Question about Home
We have a 2003 Viking Eclipse that is not heating up.
  • Alan May 11, 2010
    Did the heater previously work and when did it stop working? Is there an error message at the control pad. Does the spa function normally just no heat?
Did you check the manual?
Posted on Aug 21, 2009
2003 eclipse 4cyl engine egr where is it?
The common cause of this problem is the coolant temperature sensor on the thermostat housing, and/or the wiring on to it is damaged.
Feb 26, 2015 | 2003 Mitsubishi Eclipse
2003 mitsubishi eclipse rs wont start i already repalced the starter...where is the starter relay at
The relay is located in the relay box under the hood in the relay box. I suggest you Google "relay location 2003 Mitsubishi Eclipse" for the exact location. For troubleshooting purposes, once you locate the relay, simply swap it with an identical relay within the relay box. If it still fails to start, then it is not the relay.
Apr 11, 2014 | 2003 Mitsubishi Eclipse Coupe
2003 misubishi eclipse changed radiator& thermo still over heats ?
with engine cold open radiator cap to see if water pump is moving coolant--could have a clog in system or thermostat not workin rite--also be sure theres enuff antifreeze for ur model--a haynes manual from a parts store has details
Aug 30, 2011 | 2003 Mitsubishi Eclipse Coupe
How to replace lower rear control arms on a 2003 Mitsubishi Eclip
I'm not surprised the shop didn't want to do the work. SOMETIMES removing the cam bolt nuts, and applying a large lever and socket,with heat, will break the bolt free of rust.
If not, it gets involved and expensive very quickly. Bolts can be cut off with and angle grinder wheel, but control arm bushes or complete arms may need replacing.
Jun 03, 2017 | 2003 Mitsubishi Eclipse Coupe
I need to remove and replace the Radio in 2003 mitsubishi eclipse
I WOULD LET THE DEALERSHIP REPLACE RADIO BECAUSE BY IT BEING PART OF THEFT SECURITY SYSTEM.IF YOU DO IT YOUR SELF YOU PROBABLY GOING TO HAVE NO START PROBLEMS.THE PCM WILL GO IN THEFT MODE THINKING SOMEBODY TRYING TO STEAL RADIO OR CAR.IF DEALERSHIP FIX THEY PUT IN NEW RADIO THEN REPROGRAM IT.
Mar 31, 2010 | 2003 Mitsubishi Eclipse Coupe
Location of thermostat 2003 Mitsubetsi Eclipse 4
The thermostat is found at the end of the top radiator hose . Find the top radiator hose and follow it to the engine .There you will find a thermostat housing with the end of the hose attached . There will be 2 bolts holding down the housing to the engine. Undo the bolts and pull the housing off and the thermostat will be there.
Sep 05, 2009 | 2003 Mitsubishi Eclipse Coupe
How can i find the fuse for my clock and stereo display?
had the same problem with my 03 eclipse. check your cigarette lighter fuse. powered on the same circuit. that was my issue
Mar 13, 2009 | 2003 Mitsubishi Eclipse Coupe
2003 mitsubishi eclipse oil inthe base of #2 cyclinder
BAD RINGS OR VALVES. IT'S GETTING TOO MUCH OIL IN THE CYLINDERS.
Feb 03, 2009 | 2003 Mitsubishi Eclipse Spyder
2003 mitsubishi eclipse wiring diagram
I own a 2003 mitsubishi spyder eclipse GT and my alarm fob broke off its key chain so I havent been using it lately (waiting for replacement). Today I went to use my car (unlocked and opened the door with the key) and the alarm activated. The car still starts but I have to wait till the alarm gos through its cycle before I drive anywhere (embarassment of course). How do I disengauge the alarm system till I get the new fob?
Feb 01, 2009 | 2003 Mitsubishi Eclipse Spyder
Home Logo
74 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
