Question about Pool & Spa
Pool doesn't have pressure. Checked pump no blockage. Had the pool guy put air through the lines and no clog. Filter has zeobrite sand, but it's green? Pool company said it shouldn't be green. We are going to change the sand. Would this cause low pressure? Shouldn't a filter not working right cause high pressure? Pool chemicals are right but the pool looks cloudy and isn't sucking the dirt up. Any ideas? Our pool guy is stumped!
    Novelist:
  • 172 Answers
Hi my name is Juan and I was a pool tech in california now located in georgia and let me try solve this if your filter is dirty it created a high pressure in your filter gauge with poor suction to check this bypass the filter and see if suction increase sometimes your gauge is bad and is not showing the true reading but if is good and pressure is to low then is so clear you have a suction leak try to replace the pump lid O ring and if you have spa check the intake valve where you select pool or spa if you don't have spa then the air leak is in the pipe connected to the pump suction side believe me this is a common problem
Posted on Jun 16, 2009
Pool pump problem: Cavitation sound in spite of no blockages in suction lines. Replaced many parts and replumbed with no success.
me id make a temporary suction line that could be dropped right in the pool (half union,suction hose with brick tied on end) this would easy test the underground pipes/valves for any spider cracks (air inlets) observe the output using the ole pump if no improvement then sorry that ole pumps gotta go
frequently on old installs I find that winter weather wasn't so kind to the plastic pipes and they develop spider cracks(tiny ) this provides a path to suck air into line
Oct 20, 2015 | Pool & Spa
Swimming pool Hayworth s240 sand filter suction is wimpy can it be old sand causing the problem?
The filter may be clogged. If you have a multi-port valve that you use to backwash, set it to "recirculate" and see if your suction improves. If it does then the filter needs to be cleaned out. If there is no difference the issue may be a clogged impeller or some restriction in the suction line. Has the pressure been running high?
May 19, 2013 | Pool & Spa
Hayward Pro Series Model # s2445
either broken lateral or crack in pipes inside try vacuuming up if same bad filter
Jan 30, 2013 | Hayward SAND FILTER, PRO SERIES
I have a swimpro sand filter it is 5 yrs old and this season when i started it up it doesn't seem to have very good pressure i have backwashed it three times and it wont even run my pool cleaner no...
If there is not much pressure, the problem is with the circulation system. Probably the pump.
When a sand bed gets old the pressure goes up on the guage, but the filter doesnt do much. When there is a lack of pressure, its due to a problem with the water flow. Usually a clogged impeller, strainer basket, or skimmer basket.
The most common solution for a loss of pressure is to dissasemble the wet end of the pump, clean out the impeller, and replace all o-rings and seals, including the shaft seal. This will revitalize the performance of your pump.
Jun 02, 2011 | Hayward SAND FILTER, PRO SERIES
Are vacuuming the pool . My sand filter does not work right it has no pressure going out to the pool. a pool store said it might be air bound .bleed the air out same thing
Do you have problems priming the system? If so you may have a suction leak in the plumbing attached to the front of the pump or a bad 0-ring seal in a valve. Symptom would be that when you set up to vac. The pump would lose prime or move very little water. Also maybe a clogged pump impeller.
May 27, 2010 | Hayward SAND FILTER, PRO SERIES
When i backwash my pool dirt comes back into poll as i vacuum
You either have a bad spider gasket or its time to replace the sand. When replacing use zeobrite.
Sep 17, 2009 | Hayward SAND FILTER, PRO SERIES
I need to change the lateral holder assembly and bottom screen on a Hayward S-200 sand filter. Will I need to remove the variflow valve or will it just come right out?
You will need to remove multiport valve and remove all the sand with a scoop. Not alot of fun. Think about replacing sand with ZeoBrite filter medium when you put it back together
Aug 02, 2009 | Hayward SAND FILTER, PRO SERIES
Reduced circulation/backwash (sand filter)
check your pool pump by putting the valve in recirculate mode.If flow is a problem it may be a clogged impeller.
Jul 05, 2009 | Hayward SAND FILTER, PRO SERIES
Pool & Spa Logo
676 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
