Question about Garden
Riding mower backfires, badly
Engine backfires when running
  • 42 Answers
A backfire typically results from improper air to fuel ratio. An overly lean air-fuel mixture (i.e. an overabundance of air) can lead to a failure to ignite in the combustion chamber, also called a "misfire". The unburnt fuel then enters the exhaust system, where hot components can cause the fuel to ignite unpredictably. Alternatively, rich air-fuel mixtures (i.e. an overabundance of fuel) can result in incomplete combustion, again causing unburnt fuel to enter the exhaust system.
Posted on Apr 23, 2014
  • 126 Answers
SOURCE: mower backfires and loss of power
i would also check fuel flow. pull the gas line from the carb and see if gas flows out at a good rate (into a metal can of course) or if it trickles out. if the latter, then gas tank either has junk at the bottom preventing the gas from flowing or the vent hole (usually on the gas cap) is plugged.
i have also had my carb float bowl rust out on me, but that took 10 years.
Posted on Jan 29, 2009
SOURCE: gas in the oil in my craftsman 17.5 riding mower
You have a bad antibackfire valve. It is located on carburator below the fuel bowl. You can replace it, or as I advise others, install an inline shutoff valve. Turn the fuel valve on to start it, then turn it off when you shut the engine down.
Posted on Mar 24, 2009
SOURCE: Riding mower having problems starting then runs roughly
I have a Scotts _ John Deere law mower tractor model S2048-S2554 Serial number 020-001, the engine runs but sounds like it is going to die or it needs air --- it runs unnevenly
Posted on Jul 20, 2009
  • 124 Answers
SOURCE: have a craftsman 18.0hp riding lawn mower. Has a
Most likely it is the governor spring but you could have a stiff throttle shaft or a needle that is not closing properly allowing the carb to flow too much fuel into the engine.
Posted on Sep 20, 2009
RonInFla
  • 86 Answers
SOURCE: i have a riding mower and it runs but lack power
if it's a 2 cylinder (should be) 1 spark plug is fouled out...rule-o-thumb...replace both...that's step 1...
Posted on Apr 28, 2010
I have a 17.5 Murray riding lawn mower engine runs well when I engage the blades it spits and sputters and starts backfiring what could be the problem
Sounds like bad fuel....runs fine when not under stress but poops out under pressure. Drain fuel and refill with new mix if it's a 50/50 gas-oil blend.
Apr 26, 2016 | Murray Garden
Engine runs "rough" and backfires.
sound like bad exhaust valve time for valve job about a 100.00 exhaust valve is bad do to not seat or broken looes seat if less than one year warranty kicks in
Sep 02, 2014 | Garden
My lt 1000 17.5 hp riding mower will backfire once in awhile when starting but runs fine once it starts. why
first smell the oil is there a gas smell to it?the needle valve maybe dripping fuel and over flowing into the intake
Apr 18, 2012 | Craftsman Garden
Mower backfired a few times and died it wont run now unless you hold the key on at that time all it does is pops and backfires with every revolution
I would check for water in the carb bowl and also the flywheel key maybe sheared allowing the engine to be out of time with the ignition and cause it to backfire and pop.
May 19, 2010 | Garden
SAbre ridingb mower. Runs, backfires,almot die, still run. Backfire again,then dies and can not restart. PLEASE HELLP!!!!! PHIL Mpwer M#1438 Engime B&S M#287707 14.5hp, OHV
Sabre riding mower. Runs, back fires, almost dies,still runs. Back fires again, then dies and can not restart Please HELP!!!!!! Mower model #1438 14.5/38. Engine Briggs and Stratton, Model #287707, 14.5hp, OHV.
Jun 06, 2009 | 2003 Ford E150
Does the gx 340 have a timing belt. I have a honda 1011 riding mower that backfires when trying to start, the fly wheel sheer pin is ok.
What engine do you have ? Some have a selonoid on bottom of bowl of carburetor if bad can cause your problem.
May 12, 2009 | Garden
Gas in the oil in my craftsman 17.5 riding mower
Mar 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman mower backfiring
if a camshaft came loose the engine would not run at all. IF engine still runs then i would change the head gaskets. these things **** air and cause backfiring when running. but if engine doesn't run anymore i would look on ebay or craigslist for local mower for parts at least.
Feb 18, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Garden Logo
74 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
