valid code and have followed the correct procedure
for Direct Code Entry. If you enter a code number that is not in the Code Lists or you do not follow all of the steps for Direct Code Entry, the LED indicator light blinks four times when the component key is released. This is an indication that a programming error has occurred. In that case, repeat the Direct Code Entry process from step 3 and try the next code listed. The last programmed code under that component key is retained. Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the component you are currently programming the remote to control.
6. To confirm that the component key is programmed with the correct code for maximum functionality, test the component. Attempt to control a variety of the component's functions with the remote. If some of the features of your components do not work, try programming the remote with a different code in the list until you find the code that allows the remote to control the majority of your component's functions. Different codes can provide different levels of functionality.
Manual Code Search and Entry:
If your component's brand isn't listed in the Code Lists, or if you have tried all of the codes for your brand and the remote does not operate your component, try the Manual Code Search. This Code Search method cycles through all of the codes in the Code Lists in the event that your component's code is listed under another brand. The Manual Code Search method may take a long time because the remote searches through all of the codes in its memory for the code that operates your component. Therefore, if your brand is listed in the Code Lists, first try the Direct Code Entry method described on page 4 in the User's Manual also described above.
NOTE: To exit without saving any point in the Manual Code Search, press and release the GO BACK key.
Note: If you press an invalid key during the Manual Code Search, the remote does not respond and the LED indicator light does not blink. If you do not press a valid Manual Code Search key (TV, VCR•DVD, SAT•CBL, ON•OFF, GO BACK), the search times out after two minutes. When the search times out, the LED indicator light blinks four times and turns off. The last programmed code under that component key is retained.
2. If you are programming the remote to control your TV or satellite receiver, go directly to step 3. To program the remote to control a VCR or DVD follow the preprogramming method listed below.
Preprogramming the VCR/DVD Key
The VCR•DVD key can control only one component, either your VCR or your DVD. To program your remote to control either your DVD or your VCR, you must first put the remote in the proper programming mode. Follow these directions before proceeding to step 3.
a. Press and hold the VCR•DVD key. The LED indicator light turns on.
b. While holding down the VCR•DVD key, press and release the number 2 key on the keypad to control a VCR or the number 3 key to control a DVD. The LED indicator light turns off.
c. Release the VCR•DVD key. The LED indicator light blinks four times and then turns off. Your remote is now either in VCR or DVD Programming Mode, depending on which you chose. Proceed to step 3.
4. While holding the component key down, press and hold the ON•OFF key. The LED indicator light turns off.
5. After holding down both keys for three seconds, the LED indicator light turns back on.
6. Release both keys. The LED indicator light remains on. Throughout the programming of each key, be sure to keep the remote pointed at the
7. Press and release the ON•OFF key repeatedly until your component turns off. Each time you press the ON•OFF key, the LED indicator light blinks, and the next code in the list is sent. This process continues until all of the codes in the Code Lists have been searched. If your component
turns off, you have found the correct code. (If it cycles through and the LED indicator light blinks four times and turns off, all codes have been searched. The Manual Code Search method is exited.) Because there are so many codes, you may have to press the ON•OFF key many times-possibly up to 200 times.
8. Once you have found the correct code, you must save the new
code by pressing and releasing the STOP key. The LED indicator
light turns off. You must press the STOP key to save the code or the correct code will not be stored!
9. Once you press the STOP key, the code is stored.
Testing the Code for Maximum Functionality:
1. Once the code has been stored (see Manual Code Search and Entry Method above), use the remote to attempt to control a variety of the component's functions. If the code that has been stored controls the majority of the component's functions, programming is complete. If the
code stored does not give maximum functionality, you will want to try another code.
2. In that case, repeat the Manual Code Search and Entry Method from step 1. When the component turns off for the first time, do not press the STOP key, which would store the code. Instead, with the unit now off, continue to press the ON•OFF key repeatedly until the unit turns back on. Once the unit turns back on, you have found another code that operates the component. Press the STOP key.
3. Test the functionality again by attempting to control a variety of the component's functions. If the code that has been stored controls the majority of the component's functions, programming is complete. If the code stored does not give maximum functionality, you will want to try another code.
4. Repeat the Manual Code Search and Entry Method from step 1. Each time a code turns the component on or off, you have found a code that operates the remote and needs to be tested for maximum functionality. Continue through the code lists, cycling through the codes you have already tried, until you find one that offers maximum functionality.
Nov 10, 2012 | RCA RCR350 Remote Control
Programming EUR7724KCO Panasonic Universal Remote Control
To program the remote, press and hold the TV button. Then enter the 2 digit code from the code list. The EUR7724KC0 will only control TVs from about 17 manufacturers that were manufactured before the remote was programmed. If the given code for the TV brand doesn't work or the manufacturer isn't listed, then the remote can't control that TV. I'll list a few of the codes (see the manual, link below, for more):
Panasonic 01, 02
RCA 03
Samsung 14
The EUR7724KC0 remote came with several devices including the PV-D4734S DVD/VCR. The directions for programming the TV code are on page 28 of that manual. The code list is on page 29. This manual is available from Panasonic here: http://service.us.panasonic.com/OPERMANPDF/PVD4734S.pdf . Since this particular DVD/VCR model was listed at Amazon in 2004, it probably won't work for TVs built in that year or later.
I hope this helps.
Feb 04, 2012 | Universal Remote Control Televison & Video
How do i program the RCRN04GR universal remote to a sylvania tv?
Hello
Here is the proceedings for direct code entry.
Direct Code Entry lets you enter a code from the accompanying
code list for your brand of device. It's not as easy as the other
methods, but it's potentially the fastest method
TIP: Each device key is associated with a type of device-
the TV is preset to search for TVs, SAT•CBL•DTC for satellite
receivers, cable boxes or digital TV converters, DVD•VCR
for DVD players, and DVR•AUX for DVRs. To program a
device key for a different type of device, see the Changing a
Key's Device Type section.
1. Manually turn on the device you
want to contro
2. Find the Code List that came with
the remote. Locate the section for
the type of device you're trying to
program, and find your brand in
that section. Circle the codes for
your brand and keep them handy.
3. Press and hold the device key you want to program (the
POWER key illuminates).
While you're holding down the device key, use your other
hand enter the first five-digit code for your brand in the
code list (the POWER key turns off after the first digit).
4. When you've finished entering
the five-digit code, keep holding
down the device key and look at
the POWER key.
Is the POWER key
illuminated?
YES: You're done! You've programmed this device key.
NO, it blinked four times and turned off: You have
either entered a code number that is not in the code lists
or missed a step in the code entry procedure. Try step 3
again
NOTES
Test the remote with the device to make sure the device
functionality. If some features don't work, try a different code
in the list.
Remember to enter the code for future reference in the box
provided in the Code Retrieval section of this manual.
If your brand isn't listed in the code list, use one of the Code
Search methods to program the remote control. (Refer to the
Auto and Manual Code Search methods.)
If you release the device key any time during the Direct Code
Entry procedure, the POWER key blinks four times, and the
process is exited. The last programmed code under the
device key is retained
Codes to check with Sylvania are:
20035, 20081, 20000, 20043, 20593, 21593
11864, 10054, 10171, 11271, 11314
51563
OK.
Aug 29, 2011 | RCA RCRN04GR Remote Control
I need to know how to program my nexxtech 5 in 1 Universal remote control Cat # 1519004 to my T.V which is a Toshiba
Directly from the manual:
Code Programming
The P (Program) button is used to program the remote. You can program the remote using the code for your brand of device from the code list, or search through the library of codes until you find a code that works for your device. You can store any kind of code under any mode (except TV). For example, you can store a VCR code under the SAT button, or a DVD code under the VCR button, etc. However, you can only store TV codes under the TV button.
Direct Code Entry
1. Press and hold the P (Program) button until the red indicator stays on. Release the P button.
2. Press and release the desired mode button (TV, VCR, etc.). The red indicator blinks, then stays
lit.
3. Enter the 3 digit code from the code list. Note: The red indicator turns off after a valid code entry and flashes for an invalid code. 4. With your device on, press Channel Up. If the device responds, no further setup is required. Note: If some buttons on your device do not operate, try one of the other codes for your brand.
Toshiba TV Codes
0159, 0178, 0109, 0120, 0181, 0105, 0049, 0095, 0170, 0260, 0358, 0394, 0924, 0012, 0095, 0117, 0141
You can download the fuel manual and code list here: http://files.remotecentral.com/download/472/1519004-manual.zip.html
Jun 01, 2011 | Televison & Video
I need the set up code for urc 3021b00
One-for-All does not have a code list for the URC-3021b00. However, the basic code list and the manual programming method should be the same as the URC-3021.
Both the manual and the code list for the 3021 is available here: http://www.oneforall-na.com/remote.php?type=URC%203021 .
I hope this helps.
Mar 01, 2011 | One For All URC-3021 Remote Control
How to program a rca rcr451 remote
or cable box).
2. Locate the enclosed Code Lists.
component’s brand. You will see a
brand. If your brand isn’t listed,
control. (Refer to page 6 for
Manual Code Search method.)
(TV, VCR, DVD, SAT·CBL) you
your component’s brand and use the
light turns off.
component’s functions with the
your component’s functions.
DOWNLOAD the full manual with codes for free at: http://www.replacementremotes.com/RCA-Manuals/Download-FREE-RCR450C-MANUAL-OPERATING-MANUAL.html
Aug 11, 2010 | RCA Universal Remote Control
Remote Code
1.Go to the url below
http://www.rcaaccessories.com/rcaaccessories/RcaaccessoriesProductDetail.do?ACTION_TYPE_ID=ACTION_TYPE_PRODUCT_DETAIL&ACTION_CATEGORY_IDSTR_CATEGORY_UNIVERSAL_REMOTES&ACTION_PRODUCT_ID=RCR312W
2. Scroll down and select the "Support and Manuals" tab.
3. Click "Code List for RCR312W
Jan 26, 2010 | RCA Universal Remote Control
RCA RCR412b remote
Direct Code Entry
2. Locate the enclosed Code Lists. Find the
program. Find your component’s brand.
for each brand. If your brand isn’t listed,
use one of the Code Search methods to
pages 7-8 for Manual and Auto Code
Search methods.)
DVD, VCR·AUX, SAT·CBL) you wish to
program. (To program the VCR·AUX key
to control a component other than a VCR,
see page 7.) The illuminated ON·OFF key
illuminated ON·OFF key blinks four
times, and the process is exited. The last
programmed code under the component
key is retained. Toshiba codes:2011, 2029, 2030, 2033, 2093, 2107, 2110, 2111, 2112
Sep 13, 2009 | Televison & Video
Need codes
Unit does not have a manual, but I did find this -
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Let me know if this works, and if not, I'll keep looking.
Feb 01, 2009 | JVC DR-MV100B DVD Recorder/VCR
Locateowners manual/program codes for tv remote
Codes for Zenith T.V are 1000,1001,1004,1083,1101,1100,1099,1097,1089,1078,1022,1020,1011,1009
Jun 07, 2007 | Jensen JER-822 Remote Control
Samsung RS265TDBP Side by Side Refrigerator Logo
62 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
