Question about Alpine Car Audio & Video
Alpine model no 5960
Mounting
How do i connect headphones to htr-5960
Does it have a headphone jack on the front of the (Reciever)
Dec 05, 2012 | Yamaha HTR-5960 Receiver
PHILIPS DVP -5960
The easiest and fastest solution is to buy a power converter for the cigarette lighter or other 12v power source. It would take a lot of time and money to change the capacitors and motors on the DVD Player itself. Some power convertors work with any 12v power in your car.
Dec 08, 2007 | Philips DVP5960
Would like to change the stock radio... how do I do it
THIS IS A COPY OF A POST I SUBMITTED TO SOMEONE WHO HAD A SIMULAR QUESTION REGARDING AN ALPINE BRAND RADIO ISTTALLATION. THE PROCESS IS THE SAME NO MATTER WHAT BRAND THE AFTERMARKET RADIO IS.
Go to the store and buy a mounting kit and wiring harness adapter that are for your car. There are alot to choose from and most are universal and come with instructions. You can get these at wal-mart or best buy. The mounting kit is meant to fill in the empty space left by the new aftermarket radio (your alpine). The alpine will have a metal sleeve around it. take this off and put it in the mounting bracket so it is flush. The sleeve will have little triangle shaped tabs on it. Bend these out so the sleeve cant fall out of the bracket or someone will be able to pull out your radio. Remove your stock radio by pulling off the trim around the radio. This is held on by clips, so be careful. There will be a couple of screws holding in the radio. Remove these and pull the radio out. Behind the radio there will be 1 or 2 wiring harnesses plugged into the radio. Unplug these. Then attach the wiring harness adapters you bought. These plug into the stock harness and have wires at the other end that are labeled. Wire the alpine wiring harness into the harness adapters that you plugged into the stock harness. If you want to you can unplug the harness from the alpine and wire it to the harness adapter before plugging it into the stock harness. The wiring diagram should be on the radio. If not the colors are pretty common.
RED = SWITCHED PWR LEAD (IGNITION)
ORANGE = ILLUMINATION
BLACK = GND
YELLOW = BATTERY LEAD
GREY = FNT SPKR RIGHT(+)
GREY/BLACK STRIPE = FNT SPKR RIGHT(-)
WHITE = FNT SPKR LEFT (+)
WHITE/BLACK STRIPE = FNT SPKR LEFT (-)
VIOLET = REAR SPKR RIGHT (+)
VIOLET/BLACK STRIPE = REAR SPKR RIGHT (-)
GREEN = REAR SPKR LEFT (+)
GREEN/BLACK STRIPE = REAR SPKR LEFT (-)
BLUE = PWR ANTENNA LEAD
BLUE/WHITE STRIPE = REMOTE TURN ON LEAD(FOR SUBWOOFER AMPLIFIER)
There may be RCA jack inputs in the back and these are for the subwoofer amp.
There will be a large black cable in the back and this is the antenna wire. Plug in the antenna wire from the back of the stock radio here. Yu may or may not need an adapter for this depending on the size difference between the wire and the hole it plugs into.
**Please note: if your car has a "premium" sound system that comes stock with an amplifier you will need to attach the power antenna lead from the alpine to the remote turn on lead on the harness adapter. If not when you turn on the radio/cd it will not turn on the stock amplifier and the speakers will not work.
I found this out with my 99 dodge avenger which has an Infinity stock radio. You can pop the trunk and look up at the back dash and see the small amplifier.
Once the radio is wired and the mounting bracket is installed, connect the harness adapter as well as the antenna wire. The new wiring harness adapter makes the wiring a little longer so you may have to stuff them back a little bit. Connect the harness from the alpine back into the back of the radio and slide the head unit into the metal sleeve until you hear a click. Before sucuring the mounting bracket and putting the trim back on it is a good idae to try the radio out so if there is something wrong you dont have to disassemble it again. When you buy the harness and bracket it will say on the packaging "nissan 84-94" or "Honda 83-99" or something similar. Look on the back for a complete list of compatable models
please vote and thank you!
Oct 17, 2010 | 1995 Oldsmobile Cutlass Supreme
Looking for instruction to operate an Alpine MDA-W905JB head unit in a Japanese car I just bought.
BLACK = GND
Once the radio is wired and the mounting bracket is installed, connect the harness adapter as well as the antenna wire. The new wiring harness adapter makes the wiring a little longer so you may have to stuff them back a little bit. Connect the harness from the alpine back into the back of the radio and slide the head unit into the metal sleeve until you hear a click. Before sucuring the mounting bracket and putting the trim back on it is a good idae to try the radio out so if there is something wrong you dont have to disassemble it again. When you buy the harness and bracket it will say on the packaging "nissan 84-94" or "Honda 83-99" or something similar. Look on the back for a complete list of compatable models.
Hope this was helpful. Please rate, and thanks!
Oct 17, 2010 | Car Audio & Video
I have a Bassett Sleigh Crib Model # 5960-0604 however the hardware has been lost leaving me with the head boad foot boad and rails, How can I get the hardware.
hi,
you can also get in the net ican give the site
http://www.bestmattressreviews.com/bassett-mattress-reviews.html
that's the site you can search on it.
regards,
Oct 22, 2009 | Bassett Mission Crib
Seeking detail of an iPod interface cable for Alpine 7514S radio
go to your local auto electrician or alpine dealer and find out if they can find you the right cable
Aug 25, 2009 | Car Audio & Video
Yamaha 5960
Does your reciever use a remote control?
If so, you should be aware that on many recievers and surround amplifiers some of the functions may only be accessible via the remote control (the best way to learn about it is to consult the user manual).
I have a Pioneer VSA-730 surround amplifier and the only way i can change the mix levels for surround/sub/center speakers is by a remote control. My friend had the same problem and, after reading the manual, he discovered that he actually needs to use the remote control to access all functions of the amplifier.
Good luck and best regards
3rq8 (Triarcuate)
Jul 15, 2009 | Yamaha HTR-5960 Receiver
Lost instructions
need instructions for the model 5960-0604 model crib
Jun 24, 2009 | Bassett Mission Crib
Car Audio & Video Logo
26 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
