Question about Janome Memory Craft 5700
Screen won't respond
As requested details for Above problem. When I turn on my machine a bobbin picture appears on the screen.I turn off the machine. I pushed start/stop button, reverse button and auto-lock button all at the same time and turn on machine again. follow "+" directive instructions and when done "adjustment end " appears on screen. I turn off the machine and 15 seconds later turn back on. The bobbin picture reappears. What can I do now. Thank you.
  • Janome Master
  • 1,388 Answers
Probably needs a replacement Touch Screen...please
Contact Us at Bargain Box
Posted on Apr 22, 2014
SOURCE: Step motor error
There are 2 stepper motors, in this machine. One is for the embroidery arm (the one you attach the embroidery frame to), and the other is inside the top (under the cover/which is under the spool holder) for the side-to-side/front-to-back motion of the needle (during embroidery stitches). If these get ANY debris/lint in them, they cannot return to the correct point, so the machine (sensing this) stops you, as incorrect positioning could break your machine. I have had my son clean 2 of these, so far, and then they have worked fine. The shops tend to want you to dump the machine, or pay for a complete new part, when my experience is that you just need someone, who is mechanically minded, to open it up, and carefully clean it.
Posted on Jul 19, 2012
SOURCE: SP in display window, no options?
SP means that the bobbin winder has been pushed to the right in preparation for winding the bobbin. Just click the winding post to the left till it clicks, and the stitch number will be displayed.
Posted on Sep 30, 2007
  • 323 Answers
SOURCE: Bobbin winding message
Under the top cover, on the right hand side where the bobbin winder is, there is a small switch which is activated when the bobbin is being wound. You will need to remove the cover and reposition the switch (it's located towards the front of the machine) to make it work properly.
sewman7
Posted on Nov 25, 2008
SOURCE: The machine won pick up the bobbin thread, it jams when starting
wont pick up thread from bobbin
Posted on Nov 28, 2009
  • 25 Answers
SOURCE: janome 4900 sensor problem?
Maybe the bobbin winder is in the the on position. Push it to the off position.
Posted on Feb 11, 2010
My touch screen isn't working
Brother 8200 8500 8500d screen ..just found this on youtube not sure if this will help you out
Dec 03, 2016 | Brother Sewing Machines
Control Panel shows the following error message: ][ How can I re-set it?
] [ = usually means that your bobbin winder is on. Move the bobbin winder post/shaft from the right position over to the left to switch the mode back to sewing, then try making your stitch selection again.
Jan 12, 2016 | Singer 7256 Fashion Mate Sewing Machine
Bobbin won't wind and display shows me in bobbin wind mode and won't turn off, so i can't use the machine at all
it sounds like it's a problem with the computer motherboard and the
machine needs to be checked
Dec 04, 2012 | Sewing Machines
Bobbin winding on screen won't come off
Did you remember to slide the bobbin winder pin all the way to the left?
Sep 25, 2012 | Janome Memory Craft 9000 Computerized...
I can't get the bobbin case to stay in
are you sure that the bobbin in the case is the right one for the machine firstly, and also that it is in the right way? Then check that it has gone into the rotary hook correctly, there is usually a latch you use on the bobbin case to lock it into place, like a little flap you pull out, put it into place, then release the flap so it locks in.
If you don't have a manual for your machine that details the above then you can download one from the singer website. http://www.singerco.com/accessories/instruction-manuals, type in the model number only and click on "search", wait for the screen to build and you should see your model with an icon beside it "Free Download", click this and again wait, its a large pdf file so will take some time to download to screen. Once you see it, click on the Clipboard icon to save it and browse to a local folder where you want to save the file. You can then view it when you need it or print it out to bind and keep with the machine.
Aug 22, 2011 | SINGER 7470 Sewing Machine
Where can I locate the fuse<
The Pfaff 7570 Creative Designer is a computerized sewingand embroidery machine that has the ability to connect to the computer, andhave embroidery designs sent to the embroidery machine. The sewing andembroidery machine has many features, including hundreds of general sewingfunctions, a separate embroidery module, and on-screen editing features. TheCreative Designer 7570, manufactured in the 1990s, was the first sewing andembroidery combination machine ever made by Pfaff.
1. Usingthe Sewing Machine
1 Turn on your sewing machine using the "On"button located just below the turn wheel on the right side of the machine.Thread your Pfaff 7570. Note that Pfaff sewing machines thread from left toright, not right to left like other sewing machines. The upper tension discsshould be raised at their highest position while threading, and the presserfoot should be raised up until you thread the needle. Drop the presser footright before you thread the needle. The prevents thread problems during use. 2 Insert a full bobbin and retrieve the bobbin threadthrough the thread plate. Raise your sewing foot and needle to its highestposition; hold the needle thread taught with your left hand, lower the needleinto the thread plate using your right hand, and then raise the needle. As youraise the needle, the needle thread will catch the bobbin thread, and pull itup. There should be a loop of thread intertwined with the needle thread. Usetweezers, your finger, or a straight pin to retrieve the bobbin thread that isvisible through the thread plate, and pull it through the plate. 3 Place the fabric under the presser foot, and drop thepresser foot. Choose the stitch you want to use from the top stitch display,right above the top thread feed. Press the '0-9" button located on thesewing machine's front panel, and a display screen will come up. Input thethread number, and press the 'OK' button located on the sewing machine's frontpanel. The stitch will display, and you are ready to sew. Repeat Step 3 foreach stitch you want to use.
2. SettingUp the Embroidery Unit
1 Turn the sewing machine off. Take out the embroiderymachine unit, locate the connection bushing on the back of your embroideryunit, and match it up with the connection bushing on your sewing machine. Theconnection bushing should be located next to a yellow sticker on yourembroidery unit, and somewhat resembles a serial port on a computer. Slide theembroidery unit onto the sewing machine with the sewing machine turned off. Connectto the bushing carefully as you slide the embroidery unit onto the sewingmachine. Use your embroidery unit manual if you need assistance. 2 Insert an embroidery card. Your embroidery unitshould contain an embroidery card labeled embroidery card 1. Use that or useanother Pfaff 7570 card that you own. Turn on the sewing machine. 3 Open the bobbin case area just below the threadplate, and lower the feed dogs by pushing the feed dog switch to the right.Press the card button located on the front face of your sewing machine. Adisplay with pop up; choose embroidery designs or monogram and a new screenwill pop up with your design choices. Choose the design you want, and press"OK." A checklist screen appears. Do everything on the checklist, andpress "OK." Use your embroidery unit manual if you need help. 4 Start embroidery by pressing the foot pedal. At thistime, your hoop should already be attached to the embroidery unit becauseyou've already gone through the checklist. Your embroidery manual displayscolored picture diagrams that are very helpful in understanding everything inyour checklist menu.
Thanks for using fixya
Jul 31, 2011 | PfaFF Creative 7570
Bobbin Winding message appears when machine is turned on
Is the bobbin winder holder clicked over to the right like you are trying to wind a bobbin? If so, and you are not trying to wind a new bobbin, click it over to the left.
Mar 09, 2009 | Kenmore 19233 Computerized Sewing Machine
Jan 14, 2007 | Janome 8080 Computerized Sewing Machine
Sewing Machines Logo
57 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
