Question about OfficeMax 10-Sheet Micro-Cut Shredder Om02750
Bin full door open
Just purchased this item, but it stopped working. It says bin door open. It will not work anymore and I've opened and closed the door. Noting is blocking it.
I found the nylon "bin full" flapper in the center of the head of the shredder is supposed to trip a microswitch indicating bin full. I removed the flapper and tapped on the switch. It came loose with a puff of paper dust. I replaced the flapper and it's back to good as new. Seems the dust built up around the switch and it was stuck.
Posted on Jul 17, 2015
When I tried to open the clear bin to empty it, the bottom did not drop open and now I can't push the cyclone down. What do I need to do to fix this?
I can't be specific without knowing your model but the crud and gunk that collects inside the dirt bin can restrict the door from opening and closing properly. If the door isnt closed properly the dirt bin may not fit back into the vacuum.
Jan 20, 2017 | Vacuums
Our shredder will not anymore shred the red light will signal
Blades probably Jammed
Safety First
Power Disconnected
Open up and free the mechanism
Apr 05, 2016 | Shredder Office Equipment & Supplies
Full bin-door open light on with empty closed bin
Pull the bin out and look inside for a push switch that the bin pushes against. See if it moves freely. Likewise it may have an LED switch, see if it's blocked.
Oct 09, 2014 | Office Equipment & Supplies
Why won't ice dispense from ice maker?
Pull out the ice storage bin from the refrigerator. Empty the bin if it is full. Add some ice into the bin. Reinstall bin into refrigerator. Make sure the refrigerator door(s) are closed. The ice will not dispense if the door(s) are open. Press the ice dispenser with a glass underneath it to start dispensing ice. Listen for a whirring sound. If there is a sound, then the auger that moves the ice cubes is working. Check the ice shoot in the door to see if it is blocked with ice. If you don't here any whirring sound the motor that runs the auger is probably bad. Then you will have to replace the whole ice maker assembly.
Jul 20, 2014 | GE Refrigerators
I have a model qd0452a manitowoc and it will not stop making ice
Very unusual for one of these to not stop. There is a magnetic proximity switch located on the bottom right side of the water curtain that serves to both cancel a harvest/drop and to shut the unit down on a full bin. When a drop occurs the control board sees a open and then close of the switch and restarts a freeze mode. If the ice drops and the bin is full the curtain is blocked by the ice behind it from closing again and the unit shuts down on a full bin indication. If the curtain does not open and close after 3 hours it would lock the unit out. Therefore I assume that the switch and the board are working. Most likely you either have the unit on a non-Manitowoc bin or are missing a deflector plate in the Manitowoc bin and the ice is falling out of a service door.
Nov 17, 2010 | Manitowoc SY0454A S Series Ice Maker...
I can't get the door open do empty the shredding
You have probably got the bin so full it is stuck/jammed full of paper and you now can't remove it...this is a "consumer" model machine and to keep cost low they do not provide a "bag-full" light on the panel...you should regularly empty the bin so that the shredded paper does not totally jam the bin and in extreme cases then get caught back up into the cutting machanism and blow the pcb inside the machine...check your "users" instructions to remove the bin.
Aug 23, 2010 | Royal PX1000MX Shredder
Hi, I just received a problem from the recycle bin: When I try to use the function empty recycle bin, the bin pop out window says "confirm multiple file delete" "Are you sure you want to delete these two...
Interesting problem. I'd try this: Open control panel and open Folder Options. Click the View tab and check the box to "Show hidden files and folders". say ok to that and close out back to the desktop. Now look in the recycle bin to see if there are those 2 files in there and try to delete them manually. Also go to www.download.com and download and install CCleaner (Freeware). Run CCleaner and see if it is able to delete those files. If not, then see if you can right click on those 2 items and choose Restore. Once you have done that I would recommend you do a full virus scan on the pc just in case and also run the ccleaner once again. Hope this helps.
Cheers!
Aug 14, 2010 | Microsoft Windows XP Professional
Ice maker will not make ice cubes, only crushed ice.
take out your ice bin the look in the back of the freezer and ytou will see a small hole with a plastic sqaure actuator.hold the door switch closed and make sure the unit is selected for cubed ice then try and dispence ice if the swaure plastic acuator moves up it is working fine it shoeld drop down when you release the dispencer arm.if it dropps back down then make sure that the metal bail arm is properly inserted into the hole in the auger case when that actuator moves up this opens the small plastic door on the ice bin to allow subed ice to come out.make sure there is no ice build up on the ice bin that would stop the trap door from opening.good luck with you fridge i hope this helps you out,let me know how thing s go for you.
Jan 20, 2010 | Frigidaire FRS23H7C Side by Side...
Ice maker is overflowing
Older icemakers have a bar that drops from above your ice bin; once the bin is full the bar is raised and trips turning the ice maker off so that it won't dump. If your's is this style, try manually pushing the free end of the bar upward so that it locks in the upward position. Newer ice makers with the ice bin in the door have a small panel that moves to the open position when the door opens and closes when the door closes. Mine also includes an optical sensor that is visible when this panel is in the closed position. Try placing a non-clear tape over the optical sensor (don't know if that will work or not but worth a shot). If effective in stopping the ice flow then call a repairman. If none of this works, turn off the water supply coming out of the wall to your freezer.
Sep 08, 2009 | Kenmore Freezers
Get code C0b61 on Minolta 4000 copier
Check the exit bins mite be jammed. Service manual is Bin movement. Check mvement of all bins open close finiher door and reset front door
Mar 04, 2009 | Konica Minolta DiALTA Di200 Copier
OfficeMax 10-Sheet Micro-Cut Shredder Om02750 Logo
195 people viewed this question
Top OfficeMax Office Equipment & Supplies Experts
ROCKIT957
Randy Schumann
Randy Schumann
Colin Stickland
Colin Stickland
Are you an OfficeMax Office Equipment and Supply Expert? Answer questions, earn points and help others
