Question about Dell XPS M1530 Laptop
Black screen white black screen lid
Black and White Horizontal Lines
Sounds like the graphics card just died. You will need that repaired.
Apr 15, 2014 | Apple iMac Computers & Internet
Tart up black screen and beeps
Sounds like your screen went bad.
Close the lid, attach an external monitor, open lid and see if the screen appears on the monitor.
Resetting the PRAM may do the trick also:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
Happy New Year,
Kerry
Mar 05, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Hi. I have hp 6735s laptop and when I move him screen suddenly go black or in rare case white and I need to hold power button to shut down and when I turn him on everything is normal until I move him again...
When you say you move him, do you mean lifting the unit and moving to another location or just moving the lid (changing angle of the lid/lcd)?
If changing the angle of the display gives you black/white screen, you may be having problem with the LCD cable, it might be loose or defective. But if moving the unit to another location gives you the black/white screen, one component of the unit might be loose. Either you need to properly reinsert the memory of the harddrive. If these simple steps will not resolve the issue then you might need to check the whole motherboard including the connection to the LCD.
Hope this helps.
May 19, 2011 | HP Compaq 6735s Notebook
My 13" black macbook's screen blanks out to a
Have you tried starting from the system disks that came with the computer? Put the disk into the computer and start up holding the C key down. And troubleshoot form there.
Nov 24, 2010 | Apple Computers & Internet
Wide black line down page
open the document lid. Check to see if there is white-out on the glass platen where the document rides across the scanner. Some units require the white roll to be taken off.
sometimes a black mark on this platen can leave black streaks on copies made on this machine, and even when they send to others.
Try to clean the platen glass.
Oct 15, 2009 | Samsung SF-340 Plain Paper Inkjet Fax
Black screen
the next time you reboot keep on tapping the f8 key. it should bring you to the advanced options menu. from there select the option for last known good configuration. select it. if this doesnt remedy the issue you may have to reinstall windows.
Oct 30, 2008 | Toshiba Computers & Internet
Dell XPS M1530 Laptop Logo
23 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
