Question about Kenwood KDC-PS909
Replace Flex-PCB in a Kenwood KDC-ps909
How do you open the face plate on this in dash receiver Kenwood KDC-PS909. I need to istall a new Flex-PCB Cable. the old one is cracked and I have a new one and I want to know how to open the face plate to put the new one on.
  • 365 Answers
Don't remember but I think you need "Keys" a couple of funny shaped forks to press in the sides of the head unit...Frankly, if the PCB cable is bad (and you have one). Why not contact a local car audio dealer that sells Kenwood?
Good Luck
Posted on Jun 15, 2009
What would cause the Kenwood KDC-BT555U to have no display
If audio can be heard
Most likely this is a fault of a bad face plate and would need to be replaced.
Jun 10, 2014 | Kenwood KDC-BT555U n-Dash USB/CD Receiver...
I have a Kenwood KDC PS909 HU and I have it connected with an aftermarket wiring harness. The speakers are all brand new and there is no sound with the fronts or the rears when connected through the...
if your car is equipped with a factory amp u must power it up in order to get sound. if you have more problems with the sound gives us a call at 520-882-8979 and well walk you through it
Jun 12, 2010 | Kenwood KDC-PS909
I have the same problem that the Grtpumpkin solved.
you have a bad flexible cable. it needs to be replaced. unless you are good at soldering i would not recommend you replace it yourself, as the connector needs to be unsoldered from the old cable and resoldered on the new one.
Aug 24, 2009 | Kenwood KDC-715S
Replacing the facepale
that hole on that model is for a locking screw, the locking screw is installed to minimize theft and for other precautions. If the face plate is having any odd reactions its normally do to the flex cable. The best sign for a dying or dead flex cable is at the joint. The joint can be viewed at the point when you remove the face plate. Immediately after pulling the face plate off look behind the pivoting frame at the orange colored ribbon, you should only be able to see a small portion of it. If there is any sign of a yellowy residue its a sign that the protective covering of the ribbon is deteriorating. A bad flex cable is everything on the moving face plates.
Sep 06, 2008 | Kenwood KDC-716S CD Player
My Kenwood KDC-7024 has just started playing up - as soon as you turn on the ignition, the face panel comes down, flicks on for all of 2 - 3 seconds and then closes, it then keeps doing this repeatedly...
It's possible the flexible PCB (more of a cable, really) that connects the faceplate to the main unit has cracks in the conductors. This has been an issue with some of the older Kenwood HUs that have the MASK motorized faceplate. The flex-cable gets bent and pinched enough over the years that it eventually cracks the copper.
Mar 07, 2008 | Kenwood KDC-7024 CD Player
Kenwood kdc 7009 - just bought car w/ stereo in it, but no remote or codes ?
Look for a small hole in the face plate. Take the tip of a pen and try holding it in for a few seconds. Re-setting it should work.....
Jan 26, 2008 | Kenwood KDC-7009
Kenwood KDC-322
If you have the remote control for the unit, or can buy one then you can reset the code. Just ask me how...
Jan 09, 2008 | Kenwood KDC-322 CD Player
Face plate will not close, retract into dash,radio plays!
Get your Shifter shortened, it will give you faster more controlled shifts, and keep your knuckles out of the dash.
Nov 18, 2007 | Kenwood KDC-MP628 CD Player
Kenwood MP925 cant get to work
The ribbon cable to the face plate needs replaced. It's an easy fix and any shop that does car audio repairs will likely have them in stock (mine does). Every shop has their own rates but my shop charges around $65-75 to fix that problem. Call around and ask. The bad part is: J84-0153-05 FLEX-RIBBON CABLE FROM FACE TO MAIN PCB
Sep 21, 2007 | Kenwood Sirius KDC-MP925 CD Player
Kenwood KDC 7024
Some flip face stereos use a tiny micro switch to tell the onboard computer when the face is down or up and sometimes it uses the same switch for both positions sensing. It could be this switch is not working properly (dirty contacts, broken, bad wire, mis-aligned, etc.) and that is causing the problem. Good luck.
Feb 12, 2007 | Kenwood KDC-7024 CD Player
Car Audio & Video Logo
112 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
