Question about Vizio VO320E LCD TV
Is my VO320E Visio tv compatible with hulu?
Will my model of tv work with hulu and if so, how do I hook it up?
I have NextBook Ares 8 Android version 5.1.1 Model # NXA8QC116. In Google Play Store I do not find Hulu: Stream Tv, Movies and More application or any Hulu or Hulu Plus installation application.
I think a lot of the hulu apps were pulled from the market, i just checked google play store myself and don't see any official hulu apps available either.
May 04, 2017 | Nextbook Tablets & eReaders
How do I get my Sony universal remote to work with my Visio tv!
On your Visio TV remote control there will be a Source button or Input button. Press it & on your TV screen select HDMI 1 or HDMI 2. See the TV to see how the HDMI cable is connected from TV to Set Top Box. Now take the other remote control i.e. Sony Universal remote in your hand. Press mute & Select simultaneously. A blue light will blink twice, Immediately release the buttons & enter the code. You have to be extremely fast in doing this.
Following are few codes which you can try:
002, 000, 011, 080, 111, 006, 071, 128, 1904, 925, 0000, 0834, 0810, 1685, 1786, 1032, 1972.
Check the Visio TV manual for the make of your TV & model no & if code is printed. Then contact Visio TV manufacturer or retailer for the Visio TV code to enter & synchronize with the Sony Remote Control.
Nov 13, 2016 | Sony Televison & Video
I have my Vizio vo320E TV hooked up to my cable box. and it says no signal. What must I do to fix this problem. Thanks Jay
you must not have the cables right. try again. I am using a HDMI cable and it works fine. The 3 color cables---not so much
Oct 11, 2014 | Vizio VO Televison & Video
Visio 1080p screen went light
Our Visio 42" flat screen TV did the same thing. It didn't happen that often but sometimes it would go darker or the sound would go off until I changed the channel or turned TV Off then back On. I contacted Visio through my warranty and they sent me a flash drive to install info on my TV. Did not fix the problems. A year later before warranty ended I contacted Visio again. They sent a huge box for me to pack my TV in to send to the warehouse where they fix everything. It took about 2 wks. to get it back. Worked fine for about 4 months and the problems continued. I will not buy another Visio TV. I found out that they had many problems with several models.
May 03, 2014 | Televison & Video
Vizio screen problem. Please help!
The screen is ok Your T-Con board quit. You can get a new one from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Aug 03, 2017 | Vizio VO320E LCD TV
We recently purchased a Visio lcdhd tv and the manual that came with our Jumbo uiversal remote doesn't show the code setting for the Visio. Is there a code you can give us.
We can't give you the code without specific model numbers for both the TV and remote control. Try the codes for the Visio models that are listed in the manual. There is a good chance that Visio used the same coding system for more than one model. If that doesn't work, check the Internet support page for your remote control. It may have additional models listed, and one may apply if Visio used one of the other remote control systems on the market at the time your remote control was manufactured.
Oct 27, 2010 | Televison & Video
Is the SAA7130 able to be hooked to a tv set, and can I then watch internet programees such as Hulu through it
The only way I know of is to buy an LCD TV most of them can be used as a computer monitor. I just helped a friend hook up a new Samsung. It only takes one button on the remote to switch from regular tv to computer to watch hulu he loves it.
Aug 14, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
How do you hook up the audio from Visio flat panel to SA EX 300
Wild guess. Is the TV volume turned down and its output set to variable instead of fixed?
May 17, 2009 | Technics SA-EX300 Receiver
Vizio VO320E LCD TV Logo
20 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
