Logik tv37"LW782 Turns itself off after a while will not restart immediately, have to wait for cool down period
5 Suggested Answers
ebackhus
  • 31 Answers
SOURCE: wait time for restarting projector/
You were right about the shut-down time. We had an older InFocus projector at work that had the cord yanked (by the presenter no less...) which cost us a near $400 in repairs. A LOT of heat is generated in these machines and proper cooling is absolutely essential to their operation.
Posted on Jun 03, 2008
ruben_barrer
  • 117 Answers
SOURCE: Toshiba Laptop turns itself back on after being shut down
go to toshiba's website
www.toshiba.com select your proper device and go to support put in your model number there have been some bios updates to resolve this issue. load all bios updates and you should eliminate this known issue.
good luck!
Ruben
Posted on Jul 19, 2009
  • 365 Answers
SOURCE: Radiator hose blew and engine stalled. Fixed hose,
you may have a blown head gasket or cracked the head due to the overheating of the engine
Posted on Jun 11, 2010
nhpatriotman
  • 3 Answers
SOURCE: maytag dryer will not restart immediately after drying a load. has to cool down
try cleaning out your dryer vent. Remove your lint trap and use a flexible wire brush to clean deep inside, then remove your dryer vent hose and make sure all lint is clean from the dryer side of the vent and the vent hose all the way to the out side vent.
Sounds like it may be clogged with a build up of lint
Posted on May 23, 2012
Kai Rio built sept 07.Suspect fuel pump fault.Car randomly cut out when driving & won't immediately restart,leave a few hrs & restarts & drives ok again. Any engine fault codes for fuel on this car?
Generally this kind of problem is caused by a faulty electronic component getting heat soaked. Best bet is to run your diagnostics while the car is still warm and won't start. If you wait for it to cool down (when it starts), the problem will not present itself. If it's not trying to start at all, it's usually the ignition module. If it runs rough, it's usually one of the coils.
Jan 02, 2017 | Kia Rio Cars & Trucks
My laptop turned off but it has 35% remaining battery
Laptop turns off suddenly? Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage.
If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed.
Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot.
The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down.
Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
May 29, 2010 | Computers & Internet
Turns off suddenly
Mar 27, 2010 | Toshiba Satellite M55-S331 Notebook
The computer will just randomly do a windows shutdown and then restart. Cleaned, changed the power supply and still does it.
Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the computer back on and figures out a way to foil the protection, the unit is probably doomed. Once a unit shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot. The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated unit is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down. Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning. Check the CPU fan if it is spinning and also the CPU itself put thermal paste. So that the heat from CPU will absorbed by the heat sink.
Jan 19, 2010 | Dell Dimension 2400 PC Desktop
Logik LBD1000 will not play disks
Get the software update from here. Burn the DAT file and the IMAGES folder to a cd. Now start your player and wait until screen displays no disc. Now insert cd and close tray. software will update and cd will eject. Remove cd and close tray. Player will restart by itself and your software will be updated.
http://support.thetechguys.com/layout.aspx?ID={dbc6bc85-b8cc-470d-89f7-f2515bb1f40e}&CatID={57a197ba-7d6a-45b0-8554-3d1bc82287e8}
Jan 18, 2010 | Electronics - Others
My 50 Viore dlp tv turns itself off after just a
HI, this may be a simple cooling issue. try inspecting the cooling fans that are located near the power sector. if these cooling devices are not operational, they will cause the power board to shut down periodically, due to heat build up.
If the fans are operational, this will confirm a weak and defective power power board.
Jul 20, 2009 | Televison & Video
good luck!
Ruben
Jul 18, 2009 | Toshiba Satellite Pro M300-S1002V T8300...
Wait time for restarting projector/
Jun 02, 2008 | Mitsubishi HC3000U Multimedia Projector
Heater kicks out
Honeywell heaters like HZ3650 have a screen on the air inlet at the back side of the heater. This screen can be partially blocked off by an accumulation of lint, etc. The lint blocks some of the air flow which may cause heat increase within the heater to the point that the safety shutoff thermostat shuts off the power. Operation is returned after a cool down period only to repeat the shut down cycle after a short period of operation. If this is the cause of the problem the screen must be cleaned.
Sep 19, 2007 | Honeywell HZ365 Ceramic Compact Heater
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
