Question about Fisher and Paykel E522BRXFD Stainless Steel Bottom Freezer Refrigerator
High pitched hum
Hum stops when door is opened
The fan is making a humming sound
when door open Temp inside goes up, when close door it tries ti bring temp inside back to where it needs it also it will generally only try to work when in closed environment don't sound like any "Fault" tho
Aug 22, 2015 | Samsung RF265AB (258 cu ft) Bottom Freezer...
Kenmore elite refrigerator
Check the door switch by depressing it with your finger. maybe not making contact that well with the door ?
Dec 12, 2013 | Refrigerators
Microwave starts humming when connecting to mains
Chances are a door switch or power / cooking relay is shorted.
Jan 08, 2013 | DeLonghi Microwave Ovens
My micrwoave will keep humming when it is just plugged in with door closed
maybe it;s humming because it don't know the words. haha. is the handle lose on the door, or do you have something on the top of the microwave?
Aug 11, 2012 | Maytag MMV4203DS 2.0 Cu. Ft. Combination...
After the GE JVM1190BY002 Microwave stops its microwave sequence the fan motor above the touchpad just sits and hums but doesn't shut off.It still heats food corectely and it stops humming when I open...
You should first be sure your filters are clean and that your ductwork is clear.
See this link for a bulletin that may address your problem.
Otherwise, see this link in case you have a sticky door switch or relay.
You can find helpful GE exploded views and order GE parts here, and download GE owner's manuals and installation instructions here.
Oct 20, 2011 | Microwave Ovens
My 41A4315-7a Garage door opener Motor does not engage. It just hum sfor a second then stops. I checked the internal gears and they seem fine. The door buzzes for a second then stops. Any Ideas.
If the door is not stuck in the open position and just hums you could have a bad start capacitor. It is alongside the motor and has 4 wires going to it.
Dec 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
Making humming noise power not on door locked
turn off the unit.use a wet dry shop vac and attach it to the end of the drain hose this will remove all the water then you can turn it back on and should be able to open the door to get your clothes out.
after all thatis done you need to check the drain pump and make sure there is nothing blocking the pump.other likely problems are the door lock mechanism is bad or the main control board
Jul 05, 2010 | GE Energy Star WCVH6260F Front Load Washer
Motor hums but nothing happens
I just had the same problem. Extreme cold, garage door stops working, motor hums, same here. I opened up the my garage door opener(after unplugging it), and found that the wormwheel had a wear spot on it. This is the gear that allows the motor to raise and lower the garage door. Any way, after the wife "sugested" that the door was too heavy to lift, I went and bought a new garage door lifter. But if you are handy dandy with tools, I have seen the wormwheel for sale here. http://www.aaaremotes.com/gearsprocask.html It's the plastic wheel that went bad on me. If I would have found this before buying the garage door opener, I would have got the sprocket assembly. I hope this helps!
Jan 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
LG DRYER DLE2516W
The timer is not advancing itself to the OFF or open cam, which opens points and stops the timer motor.
You will have to replace the timer to correct the issue.
Dave E. (Illeagle)
May 30, 2008 | Dryers
Fisher and Paykel E522BRXFD Stainless Steel Bottom Freezer Refrigerator Logo
26 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
