Question about Proscan Televison & Video
Proscan in test mode
Tv went into test mode
My proscan tv screen went black and the blue light stays on even wen you press power button to turn off... TV not even a year old...
Try a reset to this TV & check. There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Mar 27, 2015 | Proscan Televison & Video
Power had went out for about three hours when it came back on proscan tv had no picture and buttons on side do not work
Do a reset to this set, and try again. To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 04, 2014 | Proscan 32LA30Q Television
Won't turn on
Proscan tv's use cheap capacitors in the ps area. Fix is replace with exact values.
Feb 02, 2014 | Proscan 26LA30Q 26 in. LCD Television
Proscan TV
with no picture and no audio i would more than likely suspect the main AV Board needs replacing.
Take the back of your tv and get the part number of the AV board ( THE ONE WITH THE INPUTS AND SCART SOCKETS) then Google or Ebay for a replacement.
95% thisd will cure your problem.
Hope this helps
Apr 05, 2010 | Proscan 42LA45H 42 in. LCD TV
PROSCAN 42' LCD COLOR TV MODEL 42LA45H
I am sorry Sir, the display panel is bad. If you purchased it new, it should under factory's warranty. Please call Proscan for a warranty repair.
Proscan Customer Service:
1-800-968-9853 (US and Canada)
May 31, 2017 | Proscan 42LA45H 42 in. LCD TV
Proscan tv ps27123
a capacitor blew up, or the flyback exploded?, happened to a RCA 27" tv i used to have!
Nov 22, 2007 | Proscan PS27123 TV
Televison & Video Logo
24 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
