Question about Dual XDMA7650 240 Watt CD/MP3/WMA/USB/iPod 2-Step Motorized Receiver
When i hook my phone up to the dual xdma7650 it will not read it and it says direct usb control for ipod mosfet power
What could be the problem
2 Suggested Answers
  • 5 Answers
SOURCE: The USB port on my
the USB port does not play music it only charges. the AUX is were you plug it in to get the music. If thats not it then it could be your cord. I had the same problem awhile back.
Posted on Jul 10, 2011
Remote control does not work
The easyist way to find out if the remote control itsself works is to watch it with a digital camera oder cell-phone camera while pressing a button. Normaly the IR-LED is invisible but on the display of one of the mentioned cameras you can watch it flickering if it works.
Mar 31, 2015 | Dual In-Dash CD Receiver w/ USB &...
How do you take off he faceplate of a DUAL XDMA7650 CAR RADIO?
Two small screws hold the faceplates on a lot of the Dual drop down units Open the drop down face and remove the screws. Apply side ways pressure and slightly up from one side of Player. It should release
Jun 11, 2014 | Dual XDMR-7700 CD Player
Dual XDMA7650 all wire hooked up, unit will turn blue but the display wont light up. Tried holding the power button nothing. Please help me I am so frustrated!!
i have this same issue it lights up blue and plays music ...the inner screen lights up and what not but the outer screen will not light up at all helpppppppp
Mar 04, 2013 | Dual XDMA7650 In-Dash CD/MP3/WMA Car...
IPod Touch won't be read
Wont read what ?
Sometimes, you might find that your computer does not read that the iPod is connected to the USB port, preventing the synchronization of new files.
There are several potential causes for this lack of hardware recognition and many steps can be taken to troubleshoot the causes.
Reset your iPod's internal software using the key combination appropriate for your model. Apple's support documentation details how to do this for each available model.
(See Resources)
Install all iTunes software updates and restart your computer.
Connect your iPod directly to a USB port on the computer.
Do not attach through a keyboard port or USB hub.
These might not provide enough power to operate the iPod.
Connect the iPod to a secondary USB port.
If the iPod is recognized now, the original USB port might be damaged.
Connect the iPod using a secondary iPod USB cable.
If the iPod is recognized now, the original USB cable might be damaged and should be replaced.
Restore the iPod using a computer that can read it as a last resort. Connect the iPod to another computer, launch iTunes and select "Restore" from the iPod information screen.
This will erase all data and restore default settings.
Contact Apple support or visit an Apple store for further help if your iPod still cannot be seen. An advanced hardware issue might be present and a warranty hardware replacement might be indicated.
Hope this helps
Oct 24, 2012 | Sony Cdx-gt420u - Mp3/cd Player With Usb...
I hooked up a dual mosfet 4 channel amp and i am not getting power to it. the way it is setup is from battery to 100 amp fuse, from fuse to inside cab of truck then to 500 K farad, Split from + to power on...
Bad ground sounds like you may have paint or undercoating stopping the ground from making good contact or unhook the remote wire and run a small wire from the main power to the remote hook up and see if it works ...... May have a faulty remote
Apr 25, 2011 | Dual 2-Channel Bridgeable MOSFET Amplifier...
How can I hook up an ipod to a EEQ Mosfet 50WX4 pioneer super tuner 111 D stereo?
How can I hook up an ipod to pioneer mosfet 50wx4? i cant get the aux function to show up
Dec 12, 2009 | Pioneer 50W x 4 MOSFET Apple iPod...
When I plug my iPhone into the USB it doesn't
ANSWER: The headphone jack will not charge your iPod. Only the USB will charge your iPod. However, the headphone jack will play music, but the USB will not play music from your iPod.
REASON: The headphone jack does not provide any power to charge your iPod. It isnly has enough power to recieve a music signal.
REASON WHY YOU CANNOT PLAY IPOD THROUGH THE USB: The USB is only intended to be used with a flash drive or external hard drive with a folder structure containing either .mp3 or .wma files. The way the USB works on the system is that it reads all the files and folders on the entire device and will say "reading" until it reads all the files and folders. This should only take a few seconds but if there is tons of files it may take longer. Main problem: An iPod contains much more than just music files and folders - it contains an entire operating system. Worse, the operating system which the iPod uses is protected, keeping other devices except for iTunes from reading the music files.
TO PLAY MUSIC FROM USB (NOT IPOD): You will need to use a flash drive or external hard drive with your USB. This device can only contain music, and the music must be organized into folders. Your iPod will not work. However, you can use Auxiliary input using a cable which both ends are 1/4" headphone jacks, one end going to the iPod and other plugged into your stereo.
SOLUTION: To charge your iPod, you need to plug it into USB. However, to play music, you need to plug your iPod into the headphone jack.
Good Luck! - Chris Proia
p.s. Here is the User Manual for your XDM6350 : http://www.dualav.com/support/manuals/xdm6350.pdf
Aug 13, 2009 | Dual Electronics XDM6350 Car CD/ MP3...
Ipod connection to a dual xhd6425
from what I read the dual is not ipod compatible. Use teh aux in port instead to playback or use a memory stick in the usb port
Feb 28, 2009 | Dual Electronics XHD6425 Car CD/ MP3...
Usb kdc-x890 IPOD
The 890 doesn't support iPod control via USB. You can only read plain data storage devices on the USB port, such as a flash drive or portable hard drive. When you plug the iPod in (to a PC or the 890), it doesn't show up as a plain file storage device. Some of the newer Kenwoods do offer direct iPod control via USB. These ones have more "smarts" and are able to properly talk to the iPod and access its music. For the older models, you'll need to buy the special iPod interface, which accesses the iPod like a CD changer.
Mar 20, 2008 | Kenwood KDC-X890 CD Player
Dual XDMA7650 240 Watt CD/MP3/WMA/USB/iPod 2-Step Motorized Receiver Logo
26 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
