Question about Pool & Spa
LED Light Malfunction
I recently purchased a used 2006 Cal Spa 6100. I'm having an issue with the LED lights. They operate perfectly if I'm only running one pump on low speed and the secondary pump. When I turn the jets on as well, about 2/3 of the lights go off. Any suggestions?
  • 717 Answers
This sounds like a transformer is going out possibly. You are losing power in the system.
I would have an electrician check the system before moving forward.
US Parts Center
Posted on May 06, 2014
SOURCE: High speed spa pump shuts off
The motor may have a thermal cutoff if the motor draws too much current. Do you have a sufficient large gauge circuit supplying the motore? If not the actual voltage at the motor may drop, causing it to draw more current to make up for the loss of voltage, thereby tripping the motor's protective breaker. I assume the motor will start again after serveral minutes of cooling down.
Curtis
Posted on Apr 19, 2009
wayneard
  • 1901 Answers
SOURCE: What does SF mean on pool and spa pumps?
SF stands for Service Factor. It has to do with how much overload your motor can handle without damage. Here is some information about it:
http://www.engineeringtoolbox.com/service-factor-d_735.html
You should not be feeling any "trickle" of electricity. You are correct...it is NOT SAFE! I would definitely have another qualified electrician check your wiring out.
Thanks for using Fixya.
Posted on May 16, 2009
SOURCE: Pump will not work in high speed
Clean the relay contacts on the board. Cut the power, ofcourse. Also, try switching the hot wire on the low side of the pump to the high side to rule out the pump.
Posted on Jun 08, 2009
john224
  • 1378 Answers
SOURCE: pump stops running on high speed
You have a magnetek motor and it is overheating and cycling its thermal overload. A local electric motor repair shop may be able to fix it however it will likely need to be replaced. It is to costly to repair the motor if the damage is in the windings.
Assuming at that low a horsepower it is 115V, the likely replacement motor is a catalog #BN37. We sell it for $157. You are usually better off replacing the seal when you replace the motor and most Jacuzzi pumps are either a 200 or 1000. They should be around $5.
Posted on Jun 12, 2009
Coastsider
  • 331 Answers
SOURCE: Hot Spring Spa pump won't run just click on circuit board....
Check for voltage at the pump, before assuming the relays are out... then check for voltage before and after the relay contacts
Posted on Apr 14, 2010
Recent purchase of 1999 sprint st having all sorts of issues with headlight not working or coming on but not staying on then no light at all has led lights fitted
probably find that the led lights were fitted in a back yard and attention to current required to run relays and light control modules was not carried out properly
talk with an auto electrical shop to find out all that is required to fit LED lights to a vehicle that did not have them fitted as standard
Nov 24, 2016 | Cars & Trucks
Cal spa led lights
not enough power, are you running all the lights from the same power source, if you are find another circuit to hook the other set to.
Mar 31, 2014 | Radio Communications
No LED light?
check voltage from wall then transformer voltage
Apr 24, 2012 | Pentair Control Board - 42002-0007s
I have recently purchased a preowned escape and today my abs light came on and is staying on, can you tell me what is wrong with it as I have a 2 year extended warranty on the suv
It is an OBD2 Emission System Malfunction,
as are all lights that you get on the dash
You have a possible ABS Braking System Failure
Mar 03, 2011 | 2006 Ford Escape
Colorlogic Pool Light flashes like strobe
These swimming pool lights have a power-cycled feature. THis means that you can power down the light and then power back up in 10 seconds and the light pattern will change. It sounds like your light is not cycling properly. Power it down for a full 60 seconds. This will reset the power cycle. Then try turning it on and off in 10 second intervals. If it doesn't reset, you bulb may only be partially functioning and it may need to be replaces.
Jul 06, 2009 | Hayward 12v LED Color Logic Pool Light...
Blinking light on Westell 6100 DSL modem
Blinking light means that firmware on your DSL modem just got updated. The modem is pinging the Networ/Computer connected to it. If you open your Modem Page 192.168.1.1 you will see the difference, unless you never have done it before.
Jan 25, 2009 | Westell Wirespeed LiteLine 6100...
Malfunction indicator lamp
The Malfunction Indicator Lamp or MIL (Also called the check engine light or service engine soon light) comes on when the on board computer detects an issue with the operation of the engine or transmission.
The best thing to do is to take the vehicle to an auto parts store like Autozone and have them hook up their scan tool to the vehicle and read the code. They can read it, tell you what it is and also tell you what the code means.
If it is pointing to a faulty component or sensor and you replace or repair the component the the light will go off on its own after the computer sees that the malfunction is no longer present.
You can have the code cleared, but if whatever caused the light to come on in the first place is not addressed then it will just come back on eventually.
Dec 31, 2008 | 2006 Toyota Tacoma
Pool & Spa Logo
57 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
