Question about Cuisinart CJE1000 Juicer
Cuisinart juicer broke
Juicer is not working
Cuisinart juice sqeezer throws circuit breaker
Is this a new juicer, have you used this before without the circuit failure?
Most circuits in the house will be are 15 amp breakers. If the appliance has a high amp load then this can cause it to switch the breaker turning on or off.(due to to voltage spikes) I have a waffle iron that does the same thing if my refrigerator cycles while the iron is on.
There are a few things that could cause this. But before anything else I would try the juicer in a different plug that is on a different circuit, like the living room for example. If that works well then I would start looking at you may need to replace the circuit breaker, they do go bad.
Apr 05, 2012 | Cuisinart Juicers
I need a complete new plastic top for my juiceman jr. A large plastic piece broke on the shute. Thank you
If you find a solution, let me know because we just broke our plastic top today too.
Oct 23, 2010 | Salton Jr. JM1 Juicer
JE95XL Juicer: i broke my jug...
No good. You'll need to locate your local Breville service center.
Otherwise, refer to http://www.brevilleusa.com/breville-parts/juicing/juice-jug-je95xl59.html as you can order direct!
May 18, 2010 | Breville JE95XL Juicer
Right Arm of Omega Juicer Model 1000 broke off
CALL OMEGA 717 561 1105 THEY HAVE
THE LATCH ARMS. CHEAP. ASK THEM FOR
THERE ARE TO WAYS TO REPLACE THEM.
Jan 25, 2009 | Omega Juicers Juicer 1000 Brand: Omega
Trying to find a part for the power juicer CL-003 AP
The top white part connects to the motor. You have to buy the whole bottom part. It's not separate.
Jan 09, 2009 | Jack Lalanne Power Juicer 250 Watts
Jack Lalanna Power Juicer
Visit www.powerjuicer.com and find a replacement part.
Aug 04, 2008 | Jack Lalanne Power Juicer 250 Watts
I need the cover lid
CALL WARING AT 800 492 7464 OR COST
PLUS JUICERS AT 800 578 5939. WHEN
THE JUICER VIBRATES BADLY THE BLADE
JUMPS UP AND CUTS OR CHIPS THE
CHUTE.
Jul 01, 2008 | Acme 5001 Supreme Juicerator Juice...
Cuisinart CJE1000 Juicer Logo
Top Cuisinart Juicers Experts
Tom Chichester
David Payne
David Payne
Are you a Cuisinart Juicer Expert? Answer questions, earn points and help others
