Question about Briggs & Stratton Garden
Backfiring engine backfires
  • 194 Answers
Most often the shear key under the fly wheel is sheared
Posted on Apr 22, 2014
  • 77 Answers
SOURCE: engins starts and runs when mowing will backfire and stall.
First,if your blade is bent and hasnt been replaced yet,do it, second make sure your timing is still right on your engine.
Posted on Aug 09, 2009
  • 3911 Answers
SOURCE: Backfire - Husqvarna YTH20K46
I find my 2148 runs much happier on the medium grade shell than on the cheaper gas. I did have a nasty POW, which resulted in bent pushrods, or perhaps the bent pushrods caused the POW. After replacing the pushrods, and adjusting same, the backfiring stopped altogether. knock on wood. The 21 is a B&S engine which has a propensity to the bent pushrods. Fortunately for me, my neighbor is a wiz at those fine adjustments.
Posted on Mar 24, 2010
  • 640 Answers
SOURCE: my lt1000 turns over and
The engine should be an OHV type. You could try adjusting the valves under the OHV cover. Kinda like the valve lash on cars. When the valves are at rest you can set each one to about .004 with a feeler guage. You can look on youtube for a video one adjusting lawnmower engine valves. Seeing it is easier to understand then reading it.
I hope that this helps you get it fixed.
Posted on Jul 18, 2011
SOURCE: backfiring thru carburator briggs and straton
manual said use champion qc12yc spark plugs gap 40 hard to found i use b&s plugs fail out. do i need to use qc12yc plugs
Posted on Sep 13, 2011
  • 28 Answers
SOURCE: craftsman tractor model #917271020 backfires but it will not start. Kohler 15.5 engine
suggest to look at the carb adjustement unscrew
Posted on Nov 21, 2011
Back fires rich exhaust
Preventing Backfire on Motorcycle Exhausts ' DoItYourself ...
www.doityourself.com/.../5-tips-to-preventing-backfire-on-motorcycle-e...
When the engine on your motorcycle has an emission system malfunction, such as anexhaust leak or a moment of running rich or running lean, backfire can ...
Exhaust backfire, popping when letting off throttle - Motorcycle Forum
www.motorcycleforum.com > ... > General Motorcycle Discussion
Apr 26, 2009 - 28 posts - ‎17 authors
Exhaust backfire, popping when letting off throttle General Motorcycle Discussion. ...You can damage the engine by running too lean or rich. Backfires on deceleration
Jan 24, 2015
What causes a bike to back fire?
Jul 15, 2012
At my wits end! Backfiring and fouled plugs on ...
Feb 26, 2011
More results from www.motorcycleforum.com
Glad That You Asked. Why Do motorcycles Backfire? at Cyril ...
cyrilhuzeblog.com/.../glad-that-you-asked-why-do-motorcycles-backfire...
Jun 12, 2010 - A visible flame may momentarily shoot out of the exhaust pipe. ...Another backfire situation occurs when the engine is running rich, meaning ...
Is backfire when decelerating a bad thing? : motorcycles
Jan 31, 2016 | Motorcycles
I have a ford cvh 1600 what backfire through carborator only when it is hot and then lose its power
Ford Escort carb backfire Questions & Answers - Fixya
www.fixya.com > Forum > Tags > carb backfire > Cars & Trucks > Ford
Ford Escort cars & trucks carb backfire questions and answers. ... Backfire throughcarborator and engine stopped upon returning from store. ... Turbo conversion from 1995 on a CVH engine - engine cuts out ... I have a xr3 ford escort 1600 with a weber carb,itbackfires and spits fuel up Clean the Carburator completely.
I have a xr3 ford escort 1600 with a weber carb,it backfires ...
www.fixya.com/cars/t10838117-xr3_ford_escort_1600_weber_carb
Nov 17, 2011 - I have a xr3 ford escort 1600 with a weber carb,it backfires and spits fuel up ... Turbo conversion from 1995 on a CVH engine - engine cuts out.
All comments on Ford Escort CVH Straight-through exhaust ...
https://www.youtube.com/all_comments?v=1yA5blCpTLM
Jan 05, 2016 | Ford Cars & Trucks
Why does my 318 lawn mower back fires
Charlene: According to https://www.briggsandstratton.com/us/en/support/faqs/engine-backfire-afterfire " What causes a small engine backfire & how do I fix it? Backfire typically occurs when the engine is decelerated rapidly.
Common Causes of Backfire:
  • Lowering engine speed too fast
  • Gasoline, which contains higher blends of alcohol
  • Carburetor adjustment set too lean
  • Muffler construction can induce backfire
  • Higher than normal engine temperatures
  • Some carburetors can induce backfire due to the sensitivity of internal transitional passages
    (This condition cannot be corrected).
Possible Fixes for Backfiring:
  • Lower engine speed slowly
  • Follow small engine fuel recommendations and/or switch to brands with low or no alcohol
  • Adjust carburetor for optimum performance
  • Inquire with equipment manufacturer about increasing air volume to decrease engine temperature"
Charlene: I hope that helps! :)
Charlen
May 28, 2015 | John Deere Garden
How to fix a backfiring on a 1983 Chrysler 5th avenue edition new Yorker
If it is backfiring, it is likely that the timing belt slipped a notch and needs to be replaced. Backfiring can cause MAJOR DAMAGE to that old engine so please don't drive it if it's backfiring!
May 12, 2015 | Chrysler Cars & Trucks
I have a390 ford engine that back fires while idling it has a breaker point ignition what could be wrong
Check this video for idle speed adjustment. Backfiring can be caused by incorrect mixing in the carburettor or bad timing settings.
Check this link for backfire issues:
. What would cause Ford 390 to backfire through carb Yahoo Answers
Setting Curb Idle Speed of Carburetor Video Holley Carb DVD
Feb 12, 2015 | Ford Cars & Trucks
2002 neon revs up to 4000rpms at start and idles up an ddown 1500rpms-2000rpms after. and begins to backfire near engine .
Engine system needs inspection on case of backfire:-----
Check out related help links to troubleshoot the vehicle backfire issues:-----
Feels like backfire from engine when decelerating?
http://schematicsdiagram.blogspot.in/2012/02/feels-like-backfire-from-engine-when.html
Jeep Backfires?
http://technoanswers.blogspot.in/2012/02/jeep-backfires.html
Nissan Pathfinder stalls and bucks on Acceleration?
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html
Nissan Pathfinder Backfires?
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-backfires.html
These will help.
Thanks.
Nov 28, 2012 | 1995 Honda Accord
Hi I'm new to this site , I have been asked to close Q I have asked already but don't know how on my iPhone to close then please help
There are two kinds of backfires, one is produced from the engine air intake and the other is produced from the tail pipe of the exhaust system. The cause for a backfire condition can vary depending on the malfunction of a particular system. Some backfires can be extreme enough to cause damage to related components. Anytime a backfire is observed immediately diagnose and repair as needed. If the engine is running rough it can produce a backfire. A backfire occurs when there is an imbalance in the air to fuel ratio required for your vehicle to operate properly. If the fuel mixture is too lean (not enough fuel) you may have a backfire in the intake manifold gasket, or too rich (too much fuel) you may get a backfire out of the exhaust system. It is important to observe the location of the backfire.
Oct 10, 2012 | Cars & Trucks
Garden Logo
23 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
