Question about Lincoln Electric Welding Tools
Engine will not idle after starting - Lincoln Electric Welding Tools
    Habit-Forming:
  • 22 Answers
Not knowing what model you have makes it almost impossible to suggest a repair, however, your problem indicates a fuel supply problem, if your unit has been in storage, or not used for a while,and was shut down with fuel in the tank and carburetor, it is likely that you have fuel that has stratified, and turned into a varnish inside, which will require a dis assembly and thorough cleaning before it will idle, if it has been in use, it might still need complete carb clean, also check you fuel filter, usually it is something that is just being overlooked, spark plug???? spark plug wire? ignition coil air gap??
Posted on Nov 20, 2015
2013 Honda Activa will not idle when warm
Hi, Anonymous you need to make sure you have no intake leaks by spraying some Brake Kleen, Contact Cleaner, Starting Fluid etc. around the intake manifold and seals, if the RPM's go up or down significantly then you have a leak that needs to be fixed before you can continue with the carburetor adjustment.
The engine should be at operating temperature with the enrichener off to set the idle between 950-1050 rpm. Turn the idle skrew clockwise to increase the idle speed and counterclockwise to decrease the idle speed. If you have access to your air fuel mixture skrew you may turn it as well, if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the air fuel mixture skrew clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the end, now back the skrew out 1-1/2 full turns to establish a starting point start the engine and check the idle rpm's and turn the idle skrew accordingly for 950-1050 rpm if necessary, turn the air fuel mixture skrew 1/4 turn at a time and let the engine settle for about 10 seconds, turn the skrew clockwise for a leaner mixture and counterclockwise for a richer mixture, you are seeking the highest rpm your air fuel mixture skrew can acquire without going past 3 full turns from bottom then resetting the idle skrew back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the air-fuel mixture skrew all the way in then your pilot/low-speed jet is too big and needs to be replaced with the next size smaller. Final adjustment should be made with a clean air filter mounted to the carburetor.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Honda Activa 2013 Engine Stalling
Honda Activa Engine idling stalling issue caused by faulty ring fitment...
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
http://www.partsfish.com/page/oem-parts-for-honda
Honda activa 2009 Owner Manual
Jun 28, 2014 | 2011 Honda Activa
Hi, P and the usual suspects are:
1. Idle speed improperly adjusted.
2. Air fuel mixture screws not properly adjusted.
3. Inlet system air leak.
4. Leaking accelerator pump.
5. Loose low-speed jet.
6. Plugged low-speed jet.
7. Contaminated or plugged low-speed circuit.
8. Enrichner valve/choke not seated or leaking.
9. Multi carburetors out of sync and need to be balanced.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Jun 28, 2014 | Honda Activa Motorcycles
Truck dies when idling
HI
first I would like to tell you, do this procedure only if the 5th digit of your VIN is C or K.
Description
The engine control module (ECM) learns the idle position of the throttle plate to ensure the correct idle. Anytime the throttle body is cleaned or replaced, the ECM must learn the new throttle position. The idle may be unstable or a DTC may set if the throttle position is not learned.
Conditions for Running the Throttle Learn Procedure
• DTCs P0101, P0102, P0103, P0107, P0108, P0111, P0112, P0113, P0506, and P0507 are not set.
• The engine speed is between 450-4,000 RPM.
• The manifold absolute pressure (MAP) is greater than 5 kPa.
• The mass air flow (MAF) is greater than 2 g/s.
• The ignition 1 voltage is greater than 10 volts.
Throttle Learn
Important: Do NOT perform this procedure if DTCs are set. Refer to Diagnostic Trouble Code
(DTC) List - Vehicle.
1. Start and idle the engine in PARK for 3 minutes.
2. With a scan tool, monitor desired and actual RPM.
3. The ECM will start to learn the new idle cells and Desired RPM should start to decrease.
4. Ignition OFF for 60 seconds.
5. Start and idle the engine in PARK for 3 minutes.
6. After the 3 minute run time the engine should be idling normal.
Important: During the drive cycle the check engine light may come on with idle speed DTCs. If idle speed codes are set, clear codes so the ECM can continue to learn.
* If the engine idle speed has not been learned the vehicle will need to be driven at
speeds above 70 km/h (44 mph) with several decelerations and extended idles.
7. After the drive cycle, the engine should be idling normally.
* If the engine idle speed has not been learned, turn OFF the ignition for 60 seconds
and repeat step 6.
8. Once the engine speed has returned to normal, clear DTCs.
Good Luck
Mar 04, 2014 | 1995 GMC Sierra
91 buick lesabre chugging at idle and accelerating smooths out at speed
It can be issue with IAC( idle air control valve) causing the problem.
There are many other possibilities causing these idle issues. Engine idles rough.
There are few help links with solutions to troubleshoot such idle issues.
I suggest you refer the link below and follow its troubleshooting details:------
Click the link below:-----
Ford Expedition IAC valve replacing
http://technoanswers.blogspot.com/2012/12/ford-expedition-iac-valve-replacing.html
Bad miss at idle?
http://technoanswers.blogspot.com/2012/01/bad-miss-at-idle.html
Stumbling and stalling at idle after engine rebuild?
http://schematicsdiagram.blogspot.in/2012/03/stumbling-and-stalling-at-idle-after.html
1999 Ford F-150 Idles rough and quits when gas pedal is pressed less?
http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html
Engine stumbles coming off idle when warm?
http://repairhelpcenter.blogspot.com/2012/01/engine-stumbles-coming-off-idle-when.html
Erratic idle on car?
http://schematicsdiagram.blogspot.com/2011/12/erratic-idle-on-car.html
Cold start problem and vehicle shudder around 2500 to 3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
Low idle when cold out side?
http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html
GMC Sonoma Stalls and idles low
http://technoanswers.blogspot.com/2012/10/gmc-sonoma-stalls-and-idles-low.html
GMC Idle Air Control (IAC) Valve Replacing?
http://schematicsdiagram.blogspot.com/2011/12/gmc-idle-air-control-iac-valve.html
1996 Camry intermittent engine failure while idle?
http://repairhelpcenter.blogspot.com/2011/10/1996-camry-intermittent-engine-failure.html
Engine quits at idle?
http://repairhelpcenter.blogspot.com/2011/10/engine-quits-at-idle.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
High Idle Problem
http://repairhelpcenter.blogspot.com/2012/10/high-idle-problem.html
While stop engine idles like cylinder missing?
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
Idle flair is noticed on car? Rough idle? car will not idle? Erratic idle speed?
http://technoanswers.blogspot.in/2012/02/idle-flair-is-noticed-on-car-rough-idle.html
High rpm in neutral? Inconsistant high RPM in neutral?
http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
Vehicle stumbling at idle and shows code 54?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-stumbling-at-idle-and-shows.html
Rough idle, staling and Erratic shifting?
http://technoanswers.blogspot.in/2012/03/rough-idlestaling-and-erratic-shifting.html
These details will help.
Thanks.
Feb 04, 2013 | Buick LeSabre Cars & Trucks
My aprila rs50 starts fine and runs fine cold but if it heats up abit you pull the throttle and it sounds like its dieng
Instructions
    • 1 Park your RSV 1000R on a well-ventilated, level area, using its kickstand.
    • 2 Start the engine and let it idle in place until the temperature gauge built into the instrument cluster indicates a minimum internal temperature of 180 degrees Fahrenheit. This is the motorcycle's ideal operating temperature.
    • 3 Take note of the engine idle speed, using the tachometer needle, while the engine is running. Ideally, the engine should idle steadily at 1,250 rpm.
    • 4 Adjust the engine idle speed to 1,250 rpm, using the idle adjuster screw hidden between the lower right edge of the fuel tank and the upper edge of the right middle fairing panel. Turn the idle adjuster screw clockwise to increase the engine idle speed, or counterclockwise to decrease the engine idle speed, using a small flat screwdriver if your RSV 1000R's frame (VIN number) precedes ZD4MEE009YS000292. A plastic knob allows the engine idle speed to adjusted by hand on RSV 1000R models with a frame (VIN) numbers starting from ZD4MEE009YS000293.
    • 5 Rev the engine two to three times and observe the tachometer. The engine should return to a 1,250 rpm idle. Adjust the engine idle speed as needed, using the method described, then rev the engine again. Problems may exist within the throttle control, fuel-injection system or engine, if the engine idle speed will not hold steady at 1,250 rpm. Contact your local Aprilia service facility for assistance.
    • 6 Stop the engine, once you have obtained a steady 1,250 rpm idle speed.
Jan 17, 2013 | Aprilia Motorcycles
Will not idle when cold
Its cold start issues:----
Go through the list of help links mentioned below:----
Click the link :----
Ford explorer 4.0 will not idle when cold?
http://technoanswers.blogspot.in/2012/02/ford-explorer-40-will-not-idle-when.html
Automatic transmission shift lever hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
Car won't start when cold?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
Bad miss at idle?
High Idle Problem
Thanks.
Dec 14, 2012 | 1999 Jeep Wrangler
92 dodge 1500 pick up 360 v8 automatic Starts, runs but hesitates, low power code 37 on diagnostic readour
Code 37 is torque converter clutch solenoid failure. Transmission wont shift in and out of overdrive.
Nov 28, 2012 | Dodge Cars & Trucks
Ford Taurus idle missing
There are many other possibilities causing these idle issues.Engine idles rough.
Bad miss at idle? http://technoanswers.blogspot.com/2012/01/bad-miss-at-idle.html
High Idle Problem
Thanks.
Nov 24, 2012 | 2001 Ford Taurus
Welding Tools Logo
470 people viewed this question
Top Lincoln Electric Welding Tools Experts
oleolson
Level 1 Expert
Daryl Gleaton
Troy
Troy
Level 1 Expert
Are you a Lincoln Electric Welding Tool Expert? Answer questions, earn points and help others
