Question about Health & Beauty
A buildup of substances on the inner walls of arteries is known as...
15 words
What is the cause of high blood pressure
Narrowing of arteries.and veins in body due to plaque buildup. Tension/stress also does it
Apr 11, 2017 | The Health & Beauty
What is atheromatous aorta ?
An atheroma (plural: atheromata or atheromas) is an accumulation of degenerative material in the tunica intima (inner layer) of artery walls. The material consists of (mostly) macrophage cells, or debris, containing lipids (cholesterol and fatty acids), calcium and a variable amount of fibrous connective tissue.
Aorta. Main artery out of the heart that pumps fresh oxygenated blood around your body.
atheromatous aorta Google Search
Nov 23, 2016 | Miscellaneous
V on one side and numbers 3972 on the other side, what is it?
Pill imprint 3972 V has been identified as Lisinopril 10 mg.
Lisinopril is used in the treatment of high blood pressure; diabetic kidney disease; migraine prevention; coronary artery disease; alport syndrome (and more), and belongs to the drug class angiotensin converting enzyme inhibitors. There is positive evidence of human fetal risk during pregnancy. Lisinopril 10 mg is not subject to the Controlled Substances Act.
May 03, 2015 | Health & Beauty
How do I convert 12 tablespoons into grams
The tablespoon is a measure of volume, not weight, and in the USA is 15 ml. So the easiest way is to assume you are dealing with substances that are about the same as water, where 15 ml = 15 g.
So you have 12 x 15 g = 180 g
If the substance is much heavier or lighter than water, this will be incorrect.
Mar 01, 2015 | Office Equipment & Supplies
Light staying on - next to check engine light - it is an exclamation point surrounded by what look like parentheses.
Check your brake fluid level - this light comes on when the brake fluid level has dropped below the minimum level. Usually its because of a leak in the seals of the brake cylinder. Look for oily substance at the inner side of the 4 rims.
Also brake pads can be worn down below the minimum causing brake fluid level to drop below the minimum level.
In any case - make sure the cause of the warning light is known before driving any further.
Jun 30, 2011 | Toyota Sienna Cars & Trucks
How should you feel for a victims pulse
  1. 1 Use your right index and middle finger to check the pulse on the left arm of the subject.
  2. Step 2 Press the radial artery that you are trying to feel firmly with your index finger. The idea is to partially occlude the artery which will increase the volume of the pulse just proximal to your index finger which is underlying the tip of your middle finger.
  3. Step 3 Feel the pulsation with your middle finger by gently touching the skin while maintaining a firm pressure with your index finger.
  4. Step 4 As soon as you feel the pulsations, look at the clock and start counting number of pulsations. Count for at least 15 seconds and multiply the number by 4. To be more accurate, count for the whole minute.
  5. Step 5 Normal pulse is around 72 beats per minute at rest, however anything from 60 beats per minute to 100 beats per minute at rest is also considered normal.
  6. Step 6 Besides the number you should also check the rhythm or regularity of the pulse. Irregular pulse is almost always abnormal and can be due to number of heart conditions, such as Atrial fibrillation or heart block. Pulse may be increased in fever. Athletes may have a pulse as low as the 40s, however, that is considered normal.
  7. Step 7 Sometimes, despite all the correct techniques, you may still not be able to feel the radial pulse. In case someone has collapsed, the most appropriate area to look for the pulse is the carotid artery, just behind Adam's apple in the neck. Other arteries that may also be used are the bracheal artery (in front of the elbow) and the dorsalis pedis (proximal to the first web of the foot).
Sep 10, 2009 | Lenovo Keyboard
Sometimes water comes out everywhere all over the floorand on the inside, now everything freezes inside the firdge
behind the freezer inner wall is a tube that leads down to a pan under your refrigerator it is blocked: remove the wall; remove the ice buildup on the evaporator coils then using a funnel pour hot water through the tube to the pan. be sure to empty the pan when you are done
Sep 05, 2009 | Whirlpool Freezers
Water is pooling in the fridge from the icemaker, line is not plugged or leaking. It just seems like too much condensation from somewhere
behind the freezer wall is a drain to the bottom condensate tray under the refrigerator this is clogged remove the plastic inner wall remove the ice buildup on the coils and, coil shelf then: clear the drain with hot water poured into the drain hose with a funnel
Sep 03, 2009 | Refrigerators
1982 machine, tub will not pump out at end of wash or rinse
sometimes its just soap buildup and blockage like cholesterol in arteries. have the pump cleaned or replaced . Other times its a fused pump either way it needs service
Aug 01, 2009 | Washing Machines
No grinding of the beans nor not making coffe
Yes! and I hope it helps you. There is a small metal shaft that you can see when you take off the bean grinding unit alot of times with repeated use the shaft will stick from small coffee dust particals and condensation buildup which forms a sticky substance on the inner shaft! get a small pair of pliers and grip the shaft and Turn clockwise 1 full turn, this may unstick it! unplug unit for five min then try again You may want to oil the shaft with some good high grade oil! if this does not work the grinding motor may be burnt out and needs replaced! also check your settings! please rate
THANK YOU!
Jan 15, 2009 | Krups XP7230 Compact Super Automatic...
Health & Beauty Logo
60 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
